Strahinja75 0 Posted December 19, 2010 Report Share Posted December 19, 2010 Pozdrav drugari, Imam E39 1996 godiste 2.0I i danas me odao zbog pokazivaca goriva.Naime strelica je pokazivala 15+ litara u rezervoaru , a auto je ostao bez goriva. Kako to da sredim i gde? Hvala svima unapred !! Link to post Share on other sites
alkonibmw 0 Posted December 19, 2010 Report Share Posted December 19, 2010 Isti problem imam i ja.. Kada sam zamenio pumpu, malo posle toga, pokazuje da ima, malo vise od 15l i auto nema goriva, uzas.. Ne smem da se opustim pa mu na svakih 4/5 dana sipam 10tku.. jbg. Ako neko zna u cemu je rec, neka nam pomogne.. Ja sumnjam da je reostat u rezervoaru.. ali ako neko zna o cemu je problem, neka nam pise.. Link to post Share on other sites
Strahinja75 0 Posted December 19, 2010 Author Report Share Posted December 19, 2010 Ma danas me ostavi u nedodjiji na putu za Vrsac, a i klince mi bilo u kolima.Uzas. Pesacio 4 km do pumpe na - 6. Link to post Share on other sites
alkonibmw 0 Posted December 19, 2010 Report Share Posted December 19, 2010 E do djavola, to je sranje, bas si se izmaltretirao. Verujem da ti je doslo da ga pospes i zapalis.. ali to je trajalo par sekundi, cim se zavalio u njega posle sipanja goriva, sve si zaboravio.. :preved: Salu na stranu, daj da resavamo ovo nekako, cekam ako se neko sa slicnim iskustvom javi, dobro ce nam doci. Link to post Share on other sites
Strahinja75 0 Posted December 19, 2010 Author Report Share Posted December 19, 2010 Vidim da su neki cistili senzor na plovku ...sa WD 40.Jesi ti to probao? Link to post Share on other sites
alkonibmw 0 Posted December 19, 2010 Report Share Posted December 19, 2010 Nisam to probao, ja sam cistio samo dzek gde se usteka.. Kod e34 je to malo drugacije. U gepeku mu se nalazi pumpa, pa sam tu cistio kontakte i proradilo je.. E sada za e39tku nisam to probao a ni taj senzor da ocistim sto si pomenuo.. Link to post Share on other sites
Strahinja75 0 Posted December 22, 2010 Author Report Share Posted December 22, 2010 Resio problem, evo kako. Voziti auto dok ne ostane bez goriva.Znaci sad nema u sebi ni da upali.Skinuti instrument tablu....ostaviti je na kontaktima.Ukljucite kontakt, ako se kazaljka pomeri sa 0 vratite je prstom nazad.Iskljucite sa kontakta.......posle jos par puta ukljucite kontakt da budete sigurni da se kazaljka nece pomeriti. Ok, sad sipajte tacno 15L (Ja sam to iz kanti jer sljam sa pumpe mnogo krade).Ukljucite kontakt.....gde je kazaljka?Ako je na 15 Ok...ako nije opet prstom nezno pomerite kazaljku na tacno 15L.Ugasite kontakt.....pa upalite jos par puta.Ako se nije nista promenilo uzmite jos 15l i sipajte.Ista procedura kao i u prethodnom slucaju. To je to. Naravno, ovo je sve radjeno nakon ciscenja "konektora" na pumpi, oba senzora na plovcima..ili sta je vec.NIKAKO ali NIKAKO ne koristiti WD 40 vec neki "Elektro konektor" ...ima ih u sprejevima oko 400 din su. Ja sam auto napunio do kraja,potrosnja mi je oko 11l ....evo presao 230km ....kazaljka lepo radi.Cak ako ga parkirate na nizbrdici ...kad se pomerite vraca kazaljku na originalno mesto.. Javicu ako bude bilo nekih promena. Pozdravljam !! Link to post Share on other sites
Strahinja75 0 Posted December 27, 2010 Author Report Share Posted December 27, 2010 Danas se upalila lampica za gorivo.Sipao 30l, evo stoji lepo na sredini. Link to post Share on other sites
alkonibmw 0 Posted December 27, 2010 Report Share Posted December 27, 2010 Ja cu to morari ovih dana da odradim, ne vredi, nervira me kada stoji non stop na 20l. A reci mi, te konektore, to si unutar rezervoara prskao? Link to post Share on other sites
Strahinja75 0 Posted December 28, 2010 Author Report Share Posted December 28, 2010 Ja cu to morari ovih dana da odradim, ne vredi, nervira me kada stoji non stop na 20l. A reci mi, te konektore, to si unutar rezervoara prskao? Ma da ....posto imas dva plovka videces dzekove(nesto kao neku elektroniku....boga pitaj :preved: sta je) ....to sam ja isprskao ali sa ELEKTRO Konektorskim sprejem...imas za 400 din nacrtana je svecica na njemu.Naglasio mi je majstor da nikako ne cistim sa WD 40 jer ga on umasti...i nije za to. Link to post Share on other sites
Strahinja75 0 Posted December 31, 2010 Author Report Share Posted December 31, 2010 Evo opet zakuca na 15l ...ufffff ovo postaje frustrirajuce. Link to post Share on other sites
alkonibmw 0 Posted December 31, 2010 Report Share Posted December 31, 2010 Znaci opet ista "pesma" ? Da se ne zajebavam i da skidam? Link to post Share on other sites
