nesaE30 0 Posted January 17, 2014 Report Share Posted January 17, 2014 pozdrav ljudi! imam na kocki sva cetiri podizaca,fabricka,negde sam video da na prekidacima postoji osvetljenje. sad,da li je to na novijim modelima,posto je moj tenak 84 god. bele strelice su nekada bile,ali su pohabane,predpostavljam da su prekidaci fabricki,ali nisam ih vadio,pa ne znam da li uopste postoje sijalice u njima. hvala! Link to post Share on other sites
marudza 0 Posted January 17, 2014 Report Share Posted January 17, 2014 imaju sijalicice u njima Link to post Share on other sites
nesaE30 0 Posted January 17, 2014 Author Report Share Posted January 17, 2014 sad sam ih skinuo,na zalost nemaju sijalicice. samo dve opruge,i limovi za kontakt. hvala u svakom slucaju! Link to post Share on other sites
vranjin 0 Posted January 17, 2014 Report Share Posted January 17, 2014 Ja bih ubacio male LE diode :) . Link to post Share on other sites
nesaE30 0 Posted January 17, 2014 Author Report Share Posted January 17, 2014 Ja bih ubacio male LE diode :) . na koju foru? taster je od crne plastike,beli deo-strelice je samo nacrtan sa spoljne strane. P.S. si iz KI.? Link to post Share on other sites
vranjin 0 Posted January 17, 2014 Report Share Posted January 17, 2014 Ako je providna strelica stavis ispod diodu a ako je puna plastika imas trouglaste diode pa polako ih ubacis kroz plastiku. Iz Kikinde sam ali trenutno radim u Grockoj. Link to post Share on other sites
nesaE30 0 Posted January 17, 2014 Author Report Share Posted January 17, 2014 Ako je providna strelica stavis ispod diodu a ako je puna plastika imas trouglaste diode pa polako ih ubacis kroz plastiku. Iz Kikinde sam ali trenutno radim u Grockoj. puna plastika je u pitanju. nisam znao za trougle diode,pokusacu da eksperimentisem kad uhvatim vremena. drago mi je da ima nekog sa severa Banata. Inace ja sam rodeni Padejac,a lepsa polovina mi Kikindjanka. Link to post Share on other sites
vranjin 0 Posted January 17, 2014 Report Share Posted January 17, 2014 Ne znam da li ima trenutno aktivan na forumu iz ovih krajeva. A gde zivis? Na nekom starom autu nije mi nista svetlelo oko dugmica za ventilaciju. Sraf sam isturpijao u obliku trougla, velicine LED, zagrejao i sa tim probusio plastiku. Ostane ti rupa taman za LED. Naravno, treba ti otpornik za diodu. Link to post Share on other sites
marudza 0 Posted January 18, 2014 Report Share Posted January 18, 2014 moji prekidaci imaju fabricki sijalice u njima,kod mene si verovatno i video kako svetle... to kod tebe ili nisu originali ili su mozda iz neke starije serije koja nije ni imala sijalice u njima...znaci nadji original prekidace i skrati sebi muke.. Link to post Share on other sites
vranjin 0 Posted January 18, 2014 Report Share Posted January 18, 2014 To mu jeste najjednostavnija varijanta. Link to post Share on other sites
Milee30 0 Posted February 7, 2014 Report Share Posted February 7, 2014 Pozdrav drustvo, imam i ja par pitanja u vezi prekidaca pa ako je neko rad da pomogne :) Dakle vozim e30 m10, 4 vrata, nabavio sam el podizace naprijed narucivao brzom postom i lik mi posalje motorice i samo dva kabla idu s njih, i poslao mi je i dzekove zenske gde se stekaju prekidaci. probao sam motorice na ispravljac rade oba. postavio ih u vrata izvukao kablove i odem do nesrecnog elektircara. on je provukao plus i minus s akumulatora imao sam 3 prekidaca, svaki put kad je stavio nesto se zaspusilo u prekidacu i video sam da varnici malo. sad ne znam da li je do prekidaca ili do njega pojma nemam. i kad spojim te dve zice sto je on odvojio samo spusta prozor a nece da ga vrati. on i dalje tvrdi da je to do prekidaca, kad okrenem kablove opet na istu komadnu vraca prozor gore. da li je problem stvarno u prekidacima ili treba nekako drugacije spojiti da se izmeri struja pa da stavlja releje... ? mogu li prekidaci da pregore ili da im se nesto desi sta znam imam 3 a tesko mi je nabaviti ovde u bosni bilo gde te prekidace reti su skroz. svaka pomoc bi dobro dosla :) Link to post Share on other sites
marudza 0 Posted February 7, 2014 Report Share Posted February 7, 2014 Prekidaci se "pojedu" ali vrlo lako se mogu srediti da rade,bilo koji elektricar sa lemilicom ti moze srediti prekidace,al pre svega moras naci boljeg majstora jer taj sto je izvlacio direktno struju sa akumulatora ne treba da pridje vise kolima... trebao si uzeti kompletnu fabricku instalaciju za podizace sa relejima koja se dzeka ispod volana,u tom slucaju dobijaju struju kada je brava na kontaktu ili kada otvoris vrata,ukoliko povezes i relej sa pobudom sa prekidaca na stubu za unutrasnje svetlo.. naravno sve se to moze napraviti i od aftermarket delova,treba ti 2 releja i 2 metra zice,ali pre svega OZBILJNIJI MAJSTOR. Link to post Share on other sites
Milee30 0 Posted February 8, 2014 Report Share Posted February 8, 2014 hvala drug, trazicu nekog elekticara koji se razumije, da mi pogleda te prekidace i da to spoji kako treba. ubi se puseci u kolima nigde prozor da otvorim :D Link to post Share on other sites
