Nidza crveni 0 Posted November 22, 2008 Report Share Posted November 22, 2008 Ul. Viteza Karadjo. Zvezde! Link to post Share on other sites
BMW 528iA 0 Posted November 22, 2008 Report Share Posted November 22, 2008 brate onda nema koga da okrivisalim se jedino ostaje problem ozracivanja a i malo je nezgodno ispustiti tec. iz bloka Ma nije, saraf je ispod izduvne grane. Link to post Share on other sites
boban81 0 Posted November 22, 2008 Report Share Posted November 22, 2008 ljljo mirijevski venac je na karaburmi mirijevski venac jeste u mirijevu, a mirijevski bulevar je na karaburmi. Link to post Share on other sites
batabmw 0 Posted November 23, 2008 Report Share Posted November 23, 2008 mirijevski venac jeste u mirijevu, a mirijevski bulevar je na karaburmi. moja greska ja se izvinjavam Link to post Share on other sites
p200 0 Posted November 24, 2008 Author Report Share Posted November 24, 2008 Resio ja to ljudi u dvoristu...Lepo ugrejem auto,zavucem crevo u hladnjak i cugaj dok nije procurelo i vadio sam i dosipao litar po litar a za to vreme auto radio....ukupno sam zamenio oko 6 litara starog antifriza s ovim svezim...Na kraju odem do pumpe,kupim onu epruvetu za proveru tecnosti i po skali pokazuje -37 e sad ako udari minus ispod te temp. jbga...Nije bilo ozracivanja niti problema sa hladjenjem motora evo vec vise od 24 sata a presao sam oko 150km po gradu...Valjda sam ovaj posao dobro uradio... HVALA ljudima koji su mi izasli u susret i savetima i iskustvima mi pomogli puno oko resavanja ovog problema VELIKI POZDRAV SVIMA Link to post Share on other sites
marko13 0 Posted November 24, 2008 Report Share Posted November 24, 2008 Ako ti radi grejanje onda je sve ok. Mislim dobro je ozracen. Link to post Share on other sites
BMW 528iA 0 Posted November 24, 2008 Report Share Posted November 24, 2008 Ma mora da se odzraci. Link to post Share on other sites
p200 0 Posted November 24, 2008 Author Report Share Posted November 24, 2008 Ako bas mora i ako te ne mrzi objasni mi kako to da odradim Link to post Share on other sites
batabmw 0 Posted November 24, 2008 Report Share Posted November 24, 2008 ovako kako si ti radio nemora da se ozracuje Link to post Share on other sites
bmw 330d 0 Posted November 24, 2008 Report Share Posted November 24, 2008 E i mene ovo zanima posto nisam znao da ide u Bmw poseban Antifriz , ja sam vec zamijenio ali sam stavio neki bezveze sad dali bi trebao ponovo to sve zamijeniti ili sta da radim ??? I gdje se moze kupiti taj bmw Antifriz.. Link to post Share on other sites
batabmw 0 Posted November 24, 2008 Report Share Posted November 24, 2008 E i mene ovo zanima posto nisam znao da ide u Bmw poseban Antifriz , ja sam vec zamijenio ali sam stavio neki bezveze sad dali bi trebao ponovo to sve zamijeniti ili sta da radim ??? I gdje se moze kupiti taj bmw Antifriz.. rekao bih ti ali obrisace post Link to post Share on other sites
BMW 528iA 0 Posted November 24, 2008 Report Share Posted November 24, 2008 Ako bas mora i ako te ne mrzi objasni mi kako to da odradim Objasnio sam nekoliko puta. Imas search pa.... Link to post Share on other sites
marko13 0 Posted November 25, 2008 Report Share Posted November 25, 2008 Imas u skoro svakoj radnji bmw delova ima jedna kod zvezdinog stadiona ne znam kako se zove ima i u sarajevskoj i u zemunu ali se nesecam ni one kako se zovu. U krajnjem slucaju idi kog naseg generalnog uvoznika i kod njih je ista cena kao i kod ovih. Link to post Share on other sites
p200 0 Posted November 25, 2008 Author Report Share Posted November 25, 2008 daj neki link za to ozracivanje jer preko ovog search nema sanse da se snadjem...HVALA Link to post Share on other sites
marko13 0 Posted November 25, 2008 Report Share Posted November 25, 2008 To je tacno, onaj search je beskoristan totalno. Link to post Share on other sites
