MladenR 0 Posted February 8, 2017 Report Share Posted February 8, 2017 Čitao sam po netu da na e46 otpada zadnji most od sasije. Otkine ga motor, slabo je urađeno. Da li ti imas mozda problema s time? Link to post Share on other sites
Desmo 0 Posted February 9, 2017 Report Share Posted February 9, 2017 Ako ne pukne radilica onda otpadne zadnji most Link to post Share on other sites
pop003 0 Posted February 10, 2017 Author Report Share Posted February 10, 2017 axaxaxaxa e 46 je poznat po meksoj skoljci ja za sada nemam proglema sa tim ali bilo je da sam vidio slucajeva da se cjepa po traverzni prednjoj pogotovo gdje su ramena ali i to kako se kome strefi ja sam na 19" tockove i sa sperom pa evo nemam problem sa tim Link to post Share on other sites
pop003 0 Posted February 10, 2017 Author Report Share Posted February 10, 2017 sinoc je pocet motor napokon da se sastavlja bice slika danas Link to post Share on other sites
pop003 0 Posted February 10, 2017 Author Report Share Posted February 10, 2017 danas mo ja , Torque , Zaka majstor i Sasa Smolovic zabavljali oko motora ubaceni kovani lezajevi KING RACING ima da pumpamo do 2 bara bez problema axaxaxaxaxaxaxa a nove karike naravno razlika izmedju starog klipa (crnog) i novog Link to post Share on other sites
pop003 0 Posted February 10, 2017 Author Report Share Posted February 10, 2017 prvi dihtung glave dekompresiona ploca nerdjajuci celik pa ponovo dihtung glave slag na tortu bregastEEEEEEE Link to post Share on other sites
castor 0 Posted February 10, 2017 Report Share Posted February 10, 2017 Ružna ti boja motora... K'o ona za cijevi za dimnjak... Link to post Share on other sites
pop003 0 Posted February 10, 2017 Author Report Share Posted February 10, 2017 axaxaxaxax Link to post Share on other sites
castor 0 Posted February 10, 2017 Report Share Posted February 10, 2017 Nemoj ti to da pakuješ u karoseriju dok ne obgori malo... Hahahahah Link to post Share on other sites
pop003 0 Posted February 10, 2017 Author Report Share Posted February 10, 2017 nadimicemo ga brenerom prije ubacanja axaxaxasa Link to post Share on other sites
castor 0 Posted February 11, 2017 Report Share Posted February 11, 2017 I obavezno vatricu ispod da podložiš... Ahahahahahaha Link to post Share on other sites
pop003 0 Posted February 11, 2017 Author Report Share Posted February 11, 2017 nocas sklopljen motor ima jos da se malo radi oko turba i da se ubaca u auto , pa se sva crijeva spoje sve upasuje dovedu dovodi za intercoler za hladnjak ulja za dovod ula turbine da vodu za hladjenje turbine ali bice sve realizovano u ovome mjesecu pa ide na lakiranje Link to post Share on other sites
pop003 0 Posted February 11, 2017 Author Report Share Posted February 11, 2017 Link to post Share on other sites
pop003 0 Posted February 11, 2017 Author Report Share Posted February 11, 2017 sutra pocinjemo sa pravljenjem usisne grane metalne sa velikom klapnom Link to post Share on other sites
pomoravac 0 Posted February 11, 2017 Report Share Posted February 11, 2017 Lepota jedna.... Link to post Share on other sites
pop003 0 Posted February 16, 2017 Author Report Share Posted February 16, 2017 Link to post Share on other sites
pop003 0 Posted February 20, 2017 Author Report Share Posted February 20, 2017 jos malo pa gotovi ??? Link to post Share on other sites
pop003 0 Posted February 22, 2017 Author Report Share Posted February 22, 2017 za nocas dosta posla uradjeno glavni dio usisne grane napravljen ostaju sada finese da se urade Link to post Share on other sites
pop003 0 Posted February 24, 2017 Author Report Share Posted February 24, 2017 sto je pikovano bilo sada je sve zavareno a i usisna se vari danas sutra ce biti 80 posto nje gotovo poliranje ce se sutra raditi ostaje samo da se stave utore za dizne i nosaci magistrale Link to post Share on other sites
pop003 0 Posted February 25, 2017 Author Report Share Posted February 25, 2017 dio po dio se slaze Link to post Share on other sites
pomoravac 0 Posted February 25, 2017 Report Share Posted February 25, 2017 Kakav je plan razrade ovakvog motora kad se sastavi? Prva zamena ulja i lagana voznja do koliko kilometara itd.... Link to post Share on other sites
AcoNik 0 Posted February 25, 2017 Report Share Posted February 25, 2017 Kakva razrada, odma' pun gas Jel tako Pop Link to post Share on other sites
pop003 0 Posted February 25, 2017 Author Report Share Posted February 25, 2017 pa prvih 500 km ce mo polako nema velikih obrtaja i na 500 km mjenjanje ulja i onda jos 500 polako bez visokih obrtaja mjenjanje ulja na 1000 km i onda mozemo da ga postepeno bucamo neko kaze da se odma moze bucati ali necu da gatam nije mi trka neka da ga stiskam odma neka se razradi za svaki slucaj Link to post Share on other sites
pop003 0 Posted March 18, 2017 Author Report Share Posted March 18, 2017 Link to post Share on other sites
