Ljilja 0 Posted January 27, 2008 Report Share Posted January 27, 2008 Juce sipala gorivo...nikad nemam manje od 10lit... Sada cujem neko kao priguseno zujanje, konstantno, nekad malo varira zujanje u zavisnosti od promene obrtaja...zuji stalno, i na leru i na gasu i na kvacilu i u pokretu i u mestu...Broj obrtaja se povecao kad je hladan motor oko 1400 posle padne na 1000-900(do sada hladan i na snegu bilo 1000-900). Nemam problem sa paljenjem, nema trzanja, nema zastajkivanja. Citala sam postove o pumpi za gorivo. Jel imate jos neku ideju sta je problem? I...gde na dijagnosticiranje? Link to post Share on other sites
smfilip 0 Posted January 27, 2008 Report Share Posted January 27, 2008 naspi jos goriva,ali vidi neko kvalitetnije,pa ako i dalje zuji,pravo kod nekog da pregleda pumpu Link to post Share on other sites
motorsport 0 Posted January 28, 2008 Report Share Posted January 28, 2008 pumpu obavezno pregledaj.... citala si vjerovatno kako ja prodjoh sto se pumpe tice... Link to post Share on other sites
eros 0 Posted January 28, 2008 Report Share Posted January 28, 2008 pumpa pri kraju ali ne brini moze jos duuuugo da se vozi Link to post Share on other sites
Dzoni 2,7 turbo 0 Posted January 28, 2008 Report Share Posted January 28, 2008 Pumpa....kod mene zuji vec 2 godine al to ne znaci da treba i tebi oko 50e kosta da se pumpa otvori i ocisti... :) Link to post Share on other sites
motorsport 0 Posted January 28, 2008 Report Share Posted January 28, 2008 ova moja se ne moze otvorit, hermeticki je zapakovana... Link to post Share on other sites
Miško 0 Posted January 28, 2008 Report Share Posted January 28, 2008 ova moja se ne moze otvorit, hermeticki je zapakovana... kao i na 524 td ako nekog bude zezala da se ne gnjavi sa otvaranjem već odmah u đubre Link to post Share on other sites
Nidza 3.. 0 Posted January 28, 2008 Report Share Posted January 28, 2008 samo teraj dok nepocne da pravi problem,moze tako duuugo,a moze i kratko...nema pravila :unsure: Link to post Share on other sites
motorsport 0 Posted January 28, 2008 Report Share Posted January 28, 2008 al kupi jednu rezervnu za svaki slucaj, da te ne ostavi gdje na putu kao sto je mene... Link to post Share on other sites
bmwpower 0 Posted January 28, 2008 Report Share Posted January 28, 2008 Komarac u kabini! Link to post Share on other sites
100le 0 Posted January 28, 2008 Report Share Posted January 28, 2008 za pumpu su smrt voda u gorivu i vazduh ako vuče, zujanje... znači dobila si opomenu. pregledaj rezervoar, šelne i očisti sita i mrežice ako ih ima pa naspi dobro gorivo i cepaj Link to post Share on other sites
Ljilja 0 Posted February 6, 2008 Author Report Share Posted February 6, 2008 Kakva glupost...izvadila sam sedista...i kazu mi da se zato cuje zujanje pumpe Link to post Share on other sites
gagy80 0 Posted February 6, 2008 Report Share Posted February 6, 2008 ja sam svoju pupu sam sredio,i ako je hemeticki zatvorena!sve moze! ne brini moja tako zuji od uvek,najmanje 3 godine! Link to post Share on other sites
motorsport 0 Posted February 6, 2008 Report Share Posted February 6, 2008 hehe, sto si vadila sjedista??? pa pumpa se mora cut kad se digne sjediste Link to post Share on other sites
Iga 0 Posted February 6, 2008 Report Share Posted February 6, 2008 To se resava prosto....pojacas mjuzzzzz Link to post Share on other sites
Ljilja 0 Posted February 7, 2008 Author Report Share Posted February 7, 2008 Ma da, izbacila sva sedista osim svog zbog tapaciranja, zato se i cuje zujanje pumpe i jos stosta ..kao u praznom stanu kad sve odjekuje...dobro je Link to post Share on other sites
BMW E36 POWER 0 Posted February 8, 2008 Report Share Posted February 8, 2008 hm...dobro si prosla... Link to post Share on other sites
gagy80 0 Posted February 8, 2008 Report Share Posted February 8, 2008 Odlicno resenje problema! B) Link to post Share on other sites
Miki s38 0 Posted February 8, 2008 Report Share Posted February 8, 2008 Hahaha vracaj sedista i reseno zujanje Link to post Share on other sites
