sladjanbekonja 0 Posted April 26, 2011 Report Share Posted April 26, 2011 pomoc!vozim na plin(sekvent)al mi pre dva dana nece da upali na benzin i necue se pumpa pri davanju kontakta vodio sam racuna da mi se nepali rezerva al se par puta upalila jel zveknula il treba da proverim jos nesto neki osigurac,relej il sta vec i ako da de da proveravam?hvala :mellow: :angry: Link to post Share on other sites
777.boban 0 Posted April 26, 2011 Report Share Posted April 26, 2011 Pa neces ni da cujes pumpu na kontaktu,ona se pali kad pocnes da verglas,proveri osigurac,ali ako dugo nije radila hoce da zvekne. Link to post Share on other sites
marudza 0 Posted April 26, 2011 Report Share Posted April 26, 2011 izvadis pumpu,zaverglas,ako ne zuji zakacis test lampu na dzek od pumpe pa zaverglas opet,ako upali lampu,znaci da je pumpa riknula,a ako ne upali onda je verovatno osigurac ili relej,oni su ti pod haubom,ispred volana u crnoj kutiji... Link to post Share on other sites
sladjanbekonja 0 Posted April 26, 2011 Author Report Share Posted April 26, 2011 stalno sam palio na benzin i s vremena na vreme provozam na isti samo odjedanput nisam mogao da upalim.izvadicu je da vidim sta se desava.jel moze da se servisira ako je ona u pitanju il mora druga? Link to post Share on other sites
vranjin 0 Posted April 26, 2011 Report Share Posted April 26, 2011 Nema tu servisiranja, druga pumpa. ovde se pricalo o pumpi http://www.bmwclubserbia.com/forum/index.php?showtopic=16421 Link to post Share on other sites
