Deka 0 Posted April 29, 2008 Report Share Posted April 29, 2008 dali moze da se smanji automatski saugh i ako moze kako?radi mi na 2000 obrtaja dok nedostigne radnu temperaturu i onda je na 1000.sa obzirom da sam skinuo termostat treba bas vremena da se zagreje.usput na plinu je.hvala. Link to post Share on other sites
gagy80 0 Posted April 29, 2008 Report Share Posted April 29, 2008 A rcei samo dali ti je toliko jak ler na plinu ili na benzinu???Malo si nejasno napisao 'na plinu je' ima plin,Ok ali kada je veliki ler??? Link to post Share on other sites
Deka 0 Posted April 30, 2008 Author Report Share Posted April 30, 2008 ler mi je od starta znaci na tacnije 1800 obrtaja,dok dostigne radnu on padne na 1000,probao sam da smanjim ler ali onda hoce i da se ugasi.tako mi je i na benzinu. Link to post Share on other sites
simma 0 Posted April 30, 2008 Report Share Posted April 30, 2008 I meni je tako na istom modelu. Ubaci termostat pa ce te "krace" nervirati jer se brze greje. Link to post Share on other sites
