milanhgt 0 Posted October 31, 2012 Report Share Posted October 31, 2012 u piatnju e46 2000 god 318i 87kw Od danas odjednom auto prestao da greje kabinu znaci cak ni mlako ne duva nego skroz hladno. gledao sam creva i stiskao sam ih i uredu su i creva su topla sto ulaze u radijator. sta bi tu mogao da bude problem ?? da i u hladnjaku ne fali vode i nema vazduha ??? zbunjen sam Link to post Share on other sites
miksa 0 Posted October 31, 2012 Report Share Posted October 31, 2012 neznam dali to ima na e46,ali da pokusam da pomognem. Ako ga ima, mozda je crko motorcic koji pusta toplu vodu u kabinu tj u radijator u kabini.Tako je bar na e36 bilo kod mene kad sam ga tek kupio. Link to post Share on other sites
milanhgt 0 Posted October 31, 2012 Author Report Share Posted October 31, 2012 neznam dali to ima na e46,ali da pokusam da pomognem. Ako ga ima, mozda je crko motorcic koji pusta toplu vodu u kabinu tj u radijator u kabini.Tako je bar na e36 bilo kod mene kad sam ga tek kupio. gde se nalazi taj motoric ?kako da vidim dali valja ako ga ima? Link to post Share on other sites
miksa 0 Posted October 31, 2012 Report Share Posted October 31, 2012 to ti je ovo pod brojem 4,a mozes probati sa dve zice na akumulator,dal otvara i zatvara klapnu unutra Link to post Share on other sites
milanhgt 0 Posted October 31, 2012 Author Report Share Posted October 31, 2012 da digitalnu Link to post Share on other sites
miksa 0 Posted October 31, 2012 Report Share Posted October 31, 2012 nemoj se uzdati preterano u moje pisanje,ja nisam majstor Sacekaj da neko od strucnijih napise koju rec Link to post Share on other sites
milanhgt 0 Posted October 31, 2012 Author Report Share Posted October 31, 2012 hvala na odgovoru.neznam ni kome da se obratim u subotici nema dobrih majstora Link to post Share on other sites
Dejan NS 0 Posted October 31, 2012 Report Share Posted October 31, 2012 Kako nema , imas na Palicu , paralelno sa glavnim putem preko puta velikog marketa dobrog majstora , vozio je prelepog Golfa 4 . Link to post Share on other sites
milanhgt 0 Posted October 31, 2012 Author Report Share Posted October 31, 2012 On pravi samo vw Link to post Share on other sites
Braneas 0 Posted November 1, 2012 Report Share Posted November 1, 2012 Prvo, to pod brojem 4 nije pumpa nego elektroventil. Proveri da li su topla creva iza njega, tj da li otvara. Ako su topla, znaci da ti je hladnjak ( grejac) u kabini zacepljen. Link to post Share on other sites
Sutlandjanin 0 Posted November 1, 2012 Report Share Posted November 1, 2012 upravo tako, ako nisu onda je ventil, imao sam problem pre nekoliko dana doduse na e36, isto digitalna klima Link to post Share on other sites
miksa 0 Posted November 1, 2012 Report Share Posted November 1, 2012 Prvo, to pod brojem 4 nije pumpa nego elektroventil. Gde sam ja njemu napisao da je to pumpa? Link to post Share on other sites
StunterSM 0 Posted November 1, 2012 Report Share Posted November 1, 2012 Napisao si motoric, ako pokrece vodu motoric onda je njegovo ime pumpa. Nebitno u pitanju je elektro ventil koji treba da je otvoren kad je namesteno na konzoli grejanje Link to post Share on other sites
milanhgt 0 Posted November 1, 2012 Author Report Share Posted November 1, 2012 Danas sam se čuo sa majstorom i kaze da treba da skine kasetu i tamo da promeni neki motoric ili u najgorem slucaju da mi rastavi ceo kokpit i zameni klapne. Dali prica gluposti ili ima tu nesto? Link to post Share on other sites
Sutlandjanin 0 Posted November 1, 2012 Report Share Posted November 1, 2012 pa jesi li proverio ventil, kao sto je gore napisano ? :) Link to post Share on other sites
milanhgt 0 Posted November 1, 2012 Author Report Share Posted November 1, 2012 nisam nesmem:) Link to post Share on other sites
Sutlandjanin 0 Posted November 1, 2012 Report Share Posted November 1, 2012 :D Link to post Share on other sites
milanhgt 0 Posted November 1, 2012 Author Report Share Posted November 1, 2012 Nosim ga u utorak na rastavljanje pa cemo videt nadam se da nisu klapne Link to post Share on other sites
Braneas 0 Posted November 2, 2012 Report Share Posted November 2, 2012 Slobodno nadji gde je ventil, u motornom prostoru ispod soferke na strani vozaca, i kada zagrejes motor, ispipaj creva ispred i iza ventila. Za to ti nista ne treba. Link to post Share on other sites
milanhgt 0 Posted November 2, 2012 Author Report Share Posted November 2, 2012 Taj ventil mora da se menja ili moze da se napravi posto nemam pojma kad cu ga naci Link to post Share on other sites
miksa 0 Posted November 2, 2012 Report Share Posted November 2, 2012 nemoze da se popravi a ima ga verovatno masa ljudi sa foruma koji prodaju polovne delove Link to post Share on other sites
