zeljko_srb 0 Posted October 31, 2009 Report Share Posted October 31, 2009 primetio sam da mi je mokra patosnica bas kod patosnice za gas. danas sam prao kola, nije kisa padala, nisam isao kroz nikakve lokve. a vlzna je patosnica. od cega to? kako da zacepim rupu ili sta je vec? jel se sliva od neceg? Link to post Share on other sites
Iga 0 Posted October 31, 2009 Report Share Posted October 31, 2009 procackaj malo po forumu ima na par mesta prica o tome... Link to post Share on other sites
zeljko_srb 0 Posted October 31, 2009 Author Report Share Posted October 31, 2009 nema nigde te teme. Link to post Share on other sites
BMW-E36 0 Posted October 31, 2009 Report Share Posted October 31, 2009 Nedje ti je sig zacepljena kanalica ispod soferke pa ti nedje zadrzava vodu... Link to post Share on other sites
Ljilja 0 Posted November 1, 2009 Report Share Posted November 1, 2009 o tome ovde... http://www.bmwclubserbia.com/forum/index.p...c=6662&st=0 Link to post Share on other sites
miksa 0 Posted November 1, 2009 Report Share Posted November 1, 2009 nisam neki strucnjak,ali mozda mogu da pomognem.mozda je u pitanju hladnjak od grejanja,mozda je on procurio... Link to post Share on other sites
zeljko_srb 0 Posted November 1, 2009 Author Report Share Posted November 1, 2009 koliko sam skontao po svim postovima, u ostale dve teme. problem je u nekom odvodu. gde je to crevo? kako da ga ocepim ili ste je vec problem? Link to post Share on other sites
wice 0 Posted November 1, 2009 Report Share Posted November 1, 2009 ako imas siber,moguce da je crevo od odvoda sibera,nalazi se sa leve strane iza plastike kod rucice za otvaranje haube,i spusta se u sajtnu. Link to post Share on other sites
zeljko_srb 0 Posted November 1, 2009 Author Report Share Posted November 1, 2009 imam siber. ali meni je vlaga tacno kod papucice za gas. bas oko nje. Link to post Share on other sites
eone 0 Posted November 1, 2009 Report Share Posted November 1, 2009 Proveri cevi od grejanja sto idu u mali hladnjak i creva pod haubom sto idu na njih, mozda se odatle sliva. Ili imas neku rupu u kosu, ili kedar soferke.. Link to post Share on other sites
zeljko_srb 0 Posted November 8, 2009 Author Report Share Posted November 8, 2009 juce sam u garazi gledao i gledao, i skontam da je mali hladnjak problem. znaci kod papucice za gas pa desno, gore, sve je mokro. kad stisnem prstom voda se sve sliva, i lepljivo je i zeleno, pogledam u hladnjak opao nivo, liznem prste, isti ukus kao u hladnjaku antifriz. znaci da je hladnjak za grejanje problem, taj mali hladnjak... e sad, ako moram da vadim celu instrument tablu napolje da bi dosao do njega, ne pada mi napamet da radim to. neka curi, proce zima, pa nece curiti. jel postoji neki drugi nacin? kako mogu da znam da li je neko crevo? gde tacno stoji taj hladnjak? i jos sta mi je palo napamet. ako na primer flisuje taj mali hladnjak. jel mogu da kupim onaj kao pesak sto se naspe u hladnjak i sam zavari gde je pukao. pa mozda da krnem dve tri tube u hladnjak da zacepi taj mali.... sta kazete na to? Link to post Share on other sites
wice 0 Posted November 8, 2009 Report Share Posted November 8, 2009 mozes probati sa tim,ali nije resenje,ako ne zadihtuje,i bude curilo i dalje onda ce ti magliti stakla kada pustis grejanje. mislim da nije potrebno skidati celu tablu Link to post Share on other sites
zeljko_srb 0 Posted November 8, 2009 Author Report Share Posted November 8, 2009 nego sta da uradim onda? daj nek se javi neko ko ima resenje za ovaj problem... Link to post Share on other sites
wice 0 Posted November 8, 2009 Report Share Posted November 8, 2009 pa ako ne zadihtuje prah,onda ces morati da skidas grejac,treceg nema.ili da ga otkacis,ali sta ce ti auto bez grejanja zimi. pozdrav Link to post Share on other sites
eone 0 Posted November 8, 2009 Report Share Posted November 8, 2009 Posto nisi strucan, pravo kod majstora da zameni hladnjak, i resen problem. Link to post Share on other sites
zeljko_srb 0 Posted November 8, 2009 Author Report Share Posted November 8, 2009 da to je najbolje, kontam da me to nece izaci ni najmanje 100e krpljenje i skidanje table i svega ostalog. Link to post Share on other sites
zeljko_srb 0 Posted November 8, 2009 Author Report Share Posted November 8, 2009 taj mali hladanjak gde se tacno nalazi? jel bi mogao nekako direktno u njega da sipam taj prah za lepljenje hladanjaka? jer ako sunem jedno pakovanje u veliki hladnjak, kontam da nece nista otici u taj mali, vec da ce se sve zadrzati u velikom hladnjaku. koliko bi smeo da sipam pakovanja tih zaptivaca, a da ne zapusim hladnjak ili nesto...? Link to post Share on other sites
eone 0 Posted November 8, 2009 Report Share Posted November 8, 2009 :) Link to post Share on other sites
zeljko_srb 0 Posted November 9, 2009 Author Report Share Posted November 9, 2009 sta okreces ocima? Link to post Share on other sites
eone 0 Posted November 9, 2009 Report Share Posted November 9, 2009 Ne sipaj nikakve zaptivace, jeftinije je. Link to post Share on other sites
zeljko_srb 0 Posted November 9, 2009 Author Report Share Posted November 9, 2009 od danas je pocelo i da magli nenormalno kod vozaceve strane, i na zadnje staklo isto kod vozaceve strane. gde se nalazi tacno taj hladanjak,... kako mu mogu prici? Link to post Share on other sites
wice 0 Posted November 9, 2009 Report Share Posted November 9, 2009 nalazi se iza centralne konzole,iznad tunela za kardan,izvadi centralnu kasetu tj plastiku,tj sve ispod kasetofona,znacu onu policu gde ti je bord,i sto ide oko menjaca pa ces videti,on je tacno iznad onog mesta gde ti curi i gde je mokro Link to post Share on other sites
zeljko_srb 0 Posted November 9, 2009 Author Report Share Posted November 9, 2009 pa onda ne moram celu instrument tablu napolje... kako su mi pricali. Link to post Share on other sites
miksa 0 Posted November 9, 2009 Report Share Posted November 9, 2009 druze ja sam imao slican problem,ali kod mene nije curilo,vec nije radio ventil grejanja,pa kad smo zamenili,skinuli smo da vidimo da ne curi hladnjak za svaki slucaj,zato sto od kad sam kupio auto grejanje nije radilo...hladnjak je kad sednes na vozacevo sediste ispod volana sa desne strane,koliko se ja secam,treba samo da se skine plastika ispod volana i on se nalazi pricvrscen za onaj centralni sredisnji deo,nadam se da je to to :) Link to post Share on other sites
zeljko_srb 0 Posted November 9, 2009 Author Report Share Posted November 9, 2009 znaci ipak ne mora cela instrument tabla napolje... dobro je. Link to post Share on other sites
