DangaraBMW 0 Posted October 20, 2010 Report Share Posted October 20, 2010 Imam jedno pitanje...prije nekoliko dana mi je Vlada v6 poslao plave zadnje H&R opruge...e,pitao bih vas koje opruge da stavim naprijed?...a da mi auto bude iste visine i da se dobro ponasha na putu...hvala... Link to post Share on other sites
CasperBg82 0 Posted October 20, 2010 Report Share Posted October 20, 2010 Valjda isto plave :prankster2: Moze i crvene ;) Link to post Share on other sites
DangaraBMW 0 Posted October 20, 2010 Author Report Share Posted October 20, 2010 Visina naprijed zavisi i od motora koji je u autu,kod mene je 318i m10...tako da ne znam koje da stavim...kako je kod tebe Casper? Link to post Share on other sites
CasperBg82 0 Posted October 20, 2010 Report Share Posted October 20, 2010 Meni je onaj Goran sredio fabricke, secnuo ih malo i gotovo :D Ali sam spustio samo oko 30-40 mm, ako ces vise onda treba da nadjes te sportske Link to post Share on other sites
DangaraBMW 0 Posted October 20, 2010 Author Report Share Posted October 20, 2010 I meni su naprijed fabricke,ali su isto secnute,ali mi je sad u odnosu na zadnji kraj nisko,pa sam mislio da stavim sportske H&R ili Eibach,ali ne znam koje da uparim sa zadnjim... Link to post Share on other sites
CasperBg82 0 Posted October 20, 2010 Report Share Posted October 20, 2010 Ne razumem sad, jel tebi sad sa tim oprugama sto si uzeo auto pozadi visi nego pre? Link to post Share on other sites
DangaraBMW 0 Posted October 20, 2010 Author Report Share Posted October 20, 2010 Ista je visina,imao sam i pozadi fabrichke opruge,ali su bile ugrijane i malo sabijene i zamijenio ih ovim plavim...i prije mi je auto bilo nize naprijed,a to me je nerviralo...sad bih da izjednachim visinu sa zadnjim dijelom... Link to post Share on other sites
CasperBg82 0 Posted October 20, 2010 Report Share Posted October 20, 2010 Ajde sad da ti nacrtam nesto :prankster2: Vidis ovu liniju sto ide od fara duz krila, preko vrata (kvake) pa pozadi do stop svetla? Pogledaj sad koliko je prednji rub udaljen od nje a koliko zadnji...? Sta mislis da izjednacis, i sa jednakom visinom na oprugama i dalje ce biti poboden To tako mora da bude, ako hoces ladu onda kupi ladu, a za bmw ne uzimaj vaser-vagu ;) Link to post Share on other sites
StunterSM 0 Posted October 20, 2010 Report Share Posted October 20, 2010 Ako hoces pod konac da na oko stoji meri razdaljinu od gume do ruba.. Link to post Share on other sites
CasperBg82 0 Posted October 20, 2010 Report Share Posted October 20, 2010 Po slikama bi se reklo da sad lepo stoji, tj da je stajao, otprilike je jednaka razdaljina.. Mozda mu smeta zbog dzombi, jbg planina je to ;) Link to post Share on other sites
DangaraBMW 0 Posted October 20, 2010 Author Report Share Posted October 20, 2010 Neka Casper,e cu djedu trazit' neku pushku pa ti dolazim tamo :)...gledam po pragu i vidi se da nije jednak...od felne do ruba je 11.5cm naprijed 13.5cm nazad... Link to post Share on other sites
BMWscaner 0 Posted October 20, 2010 Report Share Posted October 20, 2010 kad guma udje pod rub onda znas da si podjednako spustio i prednji i zadnji kraj :) Link to post Share on other sites
CasperBg82 0 Posted October 20, 2010 Report Share Posted October 20, 2010 Pusti to, izmeri ti sto ti rece Miki da bude jednako izmedju gume i ruba Znam ja kako je tamo, peo sam se kockicom do ispod Komova, ostavio auto pod rucnom on skliznuo po travi :D Link to post Share on other sites
DangaraBMW 0 Posted October 20, 2010 Author Report Share Posted October 20, 2010 Auu,Komovi su zlo :)...nije to meni na autu nishta strashno ali mene malkice nervira...nego reko' kad sam vec stavio pozadi sportske,da stavim i naprijed...da mi ne budu sjecene naprijed...i htjedoh da pitam,ako je neko stavljao plave nazad,koje idu naprijed... Link to post Share on other sites
DangaraBMW 0 Posted October 20, 2010 Author Report Share Posted October 20, 2010 kad guma udje pod rub onda znas da si podjednako spustio i prednji i zadnji kraj :) :D...e,onda bih svaki dan novi karter kupovao...:) Link to post Share on other sites
StunterSM 0 Posted October 20, 2010 Report Share Posted October 20, 2010 Kod mene, jeste da je e36, su napred plave nazad crvene i ravan je ko strela :D Link to post Share on other sites
DangaraBMW 0 Posted October 20, 2010 Author Report Share Posted October 20, 2010 Kod mene, jeste da je e36, su napred plave nazad crvene i ravan je ko strela :D ...i prelijep :)... Link to post Share on other sites
StunterSM 0 Posted October 20, 2010 Report Share Posted October 20, 2010 Tek ce da bude ;) Na prolece farbanje, vraceni fabricki farovi sa xenonima,cekam babica na krugove, berbet type e poliran 8+9.5J, M enterijer stavljen ssa grejacima, 2x12" 600W muzika, gewinde i tako dalje.... Bice nesto od njega :) Link to post Share on other sites
DangaraBMW 0 Posted October 20, 2010 Author Report Share Posted October 20, 2010 Tek ce da bude ;) Na prolece farbanje, vraceni fabricki farovi sa xenonima,cekam babica na krugove, berbet type e poliran 8+9.5J, M enterijer stavljen ssa grejacima, 2x12" 600W muzika, gewinde i tako dalje.... Bice nesto od njega :) Opaaaa...bice k'o Bog :)...samo nek' je sa srecom...planiram i ja na proljece sredjivanje...pa cemo vidjet' ciji je ljepshi :)...salim se...lutka ti je auto,stvarno,a sa 9.5J pozadi ce izgledati pakleno... Link to post Share on other sites
DangaraBMW 0 Posted October 20, 2010 Author Report Share Posted October 20, 2010 Eto,ako je neko stavljao plave pozadi na kocku,treba mi samo da znam koje je stavljao naprijed...samo mi to treba momci... Link to post Share on other sites
