blaguja 0 Posted December 25, 2012 Report Share Posted December 25, 2012 Koje ulje sipati u ovaj motor? Dobio sam preporuke Castrol Magnetec 10w40,da li je to zadovoljavajuce dok drugi prijatelj mi je preporucio seleniju 20k ili seleniu race 10w60. Link to post Share on other sites
325ixA 0 Posted December 25, 2012 Report Share Posted December 25, 2012 sve, sve samo seleniju ne. Ubedljivo najgore ulje. Link to post Share on other sites
StunterSM 0 Posted December 25, 2012 Report Share Posted December 25, 2012 Kastrol sipaj, samo pazi ima ga starog po par godina a i falsa.. Proveri prvo sta kupujes Link to post Share on other sites
zverko 0 Posted December 25, 2012 Report Share Posted December 25, 2012 kakve veze ima koliko je ulje staro? Link to post Share on other sites
StunterSM 0 Posted December 25, 2012 Report Share Posted December 25, 2012 Ima brate, procitaj rok trajanja :) Link to post Share on other sites
zverko 0 Posted December 25, 2012 Report Share Posted December 25, 2012 Gde pise? Masa ulja mi je proslo kroz ruke nigde nisam video rok tranjanja. Ima datum punjenja ali rok tranjanja ne. Neki proizvodjaci kazu 6god, neki kazu 6 meseci po otvaranju kantice. Kako god, ulje samo od sebe ne moze da degradira. Potrebni su jos neki faktori. Link to post Share on other sites
blaguja 0 Posted December 25, 2012 Author Report Share Posted December 25, 2012 Kastrol sipaj, samo pazi ima ga starog po par godina a i falsa.. Proveri prvo sta kupujes Ok ko proizvodi Castrol? kako da znam da nije fals? Link to post Share on other sites
zverko 0 Posted December 25, 2012 Report Share Posted December 25, 2012 Castrol proizvodi BP. Original je iz UK a ima ga i u US i AUS, NZL i CA. KOd nas mozes naci Austrijski bar kod pocinje sa 9 i Nemacki barkod pocinje sa 4. Original je onaj sa deklaracijom od uvoznika Castrol DOO Beograd ili Castrol Adria ili Platner ili Zdravkovic. Ova dva poslednja retko budu posto sve uglavnom ide preko Castrol DOO - Beograd. Ali ne mora samo Castrol. Sipaj Mobil,Q8,Motul,Liqui Moly... Link to post Share on other sites
blaguja 0 Posted December 25, 2012 Author Report Share Posted December 25, 2012 Castrol proizvodi BP. Original je iz UK a ima ga i u US i AUS, NZL i CA. KOd nas mozes naci Austrijski bar kod pocinje sa 9 i Nemacki barkod pocinje sa 4. Original je onaj sa deklaracijom od uvoznika Castrol DOO Beograd ili Castrol Adria ili Platner ili Zdravkovic. Ova dva poslednja retko budu posto sve uglavnom ide preko Castrol DOO - Beograd. Ali ne mora samo Castrol. Sipaj Mobil,Q8,Motul,Liqui Moly... ok hvala puno,koja je vasa preporuka? Sutra idem da kupim ulje i planiram Castrol.od selenie sam odustao. Link to post Share on other sites
zverko 0 Posted December 25, 2012 Report Share Posted December 25, 2012 ma koja crna selenia. uzmi bilo sta 10w-40 pa vidi kako ce da se pokaze. Link to post Share on other sites
StunterSM 0 Posted December 26, 2012 Report Share Posted December 26, 2012 Gde pise? Masa ulja mi je proslo kroz ruke nigde nisam video rok tranjanja. Ima datum punjenja ali rok tranjanja ne. Neki proizvodjaci kazu 6god, neki kazu 6 meseci po otvaranju kantice. Kako god, ulje samo od sebe ne moze da degradira. Potrebni su jos neki faktori. Nino kaze da je rok trajanja valjda 2 godine.. On valjda zna jer prodaje ulje, nazovi ga i pitaj Link to post Share on other sites
325ixA 0 Posted December 26, 2012 Report Share Posted December 26, 2012 otvoreno da, posle dve-tri godine oksidacija ucini svoje. Link to post Share on other sites
StunterSM 0 Posted December 26, 2012 Report Share Posted December 26, 2012 Rece mi bas za zatvoreno, da preko izbacuju iz prodaje to koje je par godina staro, pa nasi uzimaju za male pare i prodaju ovde Link to post Share on other sites
325ixA 0 Posted December 26, 2012 Report Share Posted December 26, 2012 moguce. Ulje kao ulje nema sta da se pokvari dok je zatvoreno, verovatno opada kvalitet raznih aditiva koji se dodaju u ulje. Link to post Share on other sites
zverko 0 Posted December 26, 2012 Report Share Posted December 26, 2012 Motorna ulja imaju rok upotrebe od 3 godina. Do skora je bio 5 i to je neka vrednost koja se još uvek toleriše. Naravno ne kupujte ulja starija od 3 godine a ako dobijete na poklon ili je vašom krivicom prekoračilo rok upotrebe (iako je kupljeno na vreme) držite se da u normalnim uslovima skladištenja (garaža bar) isto možete koristiti i 2 godine nakon isteka. Ukoliko je na samom ulju rok 5 godina ne premašujte rok za više od 6 meseci. U oba slučaja razmotrite malo skraćenje intervala zamene, na primer od 20% ili tu negde. http://motornaulja.blogspot.com Link to post Share on other sites
pontdom 0 Posted December 26, 2012 Report Share Posted December 26, 2012 ...da ne otvaram novu temu ... 1 auto koji stoji skoro 5 meseci ... postoji li neka procedura redovnog "paljenja" - vremenski interval 2 neophodno da radi ne leru - koliko ? 3 sta uraditi sa kocnicama i kvacilom da bude "uvek spreman" 4 HVALA ! :) Link to post Share on other sites
zverko 0 Posted December 26, 2012 Report Share Posted December 26, 2012 pa mozes eventualno da skines svecice, naprskas WD, vratis svecke i sutra dan palis normalno. U principu nista ne bi trebalo da se desi nenormalno ako je ispravan. bmw je to brate nije jugo. pustis ga da radi malo na leru i teras. kocnice, kvacilo uvek spremno, nema sta tu da se radi. bar ja tako mislim, ako gresim neka me ispravi ko zna. Link to post Share on other sites
blaguja 0 Posted December 26, 2012 Author Report Share Posted December 26, 2012 Castrol proizvodi BP. Original je iz UK a ima ga i u US i AUS, NZL i CA. KOd nas mozes naci Austrijski bar kod pocinje sa 9 i Nemacki barkod pocinje sa 4. Original je onaj sa deklaracijom od uvoznika Castrol DOO Beograd ili Castrol Adria ili Platner ili Zdravkovic. Ova dva poslednja retko budu posto sve uglavnom ide preko Castrol DOO - Beograd. Ali ne mora samo Castrol. Sipaj Mobil,Q8,Motul,Liqui Moly... Kupio sam Castrol i kantica i 2 flase po l bar kod je sa 4 pocinje s tim sto na flase pise sve na nemackom i zemlja porekla je EU dok na kantici od 4 litre zemlja porekla FU i pise na italijanskom,spanskom ili francuskom. da li je i ono original na flasama od ispod pise Castrol dok na balonu ne. Link to post Share on other sites
blaguja 0 Posted December 26, 2012 Author Report Share Posted December 26, 2012 I da li je tacno da ide 5,75 litre u motoru sa filterom,tako mi pise u AUTO DATI Link to post Share on other sites
CasperBg82 0 Posted December 26, 2012 Report Share Posted December 26, 2012 Tacno je Link to post Share on other sites
StunterSM 0 Posted December 26, 2012 Report Share Posted December 26, 2012 Ajde kad smo kod ulja, C je oznaka za dizel, S je oznaka za benzin. Dalje druga oznaka npr CL, znaci dizelsko ulje, a ono "L" je oznaka za kvalitet. Sto je dalje drugo slovo od slova A po abecedi to je ulje kvalitetnije. Npr CL je kvalitetnije dosta od CF(koje je inace minimum a i najcesce ulje kod nas). Postoje i ulja sa oznakom CL/SL to je univerzalno ulje za dizele i benzince, dok za turbo motore ide posebno ulje. Dok su moji drzali auto centar za japanska vozila, isli su na seminare neke i predavanja, pa sam i sam nesto upamtio tad.. Nadam se da sam bio od pomoci ;) Link to post Share on other sites
zverko 0 Posted December 26, 2012 Report Share Posted December 26, 2012 Sta bre, kakav CL/SL ? Postoje ACEA i API standardi ili kategorije. Kanda ti se malo pomesalo. API ENGINE OIL CLASSIFICATIONS API stands for American Petroleum Institute. The API Service Classification System defines the performance level of a given oil, unrelated in the main, to oil viscosity. The API requirements "S" for Spark Ignition (petrol) and "C" for Compression Ignition (diesel) can be briefly described as follows. Petrol Engine Service Classifications SA Oil without additive SB Some antioxidant and anti scuff properties SC Meets 1964-1967 requirements of Automotive manufacturers SD Meets 1968-1971 requirements of Automotive manufacturers SE Meets 1972-1979 requirements of Automotive manufacturers SF Meets 1980-1988 requirements of Automotive manufacturers SG Meets 1989-1993 requirements of Automotive manufacturers SH Meets 1994-1997 requirements of Automotive manufacturers SJ Meets 1998-2000 requirements of Automotive manufacturers SL Meets 2001-2004 on requirements of Automotive manufacturers SM Meets 2004-2011 on requirements of automotive manufacturers. XW-20 and XW-30 grades have chemical limits SN Meets 2011-on requirements of automotive manufacturers. Limited to 0W-20, 5W20, 0W-30, 5W-30 and 10W-30 grades and have chemical limits SA to SH are obsolete. Diesel Engine Service Classifications CA Light duty, high quality fuel, for MIL-L-2104A, 1954 CB Moderate duty, lower quality (high sulphur) fuel CC Moderate to severe duty diesel and gasoline service MIL-L-2104B, 1964 CD Severe duty diesel, including turbo, Caterpillar Series 3, MIL-L-2104C CD-II API CD plus Detroit Diesel 6V53T approval for two stroke engines CE Turbo/Supercharged heavy duty diesels from 1983 CF Off road indirect injection diesel engines and others using a broad range of fuel types including high sulphur. May be used to replace API CD oils CF-2 Severe duty two stroke diesel engine service from 1994 CF-4 Severe Duty four stroke diesel engine service for lower emission diesel engines (from 1988) CG-4 Severe Duty four stroke engines meeting 1994 emission standards (less than 0.5 fuel sulphur) CH-4 High speed four stroke engines meeting 1998 emission standards (less than 0.5% fuel sulphur). CI-4 High speed four stroke engines fitted with cooled EGR (released Dec 2001) and using low-sulphur fuel. CI-4 PLUS As per CI-4 but with further restrictions on after shear viscosity and perform ance. (released September 2004). Aust. 2008. CJ-4 Released in 2006 for 15ppm maximum fuel sulphur. Enhanced wear, protection 1.0% ash maximum. US EPA '07. CA to CF-4 Are obsolete @blaguja: Zemlja porekla FU? Link to post Share on other sites
StunterSM 0 Posted December 26, 2012 Report Share Posted December 26, 2012 Oznake na flasi od ulja, imas sa zadnje strane. To je oznaka kvaliteta ulja, koju je izdala tamo neka kontrola :prankster2: Link to post Share on other sites
StunterSM 0 Posted December 26, 2012 Report Share Posted December 26, 2012 To ti je to API service classification Link to post Share on other sites
zverko 0 Posted December 26, 2012 Report Share Posted December 26, 2012 koga zanima ima ovde sve u tanka crevca. carbibles.com/engineoil_bible.html ko ne zna engleski,ovde ima na srpskom motornaulja.blogspot.com btw, Castrol sa italijanskom nalepnicom... hmmm... :blink: <_< Link to post Share on other sites
