DangaraBMW 0 Posted November 28, 2010 Report Share Posted November 28, 2010 Kao što i rekoh,crkla je vodena pumpa...je li teško naći novu i je li to u krv skupo?...pogledaću sjutra po radnjama da kupim novu a ako ne nadjem biće mi potrebna vaša pomoć...da mi pošaljete novu,polovnu ili šta već...i,još jedno pitanje,da li je teško zamijeniti?..hvala... Link to post Share on other sites
StunterSM 0 Posted November 28, 2010 Report Share Posted November 28, 2010 Mora da si skoro menjao vodu i stavio antifriz? Link to post Share on other sites
DangaraBMW 0 Posted November 28, 2010 Author Report Share Posted November 28, 2010 Mora da si skoro menjao vodu i stavio antifriz? Upravo tako Miki...što pitaš? Link to post Share on other sites
StunterSM 0 Posted November 28, 2010 Report Share Posted November 28, 2010 Oce to tako.. Sipaj g12 koncentrovani antifriz (razblazis ga sa 1:1 destilovane i nece biti problema, a ne onaj plavi sto se kupuje razredjen vec.. Link to post Share on other sites
DangaraBMW 0 Posted November 28, 2010 Author Report Share Posted November 28, 2010 Oce to tako.. Sipaj g12 koncentrovani antifriz (razblazis ga sa 1:1 destilovane i nece biti problema, a ne onaj plavi sto se kupuje razredjen vec.. Važi brate,al' moram prvo pumpu srediti... Link to post Share on other sites
StunterSM 0 Posted November 28, 2010 Report Share Posted November 28, 2010 Naravno, nino bi trebao da ima i novu i polovnu pumpu, samo se za transport dogovorite Link to post Share on other sites
DangaraBMW 0 Posted November 28, 2010 Author Report Share Posted November 28, 2010 Naravno, nino bi trebao da ima i novu i polovnu pumpu, samo se za transport dogovorite Važi,ujutro idem da vidim ima li nova da se kupi odje kod mene,pa ako ne nadjem dogovoriću se sa Ninom... Link to post Share on other sites
CasperBg82 0 Posted November 28, 2010 Report Share Posted November 28, 2010 Nova SKF je bila oko 40e, ali to se uspesno remontuje, tj. samo se zameni semering koji je procureo Link to post Share on other sites
DangaraBMW 0 Posted November 28, 2010 Author Report Share Posted November 28, 2010 Sta mi ti predlazesh Casper,da trazim taj semering ili da je mijenjam skroz?...pitanje je ima li to dje da se kupi,kao i koliko se nova pumpa moze naci...? Link to post Share on other sites
CasperBg82 0 Posted November 28, 2010 Report Share Posted November 28, 2010 Pa ne znam koliko ima delova za bmw u Niksicu ;) A semering mislim da ne mozes sam zameniti, vidi ako ima neko da radi remont Po meni je glupo dati 40e zbog jednog semeringa, kad procuri semering na radilici ili menjacu menjas njega a ne ceo motor ili menjac Link to post Share on other sites
DangaraBMW 0 Posted November 28, 2010 Author Report Share Posted November 28, 2010 To je istina brate,ali meni se cini da je i lezaj otisao,cini mi se da remenica ima malo lufta... Link to post Share on other sites
CasperBg82 0 Posted November 28, 2010 Report Share Posted November 28, 2010 Pa normalno da se menja i lezaj, skini je ti lepo sutra pa put pod noge po gradu ;) Link to post Share on other sites
DangaraBMW 0 Posted November 28, 2010 Author Report Share Posted November 28, 2010 Tako ce i bit'...reci mi,je li je tesko skinuti?...nijesam nikad skidao... Link to post Share on other sites
CasperBg82 0 Posted November 28, 2010 Report Share Posted November 28, 2010 http://bmwfans.info/parts/catalog/E30/4-doors/Europe/318i-M10/LHD/M/1986/december/browse/engine/cooling_system_water_pump/ Link to post Share on other sites
DangaraBMW 0 Posted November 28, 2010 Author Report Share Posted November 28, 2010 http://bmwfans.info/parts/catalog/E30/4-doors/Europe/318i-M10/LHD/M/1986/december/browse/engine/cooling_system_water_pump/ Hvala Casper... Link to post Share on other sites
DangaraBMW 0 Posted November 29, 2010 Author Report Share Posted November 29, 2010 Zamijenjena vodena pumpa,moja je bila katastrofa,slikaću pa ću okačiti...kupio sam novu,32.50€...nema nidje SKF-ove pa sam uzeo neku italijansku "Graf"...mislim da je to sranje jedno,al' vidjećemo...hvala na instrukcijama... :) Link to post Share on other sites
NINO BMW 0 Posted November 29, 2010 Report Share Posted November 29, 2010 Oce to tako.. Sipaj g12 koncentrovani antifriz (razblazis ga sa 1:1 destilovane i nece biti problema, a ne onaj plavi sto se kupuje razredjen vec.. BMW-ov antifriz je g11-Plavi,dok crveni g12 ide kod VW,Mercedes,Ford.e sad i tu ima normalno bolji od boljeg a najbolje je original BMW. Link to post Share on other sites
StunterSM 0 Posted November 29, 2010 Report Share Posted November 29, 2010 Da ali on je sipao G11 obican onaj na pumpi sto se kupi po 100din/L. Koliko kosta orginal BMW? G12 mislim da ima visu tacku kljucanja i blazi je prema materijalima. I bilo je ne jedan nego 10 slucajeva da strada pumpa i hladnjak par dana od menjanja rashladne tecnosti Link to post Share on other sites
necam3 0 Posted November 29, 2010 Report Share Posted November 29, 2010 Da ali on je sipao G11 obican onaj na pumpi sto se kupi po 100din/L. Koliko kosta orginal BMW? G12 mislim da ima visu tacku kljucanja i blazi je prema materijalima. I bilo je ne jedan nego 10 slucajeva da strada pumpa i hladnjak par dana od menjanja rashladne tecnosti BMW oridji u delti kosta 760 dindzi 1,5l, nije puno svake dve godine da se zameni to je najmanji trosak. Link to post Share on other sites
DangaraBMW 0 Posted November 29, 2010 Author Report Share Posted November 29, 2010 @ Miki Da,sipao sam bio G11 antifriz ali nije bio bas 100din/l...nijesam bas takva skrtica :)...sipao sam Exol,3.00€/litar... Link to post Share on other sites
NINO BMW 0 Posted November 30, 2010 Report Share Posted November 30, 2010 Najeftiniji je originalni antifriz.U mom autu je od 2006 godine,nikad nisam dolivao,na njegovom merenju na koliko mrzne kazaljka je pokazala -30stepeni i to posle četiri godine tako da ne važi ono pravilo da se nov antifriz mora svake zime sipati,dok kod krdže koja se sipa to se stvarno mora činiti pred svaku zimu,pa vidite šta je isplativije,zatim loš antifriz utiče na brže stradanje svih delova kroz koje cirkuliše tečnost,pumpa za vodu,termostat,hladnjak,plastične račve.... Link to post Share on other sites
StunterSM 0 Posted November 30, 2010 Report Share Posted November 30, 2010 Nino koliko kosta kod tebe i koliko mi treba za moj auto?? Link to post Share on other sites
DangaraBMW 0 Posted November 30, 2010 Author Report Share Posted November 30, 2010 U pravu ste momci,tu nema price...naravno da je bolje usuti original...kasnije cu izbaciti slike vodene pumpe shto sam skinuo sa auta...katastrofa...a nije joj ni cudo,na njoj pishe godina '84 :)...ko zna sta je sve sipano u rashladni sistem od tada...ja samo znam da je moj pokojni tata sipao stalno Permant... Link to post Share on other sites
DangaraBMW 0 Posted November 30, 2010 Author Report Share Posted November 30, 2010 Evo i kako izgleda stara pumpa: Link to post Share on other sites
DangaraBMW 0 Posted December 2, 2010 Author Report Share Posted December 2, 2010 Ljudi,auto mi sad radi savršeno...da ga ne ureknem :)...otkad sam zamijenio vodenu pumpu počinuo sam,prije se čuo ležaj pumpe a sad je auto mnogo tiši,milina...:) Link to post Share on other sites
