nemanjaz 0 Posted December 30, 2011 Report Share Posted December 30, 2011 (edited) Da li neko zna ima li ikakve veze ako je iz lonca na auspuhu izvadjeno sve mislim ako je sve prazno i napravljeno da se glasnije cuje ima li to kakve veze sa vucom auta posto mi slabo vuce nemam nekog starta sve je usporeno. upitanju je BMW E32 730i Edited December 31, 2011 by nemanjaz Link to post Share on other sites
BMW520ibgd 0 Posted December 31, 2011 Report Share Posted December 31, 2011 Jel imas katalizator?? Link to post Share on other sites
nemanjaz 0 Posted December 31, 2011 Author Report Share Posted December 31, 2011 Jel imas katalizator?? Drug nisam ni gledao ima li katalizator kupio sam ga pre 2 dana Link to post Share on other sites
Guest maxa2485 Posted December 31, 2011 Report Share Posted December 31, 2011 dodji kod mene da to sredimo sto nece da ide pa da vidimo kako ce onda ici,ako si iz bg Link to post Share on other sites
nemanjaz 0 Posted December 31, 2011 Author Report Share Posted December 31, 2011 dodji kod mene da to sredimo sto nece da ide pa da vidimo kako ce onda ici,ako si iz bg nisam drug iz BG ja sam iz Republike Srpske-Banja Luka Link to post Share on other sites
Guest maxa2485 Posted December 31, 2011 Report Share Posted December 31, 2011 onda par sveta otkaci protokomer i proba,ako je ok ti vrati,otkaci lambda sondu ako je ok vrati za sada Link to post Share on other sites
nemanjaz 0 Posted December 31, 2011 Author Report Share Posted December 31, 2011 onda par sveta otkaci protokomer i proba,ako je ok ti vrati,otkaci lambda sondu ako je ok vrati za sada Ok drug sutra cu to probati kad se otreznim pa cu javiti jesam li sta napravio Link to post Share on other sites
Guest maxa2485 Posted December 31, 2011 Report Share Posted December 31, 2011 zna protokomer da to pravi pre a i bez katalizatora i sonde on extra ide to je 6tak,ja vozim v8 4.0 i za sada nemam problema Link to post Share on other sites
nemanjaz 0 Posted December 31, 2011 Author Report Share Posted December 31, 2011 zna protokomer da to pravi pre a i bez katalizatora i sonde on extra ide to je 6tak,ja vozim v8 4.0 i za sada nemam problema brobacu pa javljam rezultate.hvala Link to post Share on other sites
nemanjaz 0 Posted January 29, 2012 Author Report Share Posted January 29, 2012 brobacu pa javljam rezultate.hvala Pozdrav raja jos uvek nisam resio problem oko vuce isao sam na diagnostiku i nema ni jedne greske sve je uredu. Proveravao kompresiju i ona je OK Svecice OK Sonda OK Katalizator nema ali neverujem da je do njega I na benzin i plin radi isto Kod mene gas neide preko sajle e da nije nesto do toga,ubacen je noviji motor od 92god Auto ide normalno vozio sam ga 200 km/h samo nema skripe i naglog starta,zestokog ubrzavanja Ima li neko ideju sta bi moglo da bude Link to post Share on other sites
777.boban 0 Posted January 30, 2012 Report Share Posted January 30, 2012 Taj auto ne moze bolje ni da ide.Da bi zavrteo moras posteno da ga nagasiras. Proveri samo da ti nije redukovan usis vazduha zbog plina. Link to post Share on other sites
nemanjaz 0 Posted January 30, 2012 Author Report Share Posted January 30, 2012 Taj auto ne moze bolje ni da ide.Da bi zavrteo moras posteno da ga nagasiras. Proveri samo da ti nije redukovan usis vazduha zbog plina. Kod mene je automatik,kako mislis da nije redukovan usis vazduha zbog plina? Link to post Share on other sites
StunterSM 0 Posted January 30, 2012 Report Share Posted January 30, 2012 eto resenja, automatik :) Link to post Share on other sites
777.boban 0 Posted January 30, 2012 Report Share Posted January 30, 2012 Kod mene je automatik,kako mislis da nije redukovan usis vazduha zbog plina? PA obicno nadri majstori kad nemogu da usteluju gas nabiju nesto na usis da bi smanjili protok vazduha i omogucili da auto radi na gas,onda ga uguse na benzinu jer nema dovoljno vazduha i automatski slabije ide. A posto kazes da je automatic onda od njega i nemozes da ocekujes neki start. Link to post Share on other sites
