mihajlo24v 0 Posted February 6, 2009 Report Share Posted February 6, 2009 da li mogu sam da skinem izduvne grane i kako?!ili je potrebno da to uradi majstor?! Link to post Share on other sites
BMW 528iA 0 Posted February 6, 2009 Report Share Posted February 6, 2009 Samo sprejaj sarafe WD40 jer sigurno su blokirani. Link to post Share on other sites
error 0 Posted February 6, 2009 Report Share Posted February 6, 2009 ....i sami che se odvrnuti! ;) Link to post Share on other sites
mihajlo24v 0 Posted February 6, 2009 Author Report Share Posted February 6, 2009 babicu ;) te! ne moze da prodje bez tvojih domishljatih upadica!! :( Link to post Share on other sites
error 0 Posted February 6, 2009 Report Share Posted February 6, 2009 ;) Link to post Share on other sites
mihajlo24v 0 Posted February 6, 2009 Author Report Share Posted February 6, 2009 zanima me dali mogu opusteno da pridjem sa donje strane i da li mora da se,npr,oslobode nosaci motora ili tako nesto meni komplikovano??!! Link to post Share on other sites
Transporter 0 Posted February 6, 2009 Report Share Posted February 6, 2009 Veoma jebeno, mislim i nije toliko ali treba strpljenja, ima pun qrac srafova i malo je nepristupacno, svejedno ces morati da ides kod majstora kad budes spajao, moj ti je savet da castis tamo da ti oni to odrade u auspuh servisu, nahvatas ih neki dan kad je kisa i kad nema posla ima sve da rade ;) Link to post Share on other sites
mihajlo24v 0 Posted February 6, 2009 Author Report Share Posted February 6, 2009 bolt on je!nema spajanja!!to sam i predpostavio ali nestrpljiv sam i hteo sam ja da cackam!!!hvala! Link to post Share on other sites
Transporter 0 Posted February 6, 2009 Report Share Posted February 6, 2009 Cackaj onda, gedoru 11 u ruke i vezbaj dok ne stignu ;) Link to post Share on other sites
mihajlo24v 0 Posted February 6, 2009 Author Report Share Posted February 6, 2009 jos jedno pitanje:da li postoji neka farba/lak kojim mogu da ih prefarbam i koja ce izdrzati te visoke temperature i gde moze da se nadje,lova!! cisto informativno! Link to post Share on other sites
mihajlo24v 0 Posted February 6, 2009 Author Report Share Posted February 6, 2009 stigle!!! Link to post Share on other sites
Transporter 0 Posted February 6, 2009 Report Share Posted February 6, 2009 Mislim da nema potrebe da ih farbas, ima spej za visoke temperature u farbarama ali umesto da je crn on postane svetlo siv, maltene beo tako da ja tu ne bi nista dir'o ;) Link to post Share on other sites
vlada_v6 0 Posted February 7, 2009 Report Share Posted February 7, 2009 neznam da li si pitao tatu da li smes to da diras i da menjas??? jer je po meni to pametnije pitanje nego da farbas grane Link to post Share on other sites
mihajlo24v 0 Posted February 7, 2009 Author Report Share Posted February 7, 2009 vidi mangupa?!sto smo se okurazili!jesi li ti neki babicev rodjak?!u stvari stvarno bi trebalo da cutim!!!! ;) Link to post Share on other sites
BMW KLINIK 0 Posted February 7, 2009 Report Share Posted February 7, 2009 Jos snage molim ;) Link to post Share on other sites
error 0 Posted February 7, 2009 Report Share Posted February 7, 2009 ;) :( :( Link to post Share on other sites
batabmw 0 Posted February 7, 2009 Report Share Posted February 7, 2009 najlakse ti je da izvadis motor i onda ih zamenis i sve to polako vratis a da i posle castis sam sebe a nema puno srafova oko 30 komada mozda i manje ako su se neki sami ranije otkinuli Link to post Share on other sites
dacha654321 0 Posted February 9, 2009 Report Share Posted February 9, 2009 Sve u svemu seks a ti uopste ne uzivas... Nije zanimljivo.... Link to post Share on other sites
batabmw 0 Posted February 9, 2009 Report Share Posted February 9, 2009 u taj sex uopste ne volim Link to post Share on other sites
mihajlo24v 0 Posted February 10, 2009 Author Report Share Posted February 10, 2009 da li je problem ako ne zavijem sve shrafove ,sredini je malo zaguljeno prici,na kracoj ne mogu 2 od 4 da zavijem!!nisam jos poceo ali pripreme su u toku i sam krecem u ovaj poduhvat!! Link to post Share on other sites
error 0 Posted February 10, 2009 Report Share Posted February 10, 2009 gledaj ti da ih zavijesh ipak Link to post Share on other sites
dacha654321 0 Posted February 10, 2009 Report Share Posted February 10, 2009 Pa kud puklo da puklo ali kao sto babic kaze gledaj ipak sve da zavijes i vratis kako je bilo... Link to post Share on other sites
mihajlo24v 0 Posted February 15, 2009 Author Report Share Posted February 15, 2009 jos jedno pitanje: da li postoje kraci oni shrafovi bez glave sto idu u blok i gde mogu da ih nadjem,koja lova?! Link to post Share on other sites
eone 0 Posted February 15, 2009 Report Share Posted February 15, 2009 U blok? Link to post Share on other sites
wice 0 Posted February 15, 2009 Report Share Posted February 15, 2009 mislis na brezone? pa oni idu u glavu ako menjas granu? Link to post Share on other sites
