vranjin 0 Posted December 4, 2011 Report Share Posted December 4, 2011 (edited) Ja samo da pitam dje se kupuju te diode? U prodavnici. :lol: Ako ustanem sutra na vreme idem do *prodavnice* i saljem ti diode. Ako hoces? zeznuh se, tu nesto pricam i ponovo postovao. Edited December 4, 2011 by vranjin Link to post Share on other sites
DangaraBMW 0 Posted December 4, 2011 Report Share Posted December 4, 2011 :D Ada neću ić' u apoteku da to kupim :)...nego pitah da bih znao dje toga ima, ako je neko kupovao... Vanja, nemoj se mučiti, kupiću to ja ovih dana u nekoj "prodavnici" pa javljam šta sam uradio...:) Hvala brate... Link to post Share on other sites
vranjin 0 Posted December 4, 2011 Report Share Posted December 4, 2011 Ok. Inace nije mi problem jer moram ici svakako da kupim sebi neke delove. Ni slanje mi nije problem jer iz firme ide svaki dan kombi za Nk. Ako ne nadjes javi se. Link to post Share on other sites
DangaraBMW 0 Posted December 4, 2011 Report Share Posted December 4, 2011 Važi brate...zahvaljujem :) Link to post Share on other sites
CasperBg82 0 Posted December 4, 2011 Report Share Posted December 4, 2011 Nista nisam napravio, nece pa nece, zezao sam se 3 sata.. plus mi od drndanja zakovao jedan zadnji motorcic, morao sam iznutra da skidam tapacir. Moram jos da razmisljam :D Link to post Share on other sites
vranjin 0 Posted December 4, 2011 Report Share Posted December 4, 2011 Otkaci zadnje motorice dok radis. Imas li instrument? Ako imas pipalice u sake i teraj redom. Otkljucavanje, s303 treba da ima 12V a s302 da je na masi itd itd. Kreni odatle. Jesi li probao da otkacis modul centralne i samo da je daljinski u funkciji? Link to post Share on other sites
CasperBg82 0 Posted December 4, 2011 Report Share Posted December 4, 2011 Kad na dzeku dovedem plus direktno na plavu on zakljuca, a kad dovedem na belu on nece da otkljuca A posto normalno otkljucava znaci da je instalacija u redu, jer sve ide kroz plavu i belu, izgleda da ne vraca plavu na masu, tako da kad treba da otkljuca on pusti plus kroz belu ali mase nema Moracu jos da pogledam oko centrale Link to post Share on other sites
vranjin 0 Posted December 4, 2011 Report Share Posted December 4, 2011 A posto normalno otkljucava mislis zakljucava. Obrati paznju na modul centrale tj po semi gde dolaze crna i bela na modul, tamo ima dva relejcica lock i unlock. Ako mozes nekako pogledati relej za lock jer preko njegovog mirnog kontakta dobija masu za otkljucavanje. pozz Link to post Share on other sites
CasperBg82 0 Posted December 4, 2011 Report Share Posted December 4, 2011 To sam mislio :) Ma resicu ga, nego se iznerviram kad uzmem tako da prckam a ne isplaniram nista, bolje lepo da razmislim, danas sam drndao to par sati i gledao instalaciju a mogao sam odmah zakljuciti da je instalacija u redu posto normalno zakljucava Link to post Share on other sites
vranjin 0 Posted December 4, 2011 Report Share Posted December 4, 2011 Malo si upoznao taj deo instalacije. Dok miruju motorici probaj instrumentom i plavu i belu prema masi. Trebalo bi da su obe na masi. Link to post Share on other sites
325ixA 0 Posted December 4, 2011 Report Share Posted December 4, 2011 ako zaredom 8 puta otkljucas/zakljucas zakovace ti motorici Link to post Share on other sites
vranjin 0 Posted December 4, 2011 Report Share Posted December 4, 2011 Vidi ovo, po semi su obe stalno na masi a ti si rekao da si direktno doveo plus na plavu. Da je sve normalno roknuo bi ti osigurac. To opet ukazuje na relej u modulu za lock. Link to post Share on other sites
vranjin 0 Posted December 4, 2011 Report Share Posted December 4, 2011 ako zaredom 8 puta otkljucas/zakljucas zakovace ti motorici Zasto ce zakovati? neka otkaci motorice na zadnjim vratima. Link to post Share on other sites
CasperBg82 0 Posted December 4, 2011 Report Share Posted December 4, 2011 Bas 8 puta? :) On zakuje zato sto se kao sto si rekao "zapecati" Uspeo sam kad sam ga skinuo plusom i minusom direktno da ga otpecatim :) Link to post Share on other sites
CasperBg82 0 Posted December 4, 2011 Report Share Posted December 4, 2011 U svakom motorcicu ima dva elektromotora, jedan koji otvara-zatvara a drugi koji ga zakljucava Na kraju ce ipak ispasti da je andrmolja kriva :D verovatno relej ne vraca na minus kako treba, ili moj koji sam stavio ili relej u fabrickoj centrali Link to post Share on other sites
vranjin 0 Posted December 4, 2011 Report Share Posted December 4, 2011 Ne znam kako ti je povezan relej od daljinskog ali nemoguce je da su oba zakazala. Trebalo bi da je nekako uskladjen sa centralom da ne bi dolazilo do kratkog spoja. Mozda sam dosadan ali ponavljam da masu za otklucavanje dobija preko releja u modulu za lock i njega treba proveriti. Link to post Share on other sites
CasperBg82 0 Posted December 4, 2011 Report Share Posted December 4, 2011 Povezao sam dva releja po jedan na plavu i belu zicu.. Kad dobiju komandu sa modula od daljinskog odspoje plavu ili belu zicu od fabricke (minusa) i spoje na plus i motorcici odrade, posle toga se vrati na minus A pre toga diode da kad se pojavi plus iz fabricke ne ode na minuse od modula za daljinsko Link to post Share on other sites
vranjin 0 Posted December 4, 2011 Report Share Posted December 4, 2011 Nisam mogao ranije pisati, dosao sam na posao. Znaci tebi masu za motorice dobija preko modula. Mozes li skinuti modul i pogledati one releje? Link to post Share on other sites
vranjin 0 Posted December 4, 2011 Report Share Posted December 4, 2011 Ej Dangara jesi li tu? Zasto ne rece da je nedelja i ne rade prodavnice? :prankster2: Zato nadjoh dioda u Vanjinom ducanu. Ima ih pun djavo, zaboravio sam za njih. Ne moras ih traziti, ako hoces poslacu ti ih. Mogu vec sutra biti kod tebe. Necu da se namecem ali to je stvarno sitnica i ne treba da se ustrucavas. Link to post Share on other sites
325ixA 0 Posted December 4, 2011 Report Share Posted December 4, 2011 procitao sam negde da je 8 puta, u principu par puta kad brzo odradis otkljucavanje/zakljucavanje zakuca neki motor. spojis da direktno, kvrcne i radi ponovo. rekoh ja da je to andrmolja. Link to post Share on other sites
CasperBg82 0 Posted December 4, 2011 Report Share Posted December 4, 2011 Povadicu opet centrale, ima da proradi, ili sa jedne ili sa druge :) Rekoh, opet sam ljut na sebe, kad sam ih vadio proverio sam da li salje plus ali ne i da li ima minus na drugoj Za sve je kriv nesistematican pristup problemu :prankster2: Link to post Share on other sites
vranjin 0 Posted December 4, 2011 Report Share Posted December 4, 2011 (edited) Povadicu opet centrale, ima da proradi, ili sa jedne ili sa druge :) Rekoh, opet sam ljut na sebe, kad sam ih vadio proverio sam da li salje plus ali ne i da li ima minus na drugoj Za sve je kriv nesistematican pristup problemu :prankster2: Da te ne kritikujem sad ali jos u prvom mom postu ti je to pisalo. Nastavljas li veceras? Da znam da li da pratim posto sam na poslu. pozz Nemoj da se nerviras, utice na lepotu. Resice se to. Edited December 4, 2011 by vranjin Link to post Share on other sites
CasperBg82 0 Posted December 4, 2011 Report Share Posted December 4, 2011 Sutra cu :) Hvala na podrsci :) Link to post Share on other sites
DangaraBMW 0 Posted December 4, 2011 Report Share Posted December 4, 2011 Imaš podršku i od mene brate Casper :) Vanja, imaš PM... da ne kvarimo Casperu temu...:) Link to post Share on other sites
DangaraBMW 0 Posted December 5, 2011 Report Share Posted December 5, 2011 Nabavljene diode zahvaljujuci Vranjinu... Svaka cast brate... :) Link to post Share on other sites
