324d 0 Posted July 20, 2008 Report Share Posted July 20, 2008 auto mi je palio do pre nekoliko dana na prvi zub sto se kaze... zimi isto tako, nikada nisam verglao, znaci samo okrenem kljuc i pali. sada kada je ladan vergla jedno 7-8 sekundi i onda pali. sta moze da bude u pitanju? meni se cini da je neki grejac riknuo. kako mogu da proverim i da li mogu sam da ga zamenim a da nesto ne zajebem... Link to post Share on other sites
ralekrusevac 0 Posted July 20, 2008 Report Share Posted July 20, 2008 moguce da je neki grejac izgoreo.ja sam zimus menjao svih 6.isti su kao kod kadeta 1,6d.ista sifra isto sve.platio sam ih oko 950 din komad. Link to post Share on other sites
ralekrusevac 0 Posted July 20, 2008 Report Share Posted July 20, 2008 tebe druze je poterao neki veliki maler u zadnje vreme? Link to post Share on other sites
BMW 528iA 0 Posted July 20, 2008 Report Share Posted July 20, 2008 Uzmes zicu od plusa i diras svaki grijac. Ako varnici radi, ako ne varnici onda ne radi. Link to post Share on other sites
324d 0 Posted July 20, 2008 Author Report Share Posted July 20, 2008 tebe druze je poterao neki veliki maler u zadnje vreme? jebe me godina proizvodnje, salim se, nije bas veliki al nije ni sve kako treba... polako dovescu ga ja u red Link to post Share on other sites
324d 0 Posted July 20, 2008 Author Report Share Posted July 20, 2008 Uzmes zicu od plusa i diras svaki grijac. Ako varnici radi, ako ne varnici onda ne radi. nisam te bas najbolje razumeo, odakle uzmem zicu od plusa... jel mogu ga ja promeniti ako nadjem koji je? Link to post Share on other sites
BMW 528iA 0 Posted July 21, 2008 Report Share Posted July 21, 2008 Plus od akumulatora. Pa naravno da mozes ti, ali preporucujem ti da stavis sve. Link to post Share on other sites
pravda91 0 Posted July 21, 2008 Report Share Posted July 21, 2008 Probaj da zamenis bobinu i razvodnu kapu Link to post Share on other sites
wice 0 Posted July 21, 2008 Report Share Posted July 21, 2008 koliko sam razumeo auto je dizel tako da nema bobinu ta proba sa zicom nije bas pouzdana jer se desi da krejac ne preori i da varnici kada se povezuje,ali da greje kraj grejaca do navoja tako da je to isto kao da ne radi.najbolje je da skines grejace i da proveris dali svi greju,kada su u redu potrebno je da se vrh usija,ili ako ti je lakse da skines dizne pa da pogledas kroz rupu od dizni dali crveni vrh,mada nisam siguran dali se vidi ispod dizni na bmw-u Link to post Share on other sites
100le 0 Posted July 22, 2008 Report Share Posted July 22, 2008 ajd sad ja malo, delimicno sam video kako to radi majstor kod mene. ima neki jack sa desne strane ispod plasticnog pokloca sa 6 rupa i lepo ispitivac u ruke das kontakt i krenes redom da zabijas taj ispitivac, tamo gde nesija taj je rikno samo neznam kako je odredio npr cetvrti, uglavnom skinuo je taj i zameno ga bez skidanja ostalih grejaca. drago mi je da sam pomogao ako jesam :D Link to post Share on other sites
324d 0 Posted July 23, 2008 Author Report Share Posted July 23, 2008 ajd sad ja malo, delimicno sam video kako to radi majstor kod mene.ima neki jack sa desne strane ispod plasticnog pokloca sa 6 rupa i lepo ispitivac u ruke das kontakt i krenes redom da zabijas taj ispitivac, tamo gde nesija taj je rikno samo neznam kako je odredio npr cetvrti, uglavnom skinuo je taj i zameno ga bez skidanja ostalih grejaca. drago mi je da sam pomogao ako jesam :D ok hvala, zato meni mozda i sija ona lampica zelena peta po redu na instrument tabli, neko mi je rekao da je taj grejac po redu i riknuo Link to post Share on other sites
hermes 0 Posted July 23, 2008 Report Share Posted July 23, 2008 E,taj te opravio :D To ti je znak da treba da menjas uskoro ulje, sto manje crtica, to je servisni interval blize ( ako je uopste resetovan pri promeni ulja). Nadji ovde negde postupak kako se resetuje INSPECTION, pa ce ti sve biti jasnije, bar sto se tice tih lampica na ins.tabli Link to post Share on other sites
DRAGANCE 0 Posted July 23, 2008 Report Share Posted July 23, 2008 ok hvala, zato meni mozda i sija ona lampica zelena peta po redu na instrument tabli, neko mi je rekao da je taj grejac po redu i riknuo e pa kazi tom liku da nikad vise ne pridje kolima .... ma ni biciklu ... Link to post Share on other sites
BMW 528iA 0 Posted July 25, 2008 Report Share Posted July 25, 2008 Taj lik treba u sanduk! Link to post Share on other sites
324d 0 Posted July 25, 2008 Author Report Share Posted July 25, 2008 koje su cene novih grejaca... Link to post Share on other sites
BMW 528iA 0 Posted July 25, 2008 Report Share Posted July 25, 2008 7-8 eura, plafon! Link to post Share on other sites
ralekrusevac 0 Posted July 25, 2008 Report Share Posted July 25, 2008 ja sam uzeo boshove za 950 dinara po komadu Link to post Share on other sites
324d 0 Posted July 25, 2008 Author Report Share Posted July 25, 2008 ajd sad ja malo, delimicno sam video kako to radi majstor kod mene.ima neki jack sa desne strane ispod plasticnog pokloca sa 6 rupa i lepo ispitivac u ruke das kontakt i krenes redom da zabijas taj ispitivac, tamo gde nesija taj je rikno samo neznam kako je odredio npr cetvrti, uglavnom skinuo je taj i zameno ga bez skidanja ostalih grejaca. drago mi je da sam pomogao ako jesam :preved: brate sad sem se drkao bas sa tim konektorima, ispod te kutije ima dva sklopa zica po 6 komada, jedan sklop je sa tanjim zicama a drugi sa debljim, tamo sa debljim sijaju mi sve a sa tanjim jedna sija ekstra jedna malo zizi a ostale cetiri ne sijaju uopste... Link to post Share on other sites
wice 0 Posted July 25, 2008 Report Share Posted July 25, 2008 probas na te sa debljim one su spojene na grejace,ali moze se desiti da grejac nije pregoreo ali ne greje gde treba kao sto sam ti napisao par postova iznad Link to post Share on other sites
324d 0 Posted July 25, 2008 Author Report Share Posted July 25, 2008 a kako to da sredim... Link to post Share on other sites
wice 0 Posted July 25, 2008 Report Share Posted July 25, 2008 jbg najbolje je da skines grejace pa da ih spojis na akumulator i vidis kako se ponasaju ,ako je ok trebao bi da usija vrh za 5-7 sekundi Link to post Share on other sites
324d 0 Posted July 25, 2008 Author Report Share Posted July 25, 2008 jel nije problem skinuti ih, necu valjda nesto zeznuti... Link to post Share on other sites
wice 0 Posted July 25, 2008 Report Share Posted July 25, 2008 pa nema sta otkacis kablove i odvijes grejace,pazi kada ih budes probao da se ne opeces Link to post Share on other sites
324d 0 Posted July 25, 2008 Author Report Share Posted July 25, 2008 vazi probacu sutra pa javljam sta sam uradio... Link to post Share on other sites
