leon63 0 Posted December 10, 2011 Author Report Share Posted December 10, 2011 Da li si izvukao i potrebne zice iz instrument table??? Link to post Share on other sites
325ixA 0 Posted December 10, 2011 Report Share Posted December 10, 2011 e wice, bas nema srece, nista ne znam o e36. gotovo nista. Link to post Share on other sites
wice 0 Posted December 11, 2011 Report Share Posted December 11, 2011 da sa plavog sam ubo novi pin na pin 10 a sa belog one 3 zice upario sam ih po boji kao sto je na shemi stim sto je kod mene na pin 21 vec bila belo crna zica i samo sam spojio ovu od borda na nju Link to post Share on other sites
wice 0 Posted December 11, 2011 Report Share Posted December 11, 2011 evo,ponovo sam sve skidao i proveravao,sveje oziceno kako treba,sa plavog dzeka pin 10 sa belog su korisceni pin 21 pin 11 i pin 12... kao po shemi,,,,ali i dalje na bordu ne iscitava brzinu,ne iscitava potrosnju ,ne iscitava trip 1 & 2 jedino sto je se range sa 107km promenio na 108km Link to post Share on other sites
wice 0 Posted December 15, 2011 Report Share Posted December 15, 2011 i dalje nista...da li je moguce da bord nije ok? Link to post Share on other sites
Sicko 0 Posted December 16, 2011 Report Share Posted December 16, 2011 Ako ti engleski nije problem imas na bimmersforum negde u delu o e36ticama temu na dosta strana o dvorednom bordu, ugradjivanju , problemima itd... Jbg obrisao sam linkove vezane za e36-tice. Link to post Share on other sites
wice 0 Posted December 16, 2011 Report Share Posted December 16, 2011 prelistao sam par tema tamo,ali ne nadjoh resenje.pokusacu opet ,hvala Link to post Share on other sites
mare_ser 0 Posted February 13, 2012 Report Share Posted February 13, 2012 A da li neko zna jel mudrost da se namontira jednoredni bord ukoliko nisam imao analogni sat,vec samo obicnu policu za odlaganje stvari? Link to post Share on other sites
wice 0 Posted February 13, 2012 Report Share Posted February 13, 2012 pa nije neka mudrost samo moras sve da ozicavas,znaci na semi ozicavas sve sa gornjeg dzeka Link to post Share on other sites
mare_ser 0 Posted February 17, 2012 Report Share Posted February 17, 2012 Ok Wice,mada i dalje mi nista nije jasno. Ne znam sta je CHECK CONTOL MODULE, CHIME, START/CHARGE SYS, X17 BLUE CONNECTOR i X16 WHITE CONNECTOR. Ako znas brate pojasni mi malo detaljnije. Kupio sam i bord(kao na slici http://www.ebay.co.uk/itm/BMW-E36-3-Series-Board-Computer-/180682446998 i senzor temparature,sve sam uzeo,ali nikako ne mogu da skontam sta se kako povezuje. Kontam da sam dosadan...ali molim te pomagaj. :) Link to post Share on other sites
mare_ser 0 Posted February 17, 2012 Report Share Posted February 17, 2012 E da,znaci bukvalno nista nemam od instalacije,samo golu policu,koju kad izvadim iza nema nista od instalacije... Link to post Share on other sites
wice 0 Posted February 17, 2012 Report Share Posted February 17, 2012 evo ti sema povezujes samo ovaj gornji dzek chime ti je onaj zvucnik iznad papuce kvacila,treba ti senzor temperature ide u tunel iza branika, ostalo su moduli koji su iza kasete sa desne strane,,,, mada ako ces samo sat da ti radi povezi ove +eve minus, i to je to,senzor temperature kada povezes radice ti i temperatura, moze i bez gonga (chime) samo ti onda nece pistati kada temp padne ispod 3 stepena. Link to post Share on other sites
mare_ser 0 Posted February 17, 2012 Report Share Posted February 17, 2012 Hvala bate na odgovoru,probacu u ponedeljak da to sve povezem....hvala jos jednom. ;) Link to post Share on other sites
mare_ser 0 Posted February 17, 2012 Report Share Posted February 17, 2012 Hey Wice,jos jedno pitanje,ja zelim da mi bord pokazuje temperaturu,sat i da pisti kad temp. padne ispod 3 stepena....kazi mi da li u mom slucaju ima potrebe da povezujem Check Control Module, Start/Charge Sys, Blue Connector,White Connector i exterior i interior lights? Link to post Share on other sites
wice 0 Posted February 17, 2012 Report Share Posted February 17, 2012 mislim da ne mora,najlakse probaj na stolu,ali trebas povezati gong i senzor temperature sigurno i one kablove od napajanja...dosta od onih kablova je vec oziceno jer se koriste i za dvoredni bord pa zbog toga Link to post Share on other sites
bapsi70 0 Posted February 17, 2012 Report Share Posted February 17, 2012 evo ti sema povezujes samo ovaj gornji dzek chime ti je onaj zvucnik iznad papuce kvacila,treba ti senzor temperature ide u tunel iza branika, ostalo su moduli koji su iza kasete sa desne strane,,,, mada ako ces samo sat da ti radi povezi ove +eve minus, i to je to,senzor temperature kada povezes radice ti i temperatura, moze i bez gonga (chime) samo ti onda nece pistati kada temp padne ispod 3 stepena. wice ,objasni tacnije ono/u tunel iza branika/posto treba da skinem sa drugog auta Link to post Share on other sites
bapsi70 0 Posted February 17, 2012 Report Share Posted February 17, 2012 Hey Wice,jos jedno pitanje,ja zelim da mi bord pokazuje temperaturu,sat i da pisti kad temp. padne ispod 3 stepena....kazi mi da li u mom slucaju ima potrebe da povezujem Check Control Module, Start/Charge Sys, Blue Connector,White Connector i exterior i interior lights? ako nemas nikakve zice ukradi struju sa muzike tu imas i kontakt plus i stalni plus i masu a i najblize ti je Link to post Share on other sites
wice 0 Posted February 17, 2012 Report Share Posted February 17, 2012 sa leve strane pored maglenke ima tunel koji vodi vazduh od branika do potkrila za hladjenje kocnica,e u taj tunel je udzekan senzor temperature sa gornje strane Link to post Share on other sites
stojevski 0 Posted February 19, 2012 Report Share Posted February 19, 2012 ljudi sve mi je jasno samo me interesuje gde idu zice sa pina 5 i 7 na njima nepise na koi pin idu nego SPLICE neznam sta to znaci,ako moze objasnjenje bio bi zahvalan.hvala oba ta pina idu na X16 WHITE CONECTOR,ZNACI 5 I 7 SPLICE ? unapred zahvalan Link to post Share on other sites
wice 0 Posted February 19, 2012 Report Share Posted February 19, 2012 povezujes na belo ljubicastu i belo zutu na x16 konektoru iza brzinomera Link to post Share on other sites
stojevski 0 Posted February 21, 2012 Report Share Posted February 21, 2012 koji konektor ide na BELO LJUBICASTU a koji na BELO ZUTU ? Link to post Share on other sites
stojevski 0 Posted February 21, 2012 Report Share Posted February 21, 2012 i jos nesto kako da znam koji je PIN prvi a koji zadnji na X16 i X17 CONECTORU za X1070 i X1071 sam nasao na netu odakle se racuna,ali za ove neznam.ako neko zna bio bi zahvalan i da pocnem da montiram. Link to post Share on other sites
wice 0 Posted February 21, 2012 Report Share Posted February 21, 2012 druze x16 ti je beli konektor, lepo ga otvori i na njemu pise koji je koji broj na unutrasnjem dzeku Link to post Share on other sites
djole 3 0 Posted February 21, 2012 Report Share Posted February 21, 2012 Kada izvuces dzek iz table skines plastiku sa zadnjeg dela dzeka gde ulaze sve zice u dzek i tu ti je svako polje oznaceno brojem.Moguce da su neka polja slobodna,tako je bar bilo kod mene pa sam zicu direkno zabo u dzek.Nadam se da sam bio od pomoci Link to post Share on other sites
stojevski 0 Posted February 22, 2012 Report Share Posted February 22, 2012 e ako pise to je uredu,znam kako se rasklapaju konektori ali nisam znao da pise na njemu koji je koji,pa samim tim nisam hteo da se upustam u rasklapanje a da neznam. najlepse hvala,a sad samo da dodjem sa posla i ARBAJT :) Link to post Share on other sites
