leon63 0 Posted July 13, 2009 Report Share Posted July 13, 2009 Posto je dosta ljudi radilo ubacivanje dvorednog bord kompjutera u e36, dajem pregled svih funcija koje isti poseduje. Iste se startuju istovremenim pritiskom na brojeve 1000 i 10, a zatim kada se pojavi natpis na displeju TEST Nr. ukucate broj 1 i tako redom dok ne ispitate sve funcije Test Code No. Display Notes Display Must Be Unlocked First? 01 All LED display elements are lit Verify that the display is working properly No 02 VBR: n,n l/100km n,n = instantaneous fuel usage in liters/100 km Yes 03 VBR: n,n l/h n,n = instantaneous fuel usage in liters per hour Yes 04 RW-VBR: n,n l/100 n,n = average fuel usage in liter/100 km. Yes 05 RW: nnn km nnn = range in km Yes 06 -- Not used Yes 07 TMTL: nn,n nn,n = fuel remaining (in liters) Yes 08 V: n km/h n = instantaneous speed in km/h Yes 09 UB: nn,nn V nn,nn = system voltage (should be around 13,80) Yes 10 LAND: n xxx * Country code -- for US drivers should be set to 2 description below No 11 EINHEIT n: xx * ?? There are two EINHEIT displays: the values for xx in EINHEIT 1 can range between B0 and BF, and for EINHEIT 2 range between 0F and FF (mine is set to B3 and FF, respectively). Press the 1000 or 100 key to switch between EINHEIT 1 and EINHEIT 2. Yes 12 VANK nn km/h nn = average speed Yes 13 ANK: nn:nn nn:nn = ETA (will display --:-- if the OBC's distance function is not in use) Yes 14 ROM: dd.mm.yy dd.mm.yyyy = Software version date. Mine is 25.06.1991 No 15 DIAG: nn nn nnn xx Diagnosis code? Mine is 01 05 255 FA Yes 16 PORT: nn nnnnnnnn Port codes? Press 1000 or 100 key to cycle port numbers. For example, PORT 01 is 10101000 Yes 17 PROM: nn nn ?? Mine reads 00 12 Yes 18 HORN: xxxx DTON or DTOFF? (Single tone horn versus dual tone) Yes 19 LOCK: xx xx = ON or OFF. See description abovefor method. No 20 KVBR: nnnn nnnn = Fuel rate calibration factor. Mine is set to 1000 Yes 21 RESET? Reset all defect codes? Also erases all stored values in the OBC (i.e, fuel consumption, avg. speed, timer, etc) and clock. Y Evo ga i link koji sve objasnjava http://delauer328.iespana.es/OBC/OBC_2.pdf Link to post Share on other sites
crnizmaj 0 Posted July 20, 2009 Report Share Posted July 20, 2009 da bi sve funcije radile, treba prvo ici u funciju 19 Link to post Share on other sites
