panthocrator 0 Posted March 6, 2012 Report Share Posted March 6, 2012 Postovanje, Danas sam seo prvi put u auto od kad sam ga kupio i izvezao na autoput ali auto nece da razvije vise od 130kmh. Ponasa se noramalno u 1, 2, 3, zapravo ide naj normalnije kad dodjem u 4 ili petoj na 130 oduzme gas i odrzava brzinu. U prve 3 sam ga zavrteo do 4000 bez problema. Kad dodje do 130 koliko god da drzim pritisnutu papuciu nista se ne desava, cak i trenutna potrosnja stane na 10l. Ukoliko pustim gas i brzina padne na recimo 120 ako ubrzam radice do 130 a onda ce opet da stane tj da odrzava brzinu. Postoji li neki speed limiter ili nesto slicno sto bi moglo da uzrokuje ovakvo ponasanje. Stose tice MID nemam onaj sa BC. Svaka pomoc je dobrodosla hvala pozz Link to post Share on other sites
pontdom 0 Posted March 6, 2012 Report Share Posted March 6, 2012 to se i meni desava....ukljucim pa iskljucim tempomat i pocinje da "ide" . Link to post Share on other sites
panthocrator 0 Posted March 6, 2012 Author Report Share Posted March 6, 2012 Ja nemam tempomat Link to post Share on other sites
pontdom 0 Posted March 6, 2012 Report Share Posted March 6, 2012 nekoliko puta ga "opali" po gasu ... mora da probije ... sve sam to prosao , tek sto kupih auto ... reko "ovaj" me razvalio koliko me je zajb.... ! :D Link to post Share on other sites
panthocrator 0 Posted March 6, 2012 Author Report Share Posted March 6, 2012 Probao sam ali nece. Vuce normalno dok ne dodje do 130 tu stane i kraj Link to post Share on other sites
pontdom 0 Posted March 6, 2012 Report Share Posted March 6, 2012 Probao sam ali nece. Vuce normalno dok ne dodje do 130 tu stane i kraj e brate...stvarno ... kod mene je slicno , ali posle " poludi " Link to post Share on other sites
Markiša 0 Posted March 6, 2012 Report Share Posted March 6, 2012 Turbina?! Zakaci auto na dijagnostiku, proveri punjenje... :) Link to post Share on other sites
leon63 0 Posted March 6, 2012 Report Share Posted March 6, 2012 Ako je turbnina, ona nece da puni ni na manjim brzinama, za turbinu su bitni obrtaji, a ne brzina. Link to post Share on other sites
777.boban 0 Posted March 6, 2012 Report Share Posted March 6, 2012 Softverski problem,resava ga dijagnostika.I da,postoji opcija limitiranja max brzine. Link to post Share on other sites
DangaraBMW 0 Posted March 6, 2012 Report Share Posted March 6, 2012 Isti problem imao drug na e46 320d 136 ks...lično sam se uvjerio u to jer je dao meni da vozim...do 130-135km/h puni kao lud i tu zakuca :)...znam da mu je bio neki problem sa turbinom...sjutra ga zovem da mi kaže šta jer sam zaboravio... Link to post Share on other sites
Markiša 0 Posted March 6, 2012 Report Share Posted March 6, 2012 Ako je turbnina, ona nece da puni ni na manjim brzinama, za turbinu su bitni obrtaji, a ne brzina. Naravno da su bitni obrtaji tj kolicina izduvnih gasova koja ustavri pokrece turbinu, ali ja pricam iz licnog iskustva, gde je djubre prve tri brzine punilo i onda lagano 4 na 3000rpm i 5 nece preko 2700-800... sve u svemu nece ustanoviti koji je problem bez kacenja na dijagnostiku! ;) Link to post Share on other sites
panthocrator 0 Posted March 20, 2012 Author Report Share Posted March 20, 2012 I sad epilog price ako nekoga intresuje, danas sam bio kod Alone-a i ispotavilo se da su umrli elektro ventil za EGR ventil i neki elektro ventil za turbinu kao i neka vakum creva za turbinu. Kacenjem na dijagnostiku su ustanovili da ima previse vazduha na usisu ( u nekom trenutku umesto da ubacuje 250 jedinica vazduha auto je ubacivao 550 jedinica) i onda su metodom dedukcije dosli do ova dva vetntila. Auto je sad ok. Nadam se da ce tako i ostati. Link to post Share on other sites
panthocrator 0 Posted March 23, 2012 Author Report Share Posted March 23, 2012 Dans izadjem na auto put da proverim dokle moze da ide auto i stignem do 180 i cini mi se da je imao jos gasa, u tom trenutku mi ablenduje neko pomerim se i obidje me mecka kao da sam stajao. Dam levi migavac da se vratim u brzu traku dam gas i nista. Brzina nastavi da pada do 140 i ostade tu ma koliko dodavao gas. Eto zalim se malo pa idem opet kod majstora. Link to post Share on other sites
ianullrich 0 Posted March 23, 2012 Report Share Posted March 23, 2012 imao sam isti problem sa tim motorom, samo u e46, a resio tako sto sam ocistio egr, posle toga je sve bilo normalno, probaj............. Link to post Share on other sites
iradic 0 Posted March 23, 2012 Report Share Posted March 23, 2012 Eto zalim se malo pa idem opet kod majstora. Ali nemoj kod Alonea. :angry: Ne zezam se. Link to post Share on other sites
bgsinger 0 Posted March 23, 2012 Report Share Posted March 23, 2012 Menjaj majstore podhitno dok još imaš 4 točka .... Tamo je pametno kupiti samo žabice za tapacirung a kamoli da ti održavaju auto :( Link to post Share on other sites
BOX 0 Posted March 23, 2012 Report Share Posted March 23, 2012 Menjaj majstore podhitno dok još imaš 4 točka .... Tamo je pametno kupiti samo žabice za tapacirung a kamoli da ti održavaju auto :( +1 Link to post Share on other sites
panthocrator 0 Posted March 23, 2012 Author Report Share Posted March 23, 2012 dobro gde da idem? Link to post Share on other sites
panthocrator 0 Posted March 23, 2012 Author Report Share Posted March 23, 2012 Malopre sam ocistio EGR ventil i otisao na probnu voznju, dogurao do 190, pustio gas malo pokusao ponovo da dam i opet do 140. Stao sam sa strane i skinuo vakum crevo sa EGR i malo mrdao konektor od protokomera jer nisam mogao da ga skinem. Vozio auto jos par kilometara radio normalno, na povratku sam vratio vakum na EGR i auto je i dalje isao normalno. Moracu da testiram jos par dana pa da vidim sta se desava. Link to post Share on other sites
iradic 0 Posted March 23, 2012 Report Share Posted March 23, 2012 dobro gde da idem? Delta, Drinjak. Do sada sam kod njih išao i nemam primedbi. Delta čak i daje popust na godište. Operu ti auto. Zovi prvo, raspitaj se za cene. Imaš i Radulovića, ali mislim da on ubija sa cenama. Nisam išao kod njega. Link to post Share on other sites
Ljilja 0 Posted March 25, 2012 Report Share Posted March 25, 2012 dobro gde da idem? opet u Alone na reklamaciju... Link to post Share on other sites
nsvlada1 0 Posted April 4, 2012 Report Share Posted April 4, 2012 I sta je na kraju bilo ? Link to post Share on other sites
panthocrator 0 Posted April 4, 2012 Author Report Share Posted April 4, 2012 Auto je i dalje u kod majstora, turbina je bila na kontroli u uzicu ali je ispravana, sad je pumpa visokog pritiska na ispitivanju u bosh servisu. Cekam da vidim sta ce da bude. pozz Link to post Share on other sites
Cika Sima 0 Posted April 4, 2012 Report Share Posted April 4, 2012 BMW Bata 063218264 . Korektan, nije skup, i veliki strucnjak. Resavao je probleme koje niko nije mogao da resi. Link to post Share on other sites
panthocrator 0 Posted April 5, 2012 Author Report Share Posted April 5, 2012 Ok hvala za informaciju kontaktiracu gospodina ako ovi ne uspeju da zavrse posao. pozz Link to post Share on other sites
