vandalizam 0 Posted March 10, 2016 Report Share Posted March 10, 2016 Da li ima neko da podeli instalaciju za Inpu ? Ili eventualno da mi objasni kako da je instaliram na Win10 ? Kupio sam kabal,probao da instaliram,sve kao na videu,ali kada dodjem do OBD.dll file u C:\WINDOWS\User,dalje nemam gde,onda ne mogu ni da dovrsim instalaciju do kraja. Moze neko malo da mi pojasni ? Link to post Share on other sites
Torque 0 Posted March 10, 2016 Report Share Posted March 10, 2016 https://mega.nz/#!9IAzSTyS!OyrRs7NK5jYLeRV4Dbp2AR7uBgjFkb-HdQZ7yqEEoqAInstaliraj BMW standard tools 2.12 pa ovu inpu sa linka prati upustvo meni radi na win 7 Link to post Share on other sites
crni82 0 Posted March 10, 2016 Report Share Posted March 10, 2016 ova inpa nema za e39 Link to post Share on other sites
vandalizam 0 Posted March 10, 2016 Author Report Share Posted March 10, 2016 https://mega.nz/#!9IAzSTyS!OyrRs7NK5jYLeRV4Dbp2AR7uBgjFkb-HdQZ7yqEEoqAInstaliraj BMW standard tools 2.12 pa ovu inpu sa linka prati upustvo meni radi na win 7 Instalirano,sve radi super na Win 10 Hvala na pomoci :thumbsup: :thumbsup: Link to post Share on other sites
Torque 0 Posted March 10, 2016 Report Share Posted March 10, 2016 Instalirano,sve radi super na Win 10 Hvala na pomoci :thumbsup: :thumbsup: Nema na cemu kolega :D Ako ima neko bolju inpu a da nije na svabski neka podeli :D Ja sam imao 5.06 jbg nisam mogao da se snadjem I ja sam muke mucio sa inpom pre neki dan provalio sam da je napravim Link to post Share on other sites
vandalizam 0 Posted March 10, 2016 Author Report Share Posted March 10, 2016 Ja imam ono preko Cda,pa instalacija Step 1, Step 2, Step3 i more jos sitnih podesavanja,i onda na kraju neradi. Ovako nesto sam slicno imao sa Crackom,ali ocigledno da je nesto falilo na tom CDu. Link to post Share on other sites
Torque 0 Posted March 10, 2016 Report Share Posted March 10, 2016 Ja imam ono preko Cda,pa instalacija Step 1, Step 2, Step3 i more jos sitnih podesavanja,i onda na kraju neradi. Ovako nesto sam slicno imao sa Crackom,ali ocigledno da je nesto falilo na tom CDu. Bitno je da radi sada :D Link to post Share on other sites
GNoRbY88 0 Posted March 10, 2016 Report Share Posted March 10, 2016 Ovo je moj upload (inpa 5.02) isto step 1,2,3 sa instrukcijom: https://www.dropbox.com/sh/oppc0gmehe9zudu/AAAsoiORneeyyR-XOZfESX-7a?dl=0 Ja sam instalirao na xp i na win10 x64. Inpa dobro radi (ncsexpert samo na xp), ovo je engleski, samo kod greske pise na nemacku 1-2 mesto.. Link to post Share on other sites
vandalizam 0 Posted March 13, 2016 Author Report Share Posted March 13, 2016 Moze li neko da mi prevede ovo ?Kada pokrenem program,radi ok,medjutim kada hocu negde da udjem i nesto pregledam izbaci mi ovo... Link to post Share on other sites
GNoRbY88 0 Posted March 13, 2016 Report Share Posted March 13, 2016 Na linku ima inpa_faq.pdf Tamo pise greske. Na c\ediabas\bin\ediabas.bin treba da pise: Interface = STD:OBD ili treba da se aktivira FIFO bufferi na com port (ima sliku na pdf) ili koristis serial port.reg file Treba lemiti na adapteru 7-8 pin Kad se ukljuciti adapter na kompjuteru onda na device manageru gledas port Port podesavanje: c\ediabas\bin\obd.ini file [OBD] Port=Com3 Hardware=OBD RETRY=ON..... Ukljucis adapter na auto, onda na laptop, daj kontakt i startujes inpa.. Link to post Share on other sites
vandalizam 0 Posted March 14, 2016 Author Report Share Posted March 14, 2016 Na linku ima inpa_faq.pdf Tamo pise greske. Na c\ediabas\bin\ediabas.bin treba da pise: Interface = STD:OBD ili treba da se aktivira FIFO bufferi na com port (ima sliku na pdf) ili koristis serial port.reg file Treba lemiti na adapteru 7-8 pin Kad se ukljuciti adapter na kompjuteru onda na device manageru gledas port Port podesavanje: c\ediabas\bin\obd.ini file [OBD] Port=Com3 Hardware=OBD RETRY=ON..... Ukljucis adapter na auto, onda na laptop, daj kontakt i startujes inpa.. Mhm,e sad moze dodatno objasnjenje ? Na adapter OBD koji ukljucujem na auto,treba lemiti te pinove ? Jel oni nisu zalemljeni,da li postoje,da li oznaceni po nekom rednom broju? Malo detaljnije ako mzoe,posto se ne razumem bas puno. Sto se tice port podesavanja ( pisem sa posla pa ne mogu da proverim ) u c\ediabas\bin\obd.ini nisam mogao da nadjem obd.ini file,jednostavno nije tamo,tj nemam ga nigde,pa sam probavao sa nekim drugim instalacijama I isto,verovatno nesto nisam uradio kako treba. Link to post Share on other sites
GNoRbY88 0 Posted March 14, 2016 Report Share Posted March 14, 2016 Mhm,e sad moze dodatno objasnjenje ? Na adapter OBD koji ukljucujem na auto,treba lemiti te pinove ? Jel oni nisu zalemljeni,da li postoje,da li oznaceni po nekom rednom broju? Malo detaljnije ako mzoe,posto se ne razumem bas puno. Sto se tice port podesavanja ( pisem sa posla pa ne mogu da proverim ) u c\ediabas\bin\obd.ini nisam mogao da nadjem obd.ini file,jednostavno nije tamo,tj nemam ga nigde,pa sam probavao sa nekim drugim instalacijama I isto,verovatno nesto nisam uradio kako treba. Da. Za e46 treba lemiti 7-8 pin ili stavis mali prekidac. Sa 7-i pin (bez cackanje) meni radio je engine modul, ali ostali moduli ne. http://cartechnology.co.uk/printthread.php?tid=6151 http://www.e90post.com/forums/showpost.php?p=11703525&postcount=5 Ako instaliras inpa sa ovim step 1,2,3 instalacijom, onda negde treba izabrati port. Ako nemas ovaj obd.ini file onda ne radi inpa. Pre instalacija treba uraditi: Part 1: Environmental Path Changes (pise na instructions.pdf) Na Part 1: First Install -> 1.2 Destination Path je c:temp (meni nije radio sa bmw tools-om). ostalo je ok. Video (od 3:54): https://youtu.be/wCP6uoEaAKw?t=3m54s Link to post Share on other sites
vandalizam 0 Posted March 14, 2016 Author Report Share Posted March 14, 2016 Ovo sto si ti postavio nece da radi na Win 10. Pokrenem install ali ga prekine.Moracu ocigledno na Win7 da se prebacim... Link to post Share on other sites
pimp 0 Posted April 4, 2016 Report Share Posted April 4, 2016 Uzeo INPU, i ne mogu da instaliram na Win 10 32bit. Na prvom koraku instaliranja, bmw toolsa, prijavljuje da radi na Win NT ili XP. Sta raditi dalje :) ? Link to post Share on other sites
325ixA 0 Posted April 4, 2016 Report Share Posted April 4, 2016 uzeti laptop za 30 eura na kom radi xp... Link to post Share on other sites
pimp 0 Posted April 4, 2016 Report Share Posted April 4, 2016 Skoro uzeo nov lap top, stari na kom je bio XP i 7, je riknuo.. :) Link to post Share on other sites
325ixA 0 Posted April 4, 2016 Report Share Posted April 4, 2016 mozes i da instasliras virutal machine pa na u njoj windows xp pa onda sve to. Sto ce reci, u okviru windowsa 10 pokreces xp pa pokreces dijagnostiku... Link to post Share on other sites
pimp 0 Posted April 4, 2016 Report Share Posted April 4, 2016 Probacu i to. Hvala. Ako zaskripi sta javljam :) Link to post Share on other sites
pimp 0 Posted April 4, 2016 Report Share Posted April 4, 2016 Instalirao XP na Virtual Box. Sad ne mogu iz njega da skinem win rar, adobe niti bilo sta sa neta, ne pokrece download. Kad ubacim u optical drive sa Win 10, nece da otovori instalaciju za aplikacije(rar, adobe), aplikacije su zza XP Link to post Share on other sites
325ixA 0 Posted April 4, 2016 Report Share Posted April 4, 2016 nadji negde u opcijama tog virtual boksa da deli copy/paste i drag&drop pa onda skini na 10 i prebaci tamo sta god ti treba. Link to post Share on other sites
pimp 0 Posted April 4, 2016 Report Share Posted April 4, 2016 Nasao, ali isto. Evo sta pise : Could not get the storage format of the medium 'C:\Users\Lalic\Desktop\Za XP\7z1514.exe' (VERR_NOT_SUPPORTED). Result Code: VBOX_E_IPRT_ERROR (0x80BB0005) Component: MediumWrap Interface: IMedium {4afe423b-43e0-e9d0-82e8-ceb307940dda} Callee: IVirtualBox {0169423f-46b4-cde9-91af-1e9d5b6cd945} Callee RC: VBOX_E_OBJECT_NOT_FOUND (0x80BB0001) Link to post Share on other sites
325ixA 0 Posted April 4, 2016 Report Share Posted April 4, 2016 Kupi laptop za 30€ Link to post Share on other sites
pimp 0 Posted April 4, 2016 Report Share Posted April 4, 2016 :D cackacu par dana ovo, ako ne ide moracu :) Nisam dugo petljao sa programima, instalacijama i ostalim, jos od srednje.. sad mi sve deluje komplikovano :) Link to post Share on other sites
