BORKO KV 0 Posted June 18, 2012 Report Share Posted June 18, 2012 Napunio sam klimu,1100gr,ali jos uvek ne hladi kako bi trebalo,slabije hladi na leru,u voznji solidno,ali mislim da bi trebalo znatno bolje,sutra idem ponovo da je dopunim,pa reko da li neko zna koliko tacno ide freona r12 u sistem? Link to post Share on other sites
CasperBg82 0 Posted June 18, 2012 Report Share Posted June 18, 2012 Refrigerant type Later models use R134a refrigerant, check with label on compressor. Refrigerant quantity R12 systems: Without rear AC = 1925±25 grams With rear AC = 2075±25 grams R134a systems: Without rear AC = 1550±25 grams With rear AC = 1700±25 grams. Link to post Share on other sites
BORKO KV 0 Posted June 18, 2012 Author Report Share Posted June 18, 2012 Hvala puno na odgovoru,kazi mi samo sta se podrazumeva pod ovim "without rear a/c",ili "with rear a/c"? Link to post Share on other sites
CasperBg82 0 Posted June 18, 2012 Report Share Posted June 18, 2012 Valjda je to dvozonska klima, ako ima i pozadi hladjenje, odnosno ima i pozadi isparivac pa je sistem veci :) Link to post Share on other sites
dexterts 0 Posted June 18, 2012 Report Share Posted June 18, 2012 To je za klimu zadnjih sedista ako se ne varam.Without je bez a with sa. Link to post Share on other sites
BORKO KV 0 Posted June 18, 2012 Author Report Share Posted June 18, 2012 Meni jeste dvozonska automatska klima,ima izmedju sedista onaj otvor za ventilaciju,kada ukljucim klimu i tu duva hladno,ako je to uopste to,u svakom slucaju malo je freona stavljeno,dopunicu sutra jos 900gr. valjda ce to biti to,hvala jos jednom! Link to post Share on other sites
CasperBg82 0 Posted June 18, 2012 Report Share Posted June 18, 2012 Ne mora da znaci da je to-to, mozda je samo sproveden vazduh od prednjeg isparivaca, ne znam bas kako to da proveris.. Napuni na ovih 1925, pa neka vide pritisak u sistemu, ako je i dalje mali onda dopuni jos Nije mi jasno kako su te to pustili tako, sta ti dodjes i kazes dajte mi 900 grama freona i to je to :D a nisu proverili nista Link to post Share on other sites
