vujke 0 Posted March 31, 2009 Report Share Posted March 31, 2009 desava se sledece: riknula mi lampica na instrument tabli za gorivo i nisam izvalio da vozim na rezervi, i jednu jurto ja da ga upalim i vergla , vregla i nece da upali....donesem ja 5l u kanti i sipam i opet nece....isprazni akumular popizdim....napuni ga.....mislim da je do toga da nije imao dovoljno struje,kad nije to..ima struje na bombini, u kablovima i svecice bacaju varnicu, sve sam proverio....pumpa zuji, zamenio sam mu filter, ali kad skinem dovodno crevo do dizni i kad ga verglam ne baca gorivo.... ZNA LI NEKO U CEMU JE PROBLEM?????? Link to post Share on other sites
max_power 0 Posted March 31, 2009 Report Share Posted March 31, 2009 A da izmeris pritisak na pumpi? Jel on ima bese onaj jos jedan filter goriva odmah posle rezervoara? Mozda je povukao mulj kad mu je nestalo gorivo. Link to post Share on other sites
BMW 528iA 0 Posted March 31, 2009 Report Share Posted March 31, 2009 Bar kad bih znao koji je to auto.. Link to post Share on other sites
Borko Vrsac KUM 0 Posted March 31, 2009 Report Share Posted March 31, 2009 e34 2.5 Link to post Share on other sites
BMW KLINIK 0 Posted March 31, 2009 Report Share Posted March 31, 2009 Ako si ostao bez goriva skini ventil pritiska sa palete dizni i zaverglaj mnogo ces olaksati pumpi da povuce gorivo ako i to ne pomogne skini sa plovka crevo sto ide ka motoru i u njega spricem naspi goriva i problem resen ;) Link to post Share on other sites
BMW 528iA 0 Posted March 31, 2009 Report Share Posted March 31, 2009 Zar nema na railu ventil za ispustanje zraka? Link to post Share on other sites
BMW KLINIK 0 Posted April 1, 2009 Report Share Posted April 1, 2009 Nema na e34 ventil na railu je poceo na e39 ;) Link to post Share on other sites
vujke 0 Posted April 2, 2009 Author Report Share Posted April 2, 2009 Skinuo sam onaj mali ventil na paleti dizni kao i crevo i ne dolazi gorivo dotle.... a sto se plovka tice i creva od njega sto ide do motora ....pitanje: 1. plovak stoji u gepeku? 2: crevo do motora ,prvo ide u filter pa posle filtera u motor 3. da li posle filtera postoji jos nesto do ventila na paleti dizni... HVALA Link to post Share on other sites
BMW 528iA 0 Posted April 2, 2009 Report Share Posted April 2, 2009 Jesi ocistio filter? Link to post Share on other sites
max_power 0 Posted April 2, 2009 Report Share Posted April 2, 2009 A ima on i onaj regulator pritiska, ja imam dizela, drugar ima benzinca, rasturali smo nesto par puta pa nisam siguran, ali cini mi se da ima onaj regulator pritiska otvara nesto na 3 bara.... da nije to? A uzmi proveravaj redom. Vidi prvo jel vuce gorivo pumpa iz rezervoara. Link to post Share on other sites
vujke 0 Posted April 3, 2009 Author Report Share Posted April 3, 2009 hvala svima ali nasao sam kvar pumpa ne vuce uopste majku joj ...ona zuji ali nista.....sta da radim?? Link to post Share on other sites
BMW 528iA 0 Posted April 3, 2009 Report Share Posted April 3, 2009 Izvadi je prvo pa pogledaj. Link to post Share on other sites
vujke 0 Posted April 3, 2009 Author Report Share Posted April 3, 2009 ma riknula je skroz sam je izvadio ...nema vakum....nemoze da povuce gorivo....pokusacu da premostim plus i minus da je tako malo precistim ali znam da to nije resenje.... Link to post Share on other sites
max_power 0 Posted April 3, 2009 Report Share Posted April 3, 2009 Rekoh ti ja na pocetku gore, izmeri prvo pritisak. Tako ces prvo da vidis o cemu se radi. Link to post Share on other sites
vujke 0 Posted April 3, 2009 Author Report Share Posted April 3, 2009 znam znam hvala na tome.... Link to post Share on other sites
vujke 0 Posted April 3, 2009 Author Report Share Posted April 3, 2009 e ovo sam skroz zaboravio da pitam....znam da plin nema veze sa gorivom niti pumpom ali nece ni na plin da mi upali....sto??? Link to post Share on other sites
BMW 528iA 0 Posted April 3, 2009 Report Share Posted April 3, 2009 Kako si ga prije palio? Direktno na plin? Link to post Share on other sites
vujke 0 Posted April 4, 2009 Author Report Share Posted April 4, 2009 kad ga palim na plim preko tastera on prvo upali na benzin pa prebaci na plin posle 1500 obrtaja a direktno pali kad mu ja zicom spojim plavu i crvenu..to radim kad izvadim dzek iz tastera da li pase pumpa na moj od e36 ima je goxxy, oce da mi proda...??????????? Link to post Share on other sites
BMW 528iA 0 Posted April 4, 2009 Report Share Posted April 4, 2009 Ja mislim da nisu iste, tj. nemaju isti pritisak. Link to post Share on other sites
vujke 0 Posted April 4, 2009 Author Report Share Posted April 4, 2009 pa ja mislim da je kod mene 3 bara a jel bi mogao ja jace da stavim? Link to post Share on other sites
