zoki04 0 Posted August 27, 2010 Report Share Posted August 27, 2010 Znaci treba mi obc za e34 m50 motronic bosch zadnji seriski broj je 405. HITNO!!! Ako neko od prijatelja iz kluba ima zelju i vremena da se nadjemo i da probam taj obc ili ako neko ima na prodaju jer je moj izgleda crko. Hvala unapred!!! Link to post Share on other sites
hermes 0 Posted August 27, 2010 Report Share Posted August 27, 2010 Zovi me sutra Link to post Share on other sites
zoki04 0 Posted August 28, 2010 Author Report Share Posted August 28, 2010 Ok samo jos da njadjem broj!! Link to post Share on other sites
CasperBg82 0 Posted August 28, 2010 Report Share Posted August 28, 2010 Toma 064/1183628 Link to post Share on other sites
zoki04 0 Posted August 29, 2010 Author Report Share Posted August 29, 2010 Dzabe, iako je Toma bio dobre volje njegov obc je simens tako da nismo nista napravili. I dalje aktuelno, treba mi bord!!! Link to post Share on other sites
zoki04 0 Posted August 30, 2010 Author Report Share Posted August 30, 2010 Mala ispravka. Treba mi ECU a ne OBC. Malo brkam pojmove ;) :) Link to post Share on other sites
CasperBg82 0 Posted August 30, 2010 Report Share Posted August 30, 2010 Zovni Zorana, ima dosta delova za E34, pa pitaj http://www.bmwclubserbia.com/forum/index.php?showtopic=13240 Link to post Share on other sites
zoki04 0 Posted September 2, 2010 Author Report Share Posted September 2, 2010 Hvala Kaspere ali problem resen!!!! Dojadilo mi da se majem po radionicama i kojekakvih majstora i za vikend mi pukne film i pocnem sam da rasturam jedno po jedno. I sta zateknem, pokidano donje crevo od ICV-a!!! (majstori kazu otiso ti ECU!!!). Odem kod Dekija na otpad uzmem crevo za 300dim. namestim i auto prede ko macka. Pa posle sto se jezim kad treba da idem kod majstora (verovatno zato sto samo sede za laptopom i klikcu misem i crklo ti ovo ili ono). O majstori, majstori! Link to post Share on other sites
zoki04 0 Posted September 2, 2010 Author Report Share Posted September 2, 2010 A da, zaboravio sam da se zahvalim Zokiju i Mirku na savetima. Oni su mi odmah sugerisali na fals vazduh, pa sam se zato i bacio na skidanje jedno po jedno. HVALA VAM JOS JEDNOM!!!!!!!!!!!!!!!!!!!! :rolleyes: :) :) Link to post Share on other sites
hermes 0 Posted September 2, 2010 Report Share Posted September 2, 2010 Sad posle bitke svi smo generali, ali vidi ko ti je prvi rekao sta ti je na autu:) http://www.bmwclubserbia.com/forum/index.php?showtopic=13320 Link to post Share on other sites
Nidza crveni 0 Posted September 2, 2010 Report Share Posted September 2, 2010 Hvala Kaspere ali problem resen!!!!Dojadilo mi da se majem po radionicama i kojekakvih majstora i za vikend mi pukne film i pocnem sam da rasturam jedno po jedno. I sta zateknem, pokidano donje crevo od ICV-a!!! (majstori kazu otiso ti ECU!!!). Odem kod Dekija na otpad uzmem crevo za 300dim. namestim i auto prede ko macka. Pa posle sto se jezim kad treba da idem kod majstora (verovatno zato sto samo sede za laptopom i klikcu misem i crklo ti ovo ili ono). O majstori, majstori! E sad da vodis kod Brke a ne da kukas ko zena! Link to post Share on other sites
zoki04 0 Posted September 3, 2010 Author Report Share Posted September 3, 2010 Ma vodim gde hoces, samo jos da mi kazes ko je Brka? Predpostavljam neka kafana?! :rolleyes: Link to post Share on other sites
