ianullrich 0 Posted July 21, 2010 Report Share Posted July 21, 2010 kada vozim preko 3000 obrtaja u bilo kojoj brzini desava se da kvacilo dobije prazan hod za trecinu i tek dole pocinje da "hvata", na manjim obrtajima se to vrati i sve je ok interesuje me vase misljenje da li je gornji cilindar ili mozda vazduh u sistemu??? e34 m50 1990god Link to post Share on other sites
777.boban 0 Posted July 21, 2010 Report Share Posted July 21, 2010 Imao sam isti problem,i ostao u sred grada bez kvacila,crko je cilindar koji se nalazi na papucici kvacila tj gornji. Link to post Share on other sites
ianullrich 0 Posted July 21, 2010 Author Report Share Posted July 21, 2010 ma i meni se desilo jednom to isto, pre par godina pa sam menjao gornji, ali je bilo samo puf i ostadoh bez kvacila, a sada me malo buni ova situacija......... Link to post Share on other sites
777.boban 0 Posted July 21, 2010 Report Share Posted July 21, 2010 Hoce i kad se bas ugreje cilinder da zeza,kako ti se ujutru ponasa?ako je ujutru ok,a kad se uugreje pocne da zeza pri kraju je i bolje menjaj nego da te ostavi negde. Link to post Share on other sites
ianullrich 0 Posted July 22, 2010 Author Report Share Posted July 22, 2010 rasturicu ga sutra, mozda i samo gumicu zamenim.................videcu u kakvom je stanju Link to post Share on other sites
NINO BMW 0 Posted July 22, 2010 Report Share Posted July 22, 2010 Nadam se da si proverio imas li ulja,kreni odatle pa onda cilindri. Link to post Share on other sites
ianullrich 0 Posted July 22, 2010 Author Report Share Posted July 22, 2010 ma imam ulje, nije izgubio ni malo.........samo se ovo desava, ali mi nije jasno zasto se situacija menja kako se menjaju obrtaji Link to post Share on other sites
ianullrich 0 Posted July 26, 2010 Author Report Share Posted July 26, 2010 zamenjen cilindar i dalje se isto ponasa...........problem je postao misterija i za mehanicara..............znaci na vecoj brzini, 130-140-150, pri vecem broju obrtaja, sve vise i vise propada kvacilo i skoro da izgubi "druk", kad pustim gas i smanjim brzinu sve se vrati i ponasa normalno ako je neko imao slican problem neka pomogne............... Link to post Share on other sites
777.boban 0 Posted July 26, 2010 Report Share Posted July 26, 2010 Ajde mozda da lupim ali nema veze mozda je i tako,Donji cilindar koji se nalazi na zvonu menjaca mozda pri vecim brzinama a samim tim i vecim obrtajima menjaca se pregreje i izgubi svoje svojstvo. Da ti mozda menjac nije bez ulja pa se pregreje i tu temperaturu prenese na cilindar,a kad usporis on se malo ohladi taman toliko da cilindar ne zeza. Neznam sta drugo bi moglo da utice na to da on pri malim brzinama i obrtajima radi odlicno,a kad pocnes da ga peglas otkazuje. :D Link to post Share on other sites
ianullrich 0 Posted July 26, 2010 Author Report Share Posted July 26, 2010 ma otkud znam, pocinje da me nervira.......kaze ovaj mehanicar da promenimo ulje i da "produvamo" creva...............pre ce biti da je ulje lose jer nije menjano bar koliko ga ja vozim, a to je 3 godine................drugi mi pak kazu da je moguce da se crevo negde zeznulo pa ne propusta dovoljno ulja.............videcu ovih dana................ Link to post Share on other sites
ianullrich 0 Posted July 26, 2010 Author Report Share Posted July 26, 2010 a nelogicno mi je za donji cilindar, pustao bi ulje negde valjda..............a sto se tice gornjeg, prvo sam menjao samo gumice a onda promenio i ceo cilindar, jeste polovan ali je nemoguce da ni jedan ne valja i da daje totalno iste simptome Link to post Share on other sites
CasperBg82 0 Posted July 26, 2010 Report Share Posted July 26, 2010 Ne bih da baksuziram, ali cim to zavisi od brzine nema sta da bude u sistemu pedala-cilindar gornji-cilindar donji.. nego nesto u samom kvacilu, lamela, korpa i druk lezaj... iz nekog razloga kad se sve to vrti brze nesto nije u redu, najpre korpa... Mozda lupam, ali ko zna :D Link to post Share on other sites
ianullrich 0 Posted July 26, 2010 Author Report Share Posted July 26, 2010 razmisljao sam da nije korpa, ali nemoguce je da korpa ima tolikog lufta, nenormalno bi se auto treso, pri polasku, na nekim brzinama...............mada, otkud znam.....................nista ne malerises, sta god da je moram da resavam.........ne mogu uvek da vozim samo do 120kmh Link to post Share on other sites
777.boban 0 Posted July 26, 2010 Report Share Posted July 26, 2010 Druze ja sam imao problem sa donjim cilindrom,propisao je a nigde nije pojavio ulje,dok nije napunio zvono menjaca uljem i dok nije pocelo iz zvona da kaplje.Zato ti kazem da mozda nije taj cilinder problem. Link to post Share on other sites
ianullrich 0 Posted July 26, 2010 Author Report Share Posted July 26, 2010 ok, ali kako se onda vraca kad spustim brzinu??? Link to post Share on other sites
ianullrich 0 Posted July 26, 2010 Author Report Share Posted July 26, 2010 nesto kontam, da je donji izgubio bi kvacilo skroz Link to post Share on other sites
777.boban 0 Posted July 26, 2010 Report Share Posted July 26, 2010 Pa ti si rekao da ga skoro totalno i izgubis? Aj isteraj ga na put i opleti ga dobro dok ne pocne to da ti se desava,pa stani,zavuci se ispod auta i pipni menjac i taj cilinder,cisto da vidis u kojoj meri je vruc,mora da bude vruc ali probaj da primetis razliku BRZA-SPORA voznja. Jesi gledao ulje u menjacu? Ako kazes da je sve normalno sa setom kvacila,i da si 100% siguran u gornji cil,ostaje sumnja na donjem,ja neznam sta drugo moze da izazove takav problem kvacila. Link to post Share on other sites
ianullrich 0 Posted July 26, 2010 Author Report Share Posted July 26, 2010 i gubio bi ulje Link to post Share on other sites
777.boban 0 Posted July 26, 2010 Report Share Posted July 26, 2010 Da,tu si upravu,da sviraju gumice gubio bi ulje Link to post Share on other sites
ianullrich 0 Posted July 26, 2010 Author Report Share Posted July 26, 2010 gledaj, kad vozim normalno, sve je ok, onda nagazim npr 150kmh i kvacila skoro nema, onda opet smanjim brzinu i sve je ok............desava se to isto npr i u cetvrtoj na 4-5000 obrtaja i u trecoj, ali uvek kad pustim gas sve se vrati u normalu................ulje nigde ne gubi, a da je donji izgubio bi bar malo ulja............... Link to post Share on other sites
CasperBg82 0 Posted July 26, 2010 Report Share Posted July 26, 2010 Necu da te ja nagovorim da skidas menjac, ali razmisli sam... :rolleyes: Sistem pedala-cilindri ti je cista hidraulika, malo klipova i tecnosti, i nema smisla da zavisi od brzine, zar ne? A ostatak kvacila je ono sto se vrti i zavisi od broja obrtaja... Nemam sad nesto mnogo iskustva, ali pretpostavljam... Uostalom, pozovi Klinika, pozovi jos neke majstore, mozda nadjes nekog ko se sreo sa tim problemom ;) Link to post Share on other sites
ianullrich 0 Posted July 26, 2010 Author Report Share Posted July 26, 2010 ma nemoj pogresno da me shvatis, ako treba skidacu i menjac, bitno mi je da resim to.............ali svi mehanicari koji su upoznati sa ovim problemom kazu da nema sanse da je do seta kvacila, tj. moze da bude problem ali bi onda bilo niz dodatnih stvari koje bi obavezno primetio.............. Link to post Share on other sites
CasperBg82 0 Posted July 27, 2010 Report Share Posted July 27, 2010 Lamela ti je kriva, pa kad je veci broj obrtaja vise baca, i ne moze da se odvoji od korpe.. Link to post Share on other sites
ianullrich 0 Posted July 27, 2010 Author Report Share Posted July 27, 2010 problem resen, donji cilindar je zezao.......iako nije nigde pustao ulje nije bio dobar, zamenjen cilindar i sada je ok.............. Link to post Share on other sites
777.boban 0 Posted July 27, 2010 Report Share Posted July 27, 2010 Pa da ja sam zaboravio da ti kazem da postoji mogucnost da i kad crkne cilindar ne gubi ulje,jer ona brisajuca gumica i dalje radi svoj posao, a ona sto gura prosvira. Ok bitno je da si resio problem. Link to post Share on other sites
