panthocrator 0 Posted February 4, 2012 Report Share Posted February 4, 2012 Postovanje, intresuje me ko u Beogradu moze da mi sredi displey radia i BC-a. Na samom displey-u fale neke tackice(zapravo gomila), citajuci razne strane forume rekao bih da je u pitanju flat kabl. Ima li neko da prodaje taj kabl ili neki servis koji to radi. Hvala svima unapred pozz Link to post Share on other sites
CasperBg82 0 Posted February 4, 2012 Report Share Posted February 4, 2012 http://www.m5board.com/e39m5/Pixel-repair-v05.pdf Link to post Share on other sites
panthocrator 0 Posted February 4, 2012 Author Report Share Posted February 4, 2012 http://www.m5board.com/e39m5/Pixel-repair-v05.pdf Hvala ali meni ne treba za instrument tablu vec za onaj display iznad menjaca na kom je komada za radio i board comp. I treba mi kabl ili neko ko to moze da uradi. Link to post Share on other sites
panthocrator 0 Posted February 4, 2012 Author Report Share Posted February 4, 2012 Jos jeno pitanje jesu li MID koji upravlja kasetofonom i MID koji upravlja CD isti? hvala Link to post Share on other sites
Sicko 0 Posted February 4, 2012 Report Share Posted February 4, 2012 Isti su. Ako imas zivaca i strpljenja evo linka... http://www.bimmerboard.com/forums/posts/504260 Link to post Share on other sites
panthocrator 0 Posted February 4, 2012 Author Report Share Posted February 4, 2012 Isti su. Ako imas zivaca i strpljenja evo linka... http://www.bimmerboard.com/forums/posts/504260 Imam i zivaca i strpljenja ali nemam kabl, pa ko znate gde bi to moglo da se nabavi bilo bi od velike pooci. Link to post Share on other sites
Sicko 0 Posted February 4, 2012 Report Share Posted February 4, 2012 Procitaj bolje... Ne treba ti novi kabl, on je neostecen vec su se s*ebali kontakti. Skine se stari tj odlepi se tamo gde naleze na plocu pa se acetonom obrisu kontakti i skine se takodje acetonom ona zuta izolacija sa samog kabla (na vrhu gde naleze), skidanjem izolacije se dobijaju novi neosteceni kontakti na kablu. Kasnije se oni postavljaju na kontakte na tabli i sve ponovo vraca. Veoma, veoma PITA. Link to post Share on other sites
panthocrator 0 Posted February 4, 2012 Author Report Share Posted February 4, 2012 Ajde probacu pa javljam Link to post Share on other sites
Sicko 0 Posted February 4, 2012 Report Share Posted February 4, 2012 Nadam se znas da PITA znaci Pain In The Ass ili ti zesce za*ebano i pipkavo... Srecno... Link to post Share on other sites
panthocrator 0 Posted February 4, 2012 Author Report Share Posted February 4, 2012 Nadam se znas da PITA znaci Pain In The Ass ili ti zesce za*ebano i pipkavo... Srecno... nisam znao ali eto covek uci dok je ziv trenutno ne radi pa ne radi i ako ga upropastim nece biti prevelika steta jer ionako sleduje drugi MID. ako uspe cist car Link to post Share on other sites
panthocrator 0 Posted February 6, 2012 Author Report Share Posted February 6, 2012 Jos jedno pitanje, sa desne strane displeya imam dva dugmeta na jenom pise AUDIO i pored njega ima mala dioda, a drugo je dole desno i ima simol za sat i pored njega velika dioda. Ukoliko ne popravim ovaj display video sam da ima i displey na kome je gornje dugme AUDIO/DSP a donje simbol sata i BC, koliko sam uspeo da procitam to BC je za kompijuter i ako ga nabavim hocu li imati opcije sa tog BC (plug & play) ili mora nesto da se programira. Hvala unapred. pozdrav Link to post Share on other sites
Sicko 0 Posted February 6, 2012 Report Share Posted February 6, 2012 Neces... Ustvari jel imas autic na instrument tabli? Odnosno LOW instrument cluster... Znaci ako imas autic bord kompjuter na MID-u neces imati ali sve ostalo da. Link to post Share on other sites
panthocrator 0 Posted February 6, 2012 Author Report Share Posted February 6, 2012 Mislim a ne vredi ovako moracu da slikam jer se jos ne razumem u BMW i sta je sta. Hvala na odgovoru u svakom slucaju. Link to post Share on other sites
Sicko 0 Posted February 6, 2012 Report Share Posted February 6, 2012 http://www.bimmerfest.com/forums/showthread.php?p=4925191 Evo na ovom linku imas kako da razlikujes instrument table i MID-ove. Ako imas sa auticem tablu onda mozes da stavis bilo koji MID samo ako stavis sa BC nece ti to raditi, jer instrument tabla sa auticem ne podrzava BC na mID-u. Sve ostalo hoce. Link to post Share on other sites
panthocrator 0 Posted February 6, 2012 Author Report Share Posted February 6, 2012 OK tabla mi je ta sa low cluster, a mid je onaj bez telefono tj donji na slici. Hvala. Sad sam zavrsio sa reparacijom tj dogurao do pola. Kad sam skinuo onaj deo plastika sa kabla sto ima viska ustanovio sam da mi fali kontakata i onda sam batalio sve. Sad sam u potrazi za novim mid ili kablom. I tako Sicko hvala za sve informacije jos jendnom. Link to post Share on other sites
panthocrator 0 Posted February 6, 2012 Author Report Share Posted February 6, 2012 evo upravo sklopih sve cisto iz inata da vidim mogu li i nije problem sutra cu da ga bocnem u kola da vidim ima li sta na ekranu. Link to post Share on other sites
Sicko 0 Posted February 6, 2012 Report Share Posted February 6, 2012 Najza*ebanije je nalepiti ponovo flet na plocu nadji odma kvalitetan selotejp. Link to post Share on other sites
panthocrator 0 Posted February 6, 2012 Author Report Share Posted February 6, 2012 Da to sam i radio, skinuo tu zutu izolaciju acetonom ali i tu fale neki kontakti. Mislim da cu poruciti novi kabl. Link to post Share on other sites
panthocrator 0 Posted February 6, 2012 Author Report Share Posted February 6, 2012 A znas li mozda kako da startujem "test mod" na MID da se upale sve tackice? Hvala Link to post Share on other sites
Sicko 0 Posted February 6, 2012 Report Share Posted February 6, 2012 Prvo i zadnje dugme pritisnes pa das kontakt (dugmice drzis i dalje)... Ukljuci se indentifikacija uredjaja koja traje oko 3 sekunde i za to vreme ukljucujes Display test. Evo ovde imas objasnjeno. http://www.meeknet.co.uk/E38/E38_MID_Display.pdf Link to post Share on other sites
panthocrator 0 Posted February 7, 2012 Author Report Share Posted February 7, 2012 hvala Link to post Share on other sites
panthocrator 0 Posted February 7, 2012 Author Report Share Posted February 7, 2012 Sad sam se vratio iz garaze i situacija je losija nego sto je bila, sad idem da porucim kabl. Link to post Share on other sites
Sicko 0 Posted February 7, 2012 Report Share Posted February 7, 2012 jbg... Link to post Share on other sites
vranjin 0 Posted February 7, 2012 Report Share Posted February 7, 2012 Ako nisi jos porucio kabl mozes da probas drugacije. Oguliti izolaciju do zdravih vodova. Vidi sa nekim ko popravlja mobilne, cd, ko ima duvaljku i pastu za lemljenje ( sa kalajem) da ti to zalemi. Moze i sa obicnom ali malo boljom lemilicom. Posle fiksiraj kabl za plocicu da se ne pokidaju ponovo vodovi. Samo, moze da se desi da gubi kontakt i na displeju. Link to post Share on other sites
panthocrator 0 Posted February 7, 2012 Author Report Share Posted February 7, 2012 Razmisljao sam i o lemljenju ali ko mi garantuje da je kabl ok na drugoj strani gde naleze na kristal, a ako zalemim nesto na polocu nikad to vise nece raditi kako treba ako budem morao da ppromenim kabl. sve u svemu kabl je 32e nije tako strasno. Link to post Share on other sites
