Sicko 0 Posted January 5, 2012 Report Share Posted January 5, 2012 E ovako radi se o e39ki 2001 godiste. Do sad sam imao ovaj kasetas u autu Rec je o Becker-ovom BMW Business C53 modelu ima ovakve konektore Nabavio sam Philips-ov dek BMW Business, takodje od restajla Ima isti konektor pozadi I MID koji ide uz njega Blaupunkt-werke Sa konektorom I odgovarajucim konektorom i kablicem E sad to je doslo od auta sa High instrument tablom (bez autica) a ja imam Low instrument tablu (sa auticem). Bord kompjuter me ne interesuje (dovoljan mi je autic), vec me interesuje gde na staroj instalaciji da prikacim ovaj kabli za MID da bi sljakao (radio. sanzer, dek). Jel ima neko raspored pinova na konektoru za Mid. Zice su ovako rasporedjene 1 Braon-crna debla zica(verovatno masa) 2 Crveno-crna deblja zica(verovatno struja) 3 Sivo-crvena (?) 4 Belo-siva (sa zutim sarama) (?) 5 / 6 / 7 / 8 Braon-ljubicasta (?) 9 / 10 / 11 / 12 / Za konektor na dec-ku imam raspored pinova (evo linka) Gledaju se BMW models after 2000 http://www.tehnomagazin.com/Auto-radio-car-connector/BMW-Car-Radio-Wiring-Connector.htm Znaci gde prikaciti slobodne zice sa MIDA da bi funkcionisao radio, kasetas, sanzer. Bord ne jer treba ozbiljniji zahvat. Izvinite na dugom postu i unapred hvala. ;) Link to post Share on other sites
StunterSM 0 Posted January 5, 2012 Report Share Posted January 5, 2012 sto nisi pitao deda mraza, sad prosla nova godina.. <_< :P Link to post Share on other sites
Sicko 0 Posted January 5, 2012 Author Report Share Posted January 5, 2012 JBG Uhvatio me na spavanju... Link to post Share on other sites
Sicko 0 Posted January 5, 2012 Author Report Share Posted January 5, 2012 Da napomenem da kada sam prikljucio ovaj "novi" dek normalno svira neka stanica ali bez Mid-a ne mogu da kontrolisem nista... Link to post Share on other sites
boris74 0 Posted January 5, 2012 Report Share Posted January 5, 2012 Da napomenem da kada sam prikljucio ovaj "novi" dek normalno svira neka stanica ali bez Mid-a ne mogu da kontrolisem nista... ako hoces da prodas ovaj stari javi mi,meni dugmence za trazenje stanica malo izgrebano Link to post Share on other sites
Sicko 0 Posted January 5, 2012 Author Report Share Posted January 5, 2012 ako hoces da prodas ovaj stari javi mi,meni dugmence za trazenje stanica malo izgrebano OK. Samo da povezem ovo. Link to post Share on other sites
Sicko 0 Posted January 5, 2012 Author Report Share Posted January 5, 2012 Evo moje neko razmisljanje + i - cu da povezem lako, uzecu sa mog glavnog konektora sa pina 15 i 12 (a na midu su mi gore navedene zice), verovatno ide posebni kabli za pozadinsko osvetljenje (uzecu ga sa pina 14 na glavnom konektoru ali ne mogu semu konektora MID-a da nadjem nikako (jedna zica od preostalih 3) i ostaje mi jedna zica da se poveze na I-bus, pin 9 na glavnom konektoru. Jedna zica na MID-u ostaje visak to je verovatno za bord. Kad bi neko iskopao negde semu konektora mid-a, mnogo bi mi znacilo. Link to post Share on other sites
majstorbob80 0 Posted January 5, 2012 Report Share Posted January 5, 2012 Po BMW WDS-u 1) Braon crna - minus 2) Crveno crna+12v 3) Sivo crvena light modul 4) Belo siva L-BUS to IKE(instrument cluster electronics pin8) 8) +12v Imam WDS ali nemogu ili neznam da sacuvam semu da bi je podigao n net, a sam wds je 4 GB.Jbg. Link to post Share on other sites
Sicko 0 Posted January 5, 2012 Author Report Share Posted January 5, 2012 Hvala puno. Link to post Share on other sites
majstorbob80 0 Posted January 5, 2012 Report Share Posted January 5, 2012 Nema na cemu druze. Pogledaj PM. Link to post Share on other sites
Sicko 0 Posted January 7, 2012 Author Report Share Posted January 7, 2012 Mozda nekom zatreba. Povezao sam ovo (po gore navedenim semama) i sve sljaka. Cak su i zice istih boja. Link to post Share on other sites
