riverman 0 Posted June 23, 2008 Report Share Posted June 23, 2008 da li neko zna,kolika je kompresija kod M40,318i?zadnji put sam merio(pre 2 godine),ako se ne varam iznosilo je na sva 4 klipa nesto preko 12 ili 12.5,tako nesto.koja je donja granica tolerancije kad je u pitanju kompresija?hvala! :D Link to post Share on other sites
ugi 0 Posted June 23, 2008 Report Share Posted June 23, 2008 318i 1766 cm3 cylinders 4 power 77 kW (105 hp) at rpm 5800 rpm torque 145 Nm at rpm 4500 rpm max rpm 6200 rpm compression 9.5 bore 89 mm stroke 71 mm fuel system Bosch L-Jetronic Link to post Share on other sites
riverman 0 Posted June 23, 2008 Author Report Share Posted June 23, 2008 318i 1766 cm3 cylinders 4 power 77 kW (105 hp) at rpm 5800 rpm torque 145 Nm at rpm 4500 rpm max rpm 6200 rpm compression 9.5 bore 89 mm stroke 71 mm fuel system Bosch L-Jetronic moj ima 85kw.verovatno ima neke razlike u kompresiji,i kako da kod raznih majstora pokazuje vise nego sto pise u uputstvu!? Link to post Share on other sites
Ljilja 0 Posted June 23, 2008 Report Share Posted June 23, 2008 Ugi... ti si dao podatke za M10 motor a ne za M40 1.8 Link to post Share on other sites
ugi 0 Posted June 23, 2008 Report Share Posted June 23, 2008 moguce, provericu Link to post Share on other sites
FloMaster 0 Posted June 23, 2008 Report Share Posted June 23, 2008 Bore × stroke 84.00 mm × 81.00 mm 3.31 in × 3.19 in Cylinders S-4 Displacement 1796 cc (109.599 cu in) 2 valves per cylinder 8 valves in total Compression ratio 8.80:1 Maximum power 116.6 PS (115.0 bhp) (85.8 kW) @ 5800 rpm Specific output 64 bhp/litre 1.05 bhp/cu in Maximum torque 161.0 Nm (119 ft·lb) (16.4 kgm) @ 4250 rpm bmep 1126.5 kPa (163.4 psi) Specific torque 89.64 Nm/litre Coolant Water Bore/stroke ratio 1.04 Unitary capacity 449 cc/cylinder Aspiration Normal Compressor type N/A Intercooler None VALJDA JE TO ZA TVOJ MODEL. NISAM SIGURAN. Link to post Share on other sites
titanica73 0 Posted June 23, 2008 Report Share Posted June 23, 2008 Na motoru M40 1.8I kompresija treba da bude 8.8 po cilindru i to se meri kad je motor hladan,u protivnom rezultati merenja ce biti mnogo visi!!!! Link to post Share on other sites
hermes 0 Posted June 23, 2008 Report Share Posted June 23, 2008 Ne mesajte kompresioni odnos, podatak koji se daje uz tehnicki opis motora, i stepen dinamicke kompresije, odnosno pritiska koji se ostvaruje u cilindrima. Prvo je bezdimenzionalna brojka, a drugo je ono sto je bitno, i konkretno za M40 trebalo bi da iznosi najmanje 9 da bi to bio relativno dobar motor, sve ispod je za generalku, a dobar motor ima oko 11 recimo. I uzgred, kompresija treba da se meri na toplom motoru ( i mene je ovo iznenadilo), procitajte malo knjizice koje ste dobili uz kola, ili ono Hayness uputstvo koje svi imamo s neta Link to post Share on other sites
riverman 0 Posted June 23, 2008 Author Report Share Posted June 23, 2008 Ne mesajte kompresioni odnos, podatak koji se daje uz tehnicki opis motora, i stepen dinamicke kompresije, odnosno pritiska koji se ostvaruje u cilindrima. Prvo je bezdimenzionalna brojka, a drugo je ono sto je bitno, i konkretno za M40 trebalo bi da iznosi najmanje 9 da bi to bio relativno dobar motor, sve ispod je za generalku, a dobar motor ima oko 11 recimo.I uzgred, kompresija treba da se meri na toplom motoru ( i mene je ovo iznenadilo), procitajte malo knjizice koje ste dobili uz kola, ili ono Hayness uputstvo koje svi imamo s neta i ja sam cuo da ima razlike u podacima(tj.da se ne meshaju ti podaci,kompresiona i dinamicka kompresija ),a covek koji je merio reche da ima odlicnu kompresiju,kao sto sam vec rekao oko 12. :D Link to post Share on other sites
FloMaster 0 Posted June 24, 2008 Report Share Posted June 24, 2008 E sad mi nista nije jasno. Dinamicka kompresija i to... Ja znam za stepen kopresije, koja govori o sabijanju smese. Ako sam naveo podatak 8.8:1, znaci toliko sabija smesu u svakom cilindru, odn. menja zapreminu u odnosu na pocetnu (8.8). To sto navodis da ti je kompresija 12 mi nije jasno? Link to post Share on other sites
tesa 0 Posted June 24, 2008 Report Share Posted June 24, 2008 Stepen kompresije Rad koji se utrosi u procesu kompresije zavisi od tezine usisane smese i pritiska kompresije. Pritisak raste u zavisnosti od smanjivanja radne zapremine. Postoje tri karakteristicne radne zapremine cilindra i to: 1. Kompresiona zapremina Vk (zapremina u cilindru iznad klipa kada je on u GKP) 2. Radna zapremina Vr (koja odgovara zapremini u cilindru koja odgovara hodu klipa) 3 Ukupna zapremina Vu (jednaka zbiru kompresione i radne zapremine) Odnos ukupne i kompresione zapremine naziva se stepen kompresije. Stepen kompresije =Ukupna zapremina / kompresiona zapremina = Vu/ Vk Povecanje stepena kompresije rezultira u boljem iskorisavanju goriva što daje veće termicke koeficjente korisnosti. To medjutim povecava opterecenje pokretnih delova motora zbog povecanja radnog pritiska. Link to post Share on other sites
mihajlo24v 0 Posted June 24, 2008 Report Share Posted June 24, 2008 komsijo iz novog beograda,kako i gde da proverim kompresiju na m50 b25?! jel ima potrebe?! chipovan! Link to post Share on other sites
riverman 0 Posted June 24, 2008 Author Report Share Posted June 24, 2008 E sad mi nista nije jasno. Dinamicka kompresija i to... Ja znam za stepen kopresije, koja govori o sabijanju smese. Ako sam naveo podatak 8.8:1, znaci toliko sabija smesu u svakom cilindru, odn. menja zapreminu u odnosu na pocetnu (8.8). To sto navodis da ti je kompresija 12 mi nije jasno? pa ni meni nije jasno,ali tako je pokazivalo,licno sam gledao-oko 12. Link to post Share on other sites
hermes 0 Posted June 24, 2008 Report Share Posted June 24, 2008 Ajde ovako....tzv. staticka kompresija je bezdimenzionalni broj, i predstavlja odnos izmedju zapremina u cilindru kada je klip u gornjoj i donjoj mrtvoj tacki ( tj. polozaj klipa skroz gore i skroz dole). Dinamicka kompresija je pritisak koji ostvaruje klip kad se krece nagore i dodje u GMT. Izrazava se u barima, i nema veze sa onim brojem koji citas u podacima o motoru, jer je to kompresioni odnos samo. U svakom slucaju, kad bi ti dinamicka kompresija ( ona koja se meri kod majstora) bila recimo 8.8 koliko pise u prospektu, to bi znacilo da ti motor nista ne valja. Link to post Share on other sites
riverman 0 Posted June 25, 2008 Author Report Share Posted June 25, 2008 Ajde ovako....tzv. staticka kompresija je bezdimenzionalni broj, i predstavlja odnos izmedju zapremina u cilindru kada je klip u gornjoj i donjoj mrtvoj tacki ( tj. polozaj klipa skroz gore i skroz dole).Dinamicka kompresija je pritisak koji ostvaruje klip kad se krece nagore i dodje u GMT. Izrazava se u barima, i nema veze sa onim brojem koji citas u podacima o motoru, jer je to kompresioni odnos samo. U svakom slucaju, kad bi ti dinamicka kompresija ( ona koja se meri kod majstora) bila recimo 8.8 koliko pise u prospektu, to bi znacilo da ti motor nista ne valja. znaci,gleda se dinamicka kompresija(izrazena u barima),koja se kreche npr.ispod 7(katastrofa),izmedju 7 do 9(dobro).od 9 do 11.5(odlicno),iznad 11.5(super).po svemu tome ja sam to tako shvatio,tj.ovako plasticno kao sto sam naveo.ali opet se vracamo na pocetak.u kom se rasponu kreche DINAMICKA kompresija kod vechine bmw-a,jer se verovatno ona razlikuje od modela do modela i od marke raznih drugih vozila.npr.dodjes kod majstora i on ti kaze,brate, kompresija ti je katastrofa,iznosi 10,mora da se rastura :drinks: !auto vuche,ne trosi ulje i nastaju glavobolje i muchnina,nista ti nije jasno i slushash majstore i <majstore>,znachi,sledi shishanje. :D :D :D ne razumiju se svi vozaci u takve vec malo delikatnije stvari.o tome ja pricham.moj hvala bogu nema te probleme,ali zato i sluzi ovaj klub,da se sto bolje upoznaju nashi ljubimci i razni problemi koji neizostavno prate sva vozila od postanka automobila do danas.verovatno postoji neka tabela koja jednostavno prikazuje raspon dinamichke kompresije,od dobrog do loseg motora i zanimati che sve clanove.poz! Link to post Share on other sites
