bokilic 0 Posted July 31, 2015 Report Share Posted July 31, 2015 Opet imam gremline,e38..opet krene kontrolna tabla da luduje,da neradi,da radi bez veze,u tom momentu neradi ni sat,na pr nepokazuje dugo svetlo ili migavce ali napolju sve radi,hoće ponekad da ostanu da sijaju stopovi pozadi i pozicije..iako sam ugasio svetla izvadio ključ..prekontrolisao spojeve,osigurače,nisam jos tablu vadio,ta mi je činiti?gde tražiti kvar Link to post Share on other sites
bokilic 0 Posted July 31, 2015 Author Report Share Posted July 31, 2015 Da dodam da tad kad luduje luduju i temperatura i obrtometar i kilometraza,ma sve nesto naopako radi? Link to post Share on other sites
Sicko 0 Posted July 31, 2015 Report Share Posted July 31, 2015 Mozda te zemlja negde zeza... Kod e39ki ima na prednjim koevima, ima i kod suvozačeve kutije filtera mesta gde su vezuje za asiju. Možda je kod e38 tako. Link to post Share on other sites
bokilic 0 Posted July 31, 2015 Author Report Share Posted July 31, 2015 Pa kao gledo sam mase,jebemli ga,kao ima ih,nisam skidao tablu da proverim da nije tu neka zbrka,ili je crko taj vrag koji god da je sto upravlja tom skalamerijom ☺ Link to post Share on other sites
vlada111 0 Posted July 31, 2015 Report Share Posted July 31, 2015 probaj sa drugom tablom. Link to post Share on other sites
leon63 0 Posted August 1, 2015 Report Share Posted August 1, 2015 Probaj sa drugim kompjuterom, EWS-om i kljucem. Pisem iz iskustva, jer je ckvek u Nisu imao skoro isti problem i nije bilo do table vec do motornog kompjutera. Link to post Share on other sites
Sicko 0 Posted August 1, 2015 Report Share Posted August 1, 2015 A dijagnostika ta kaže? Link to post Share on other sites
bokilic 0 Posted August 1, 2015 Author Report Share Posted August 1, 2015 Dijagnostika nekaze nista... Link to post Share on other sites
vranjin 0 Posted August 2, 2015 Report Share Posted August 2, 2015 Ne znam sta pametno reci. Receno je vec sta da vidis, mozda da odes kod nekog ko ima delove za e38 pa da redom menjas, pocevsi od table. I dobro pregledaj mase. Link to post Share on other sites
777.boban 0 Posted August 2, 2015 Report Share Posted August 2, 2015 A light modul? Link to post Share on other sites
Nidza crveni 0 Posted August 2, 2015 Report Share Posted August 2, 2015 To je i problem Link to post Share on other sites
bokilic 0 Posted August 2, 2015 Author Report Share Posted August 2, 2015 Lajt modul kad otkačim tabla i dalje isto zeza.. Link to post Share on other sites
Sicko 0 Posted August 2, 2015 Report Share Posted August 2, 2015 A jel si probao da očita greke kad je problem aktivan... Link to post Share on other sites
bokilic 0 Posted August 2, 2015 Author Report Share Posted August 2, 2015 Pa to se čas javi,čas ne..zapamtila bi dijagnostika valjda.. Link to post Share on other sites
Sicko 0 Posted August 2, 2015 Report Share Posted August 2, 2015 Ne mora da znači, zavisi od greke. Često kad se rei problem i greka se sama izbrie... Link to post Share on other sites
bokilic 0 Posted September 1, 2015 Author Report Share Posted September 1, 2015 Gremlin nadjen,a i mozda resen,kad se zadnji put to pojavilo,čukno po tabli i više se nista nedesava,ne zeza tabla,ne sijaju stopovi,sta je bilo neznam al sad je sve proradilo ☺ . Predpostavljam da je neki glupavi kontakt.. Link to post Share on other sites
Sutlandjanin 0 Posted September 1, 2015 Report Share Posted September 1, 2015 Znaci srpskom metodom kad nesto ne ide uzmi veci cekic hahahaha :lol: Link to post Share on other sites
bokilic 0 Posted September 1, 2015 Author Report Share Posted September 1, 2015 Pa tako nekako? al sad radi,pa do daljnjega nita nepipam .mada razmisljam da smaknem tablu i da vidim sta se tu desava Link to post Share on other sites
bokilic 0 Posted December 5, 2015 Author Report Share Posted December 5, 2015 da,gremlin definitivno u tabli,opet pocelo da zeza,proradi na blago cukanje table...beli konektor na desnoj strani table to jest kako god se zove one kutije na tabli zeza,njega pipkam proradi sve.. predpostavljam da mu je tu memorija neka ili kako se to zove vec sto se skida sa km,sata,sad kod elektricara da se vidi da nije neki hladam lem ili da promenim to,mada neznam dali se to pozadi kodira po autu itd,kako god da se zove to malo crno kockasto :) Link to post Share on other sites
Gruja1595 0 Posted December 9, 2015 Report Share Posted December 9, 2015 Je l si resio ovo druze? I kako? Pozdrav Sent from my iPhone using Tapatalk Link to post Share on other sites
bokilic 0 Posted December 9, 2015 Author Report Share Posted December 9, 2015 Ne,dzek pozadi zeza,pa elektroničar treba da mi to resi,dali je sam dzek,ili hladan lem na tabli,uglavnom pipnes prstom i sve radi,neki kontaktić,samo da uhvati vreme i resíće se,nije neki kvar al kontakt nervira..taman dok stignu novi diskovi i to ću resiti pa sam kompletan.. Link to post Share on other sites
bokilic 0 Posted December 23, 2015 Author Report Share Posted December 23, 2015 preletovani lemovi,sad sve radi☺ Link to post Share on other sites
