toscha711 0 Posted February 14, 2009 Report Share Posted February 14, 2009 DAKLE ZBOG VEROVATNOG RIKNJAVANJA PUMPE ZA BENZIN, UPALIM JA DIREKTNO PAR PUTA SEKVENT NA PLIN... I SLEDECE JUTRO NECE NI NA PLIN, A SMRDELO NA PLIN MALO KAD PREDJE NA PLIN... OTVORIM JA HAUBU, KAD ONO MEDJUTIM! U PONEDELJAK MENJAM PUMPU, ALI STA JE OVO SA PLINOM... INACE VIDEO SAM GDE CURI, I TO POSLE ISPARIVACA IDE CREVO NA NESTO STO LICI NA FILTER... E PA NA ULAZU U TAJ FILTER CURKA... PLINA SKORO I DA NEMA...A SIPANO JE VISE OD 20 LITARA A PRESO JE 50 KM, NIJE NI CUDO JER CURI... OPASNOSTI, STETA??? EVO SLIKE! http://i306.photobucket.com/albums/nn245/t...40220091492.jpg http://i306.photobucket.com/albums/nn245/t...40220091493.jpg http://i306.photobucket.com/albums/nn245/t...40220091494.jpg Link to post Share on other sites
Borko Vrsac KUM 0 Posted February 14, 2009 Report Share Posted February 14, 2009 nemoze nista strasno da se desi samo da ti se upali auto!!!! resavaj to pod HITNO!!! Link to post Share on other sites
toscha711 0 Posted February 14, 2009 Author Report Share Posted February 14, 2009 PA NE VOZIM GA, MOZE VALJDA SAMO PLIN DA ISCURI CEO, AKO VEC I NIJE... MENE ZANIMA IMA LI STETE NA UREDJAJU Link to post Share on other sites
Borko Vrsac KUM 0 Posted February 14, 2009 Report Share Posted February 14, 2009 to ce cika babic strucno da ti objasni kada bude video temu kolika moze da bude steta. P.S. ugasi Caps Lock Link to post Share on other sites
Borko Vrsac KUM 0 Posted February 14, 2009 Report Share Posted February 14, 2009 sad vidim prezime da nismo u nekom srodstvu Todorovicu? Link to post Share on other sites
error 0 Posted February 14, 2009 Report Share Posted February 14, 2009 nigde ne curi plin zaledio je plinski isparivach usled nedostatka vode u sistemu za hladjenje polivaj ga toplom vodom da odledi upali ga i drzi mu gas svo vreme kako bi progutao vishak plina i zagrejao vodu Link to post Share on other sites
error 0 Posted February 14, 2009 Report Share Posted February 14, 2009 prvo mu skini crevo sa dizni dok ga polivash vruchom vodom tu che pocheti da qlja ziv plin usled otapanja unutar samog isparivacha kada prestane, proveri koliko vode imash u hladnjaq, ako fali dospi vrati crevo na dizne i pali ga ali mu drzi gas na oko 2500 rpm da se zagreje shto se shtete tiche, nechesh je osetiti, ali svaka ovakva tortura rasprshivacha prouzroqje ubrzavanje propadanja membrana plina tu nije moglo puno da izadje plina i dalje imash Link to post Share on other sites
ivan79 0 Posted February 14, 2009 Report Share Posted February 14, 2009 babic je u pravu. takodje proveri dali su dobro povezana creva od vode sto idu na isparivach i odakle idu ta creva za vodu jer se desi da majstori premoste creva za toplu vodu na pogresnom mestu i onda nema dovoljno tople vode kako bi se isparivach zagrejao usled chega isparivach ledi. Link to post Share on other sites
toscha711 0 Posted February 14, 2009 Author Report Share Posted February 14, 2009 hvala vam svima na savetima, bas ste drugari... sutra cu da ga polivam... sto se creva tice, sve sljaka vec godinu dana besprekorno tojest vise od 20000km, tako da kapiram da je to sve ok... probacu sutra ovo polivanje isparivaca, mada je plina bilo pre 2 dana i to 25 litara... a sad dodiruje dno pokazivaca ce da vidimo, jos jednom fala Link to post Share on other sites
sone_666 0 Posted February 14, 2009 Report Share Posted February 14, 2009 E PA NA ULAZU U TAJ FILTER CURKA... PLINA SKORO I DA NEMA...A SIPANO JE VISE OD 20 LITARA A PRESO JE 50 KM, NIJE NI CUDO JER CURI...OPASNOSTI, STETA??? EVO SLIKE! proveri ti za svaki slucaj da li negde curi, ako si presao 50km sa 20l kako kazes onda definitivno negde curi Link to post Share on other sites
toscha711 0 Posted February 15, 2009 Author Report Share Posted February 15, 2009 pa jedino je curilo na crevu posle isparivaca na ulazu u filter... verovatno je zato...samo sad tu manje curi, jer je i stanje plina na minimumu, ako ga uopste ima Link to post Share on other sites
error 0 Posted February 15, 2009 Report Share Posted February 15, 2009 posle isparivacha on je na 1.2 bara i topao bar je takav kada je sve u redu Link to post Share on other sites
error 0 Posted February 15, 2009 Report Share Posted February 15, 2009 ...i topao. Link to post Share on other sites
toscha711 0 Posted February 15, 2009 Author Report Share Posted February 15, 2009 verovatno dok radi isparivac, tojest motor... ali ovo je curilo dok ne radi motor i plinski uredjaj, tojest kad su slikane one slike Link to post Share on other sites
error 0 Posted February 15, 2009 Report Share Posted February 15, 2009 ako se to desilo dok ne radi motor onda je plinski ventil zaglavio Link to post Share on other sites
Nidza crveni 0 Posted February 15, 2009 Report Share Posted February 15, 2009 Druze nemoj da cackas nista da nebi leteo kao ovi sa Vozdovca pre neki dan! Link to post Share on other sites
toscha711 0 Posted February 15, 2009 Author Report Share Posted February 15, 2009 ako je ventil, necu da diram sam, a babicu? nego sutra kod bate nova pumpa, pa cemo da vidimo za dalje Link to post Share on other sites
toscha711 0 Posted February 15, 2009 Author Report Share Posted February 15, 2009 @ babic - ja ne znam kad se to desilo... on je normalno isao na plin, bez obzira da li sam palio prvo na corbu ili direkt na plin. samo znam da je isao ok, parkirao sam ga i video zavejani isparivac :lol2: Link to post Share on other sites
leon63 0 Posted February 15, 2009 Report Share Posted February 15, 2009 I resi li problem? Link to post Share on other sites
toscha711 0 Posted February 15, 2009 Author Report Share Posted February 15, 2009 ma jok... sutra dobija pumpu, pa ce da ide malo na benzu... a ako budes smeo, policu taj isparivac vrelom pa cu da vidim... Link to post Share on other sites
hermes 0 Posted February 15, 2009 Report Share Posted February 15, 2009 Pa kad ga budes vozio na benzinu, automatski ce da se zagreje, tako da ne moras da ga polivas. Link to post Share on other sites
toscha711 0 Posted February 16, 2009 Author Report Share Posted February 16, 2009 @hermes - imas pravo, vrelo ce da krene, al da li ce da odglavi ventil? pa videcemo... na benzin neka krene, pa ako prebaci, super ako ne, u servis za plin, pa nek se oni cimaju Link to post Share on other sites
Ljilja 0 Posted February 16, 2009 Report Share Posted February 16, 2009 Druze nemoj da cackas nista da nebi leteo kao ovi sa Vozdovca pre neki dan! OVO !!!!!! ako je ventil, necu da diram sam, a babicu? JA ti kazem da ne diras nista sam!!! Link to post Share on other sites
