sladjanbekonja 0 Posted October 12, 2010 Report Share Posted October 12, 2010 pri pvom paljenju zazvekece motor 1do2 sekunde.ulje je motul 10w40.probao sam da da ga prvo zaverglam kratko (da ne upali) pa ga opet zaverglam tad se upali i nema zveketanja.skidao sam poklopac i ocistio onu cev iznad brega al nije pomoglo.sta moze da bude.hvala :unsure: Link to post Share on other sites
ianullrich 0 Posted October 12, 2010 Report Share Posted October 12, 2010 jel ima taj motor hidropodizace.......ako ima to je normalno Link to post Share on other sites
Shef Nesa 0 Posted October 13, 2010 Report Share Posted October 13, 2010 Imao sam isti problem sa istim uljem.Promeni ulje ocigledno da smo sipali nekog divljaka.Promenio sam ulje,i sad nema nikakvih problema. Link to post Share on other sites
sladjanbekonja 0 Posted October 14, 2010 Author Report Share Posted October 14, 2010 koe ulje si sipao? Link to post Share on other sites
Shef Nesa 0 Posted October 15, 2010 Report Share Posted October 15, 2010 Castrol magnatec,polusinteticko malo je mozda skuple ali to cuva motor. Link to post Share on other sites
miksa 0 Posted October 15, 2010 Report Share Posted October 15, 2010 to se meni desilo kad sam kupio auto i prvi put menjao ulje posle kupovine.Cim sam zamenio ulje,odmah sutradan su poceli da mi zvekecu hidropodizaci,sledece menjanje sipali drugo ulje,posle toga opet drugo,ali jos uvek zvekece ujutru,nema pomoci Link to post Share on other sites
sladjanbekonja 0 Posted October 17, 2010 Author Report Share Posted October 17, 2010 kako je normalno kada se nije culo dok nisam poceo da sipam ova nase sjeb.na ulja probacu sa drugim uljem. :angry: hvala :rolleyes: Link to post Share on other sites
zverko 0 Posted October 17, 2010 Report Share Posted October 17, 2010 motul ne bi trebalo da bude divljak... probaj da isperes motor nekim sredstvom za ispiranje. to sto si sipao je idealno za taj motor, ne vidim razlog zasto mu se ne bi svidjalo. ako nista drugo, sigurno je bolje nego castrol magnatec a da sipas nesto gusce ne vidim svrhu. meni recimo sa castrolom 10w-60 pocne da se cuje jedan podizac negde nakon 7000 predjenih km. Izvuko 2L i dosuo Q8 F1 10w-50 i zveckanje prestalo. Eto, mogo bi da probas neki Q8. Dobro je ulje, original 100% a dosta jeftiniji od bilo kog drugog. Link to post Share on other sites
sladjanbekonja 0 Posted December 21, 2010 Author Report Share Posted December 21, 2010 menjao ulje prao motor isprao onu cevku iznad brege a on i dalje zvekace zna neko sta dalje da prestane uzasno me nervira. :angry: Link to post Share on other sites
ianullrich 0 Posted December 21, 2010 Report Share Posted December 21, 2010 to je normalno Link to post Share on other sites
BMW KLINIK 0 Posted December 21, 2010 Report Share Posted December 21, 2010 Nije bas normalno ili je uobicajeno,pogotovo nije normalno ako niste dobro ocenili odakle zvuk dolazi pa se ispostavi da lupa na radilici :pleasantry: Link to post Share on other sites
zverko 0 Posted December 21, 2010 Report Share Posted December 21, 2010 zameni podizace Link to post Share on other sites
ianullrich 0 Posted December 21, 2010 Report Share Posted December 21, 2010 mislio sam na to da je normalno da kad je hladno zazvekecu podizaci 1-2 sekunde i posle prestane Link to post Share on other sites
sladjanbekonja 0 Posted December 21, 2010 Author Report Share Posted December 21, 2010 kako da ustanovim kad se to desava samo pri prvom startu i traje veoma kratko a nekad ni pri prvom startu se necuje zavisno da li je auto parkiran uzbrdo,nizbrdo il na ravnom.uglavnom kad je parkiran( bio )nizbrdo i na ravnom se desava da ne zazvekece a kada je parkiran uzbrdo obavezno zvekace. :mellow: Link to post Share on other sites
zverko 0 Posted December 22, 2010 Report Share Posted December 22, 2010 pa da, kod mene je bilo isto tako... gremlini bato, gremlini. zameni filter za ulje, probaj to bar nije skupo. Link to post Share on other sites
sladjanbekonja 0 Posted December 23, 2010 Author Report Share Posted December 23, 2010 kad kazes da je bilo jesi resio problem i kako? si rastero gremline? pa menjao sam filter kada i ulje. Link to post Share on other sites
sladjanbekonja 0 Posted January 24, 2011 Author Report Share Posted January 24, 2011 ima neko ideju sta da radim uzasno me nervira :angry: :angry: :angry: isti simptomi i dalje.hvala Link to post Share on other sites
Misic 0 Posted January 26, 2011 Report Share Posted January 26, 2011 Proveri pritisak ulja dok je motor hladan. Link to post Share on other sites
sladjanbekonja 0 Posted January 26, 2011 Author Report Share Posted January 26, 2011 kako se proverava pritisak ulja nisam to nikad radio ima neki merni instrument??? Link to post Share on other sites
Misic 0 Posted February 27, 2011 Report Share Posted February 27, 2011 Verovatno sam zakasnio al ajde! :) Jeste, koristi se instrument koji se nabudži na blok motora, zakači se umesto senzora od lampice za ulje (tako je bar za E30 M10) Pritisak ulja mora da se meri kad je motor hladan. Ja isto imam taj problem, nikako da ga rešim, pri hladnom startu prvih par sekundi nemam pritisak uopšte, posle se pojavi i bude u granicama normale. Menjao sam i ulje i filter ali opet isto. Moraću da vadim pumpu. Link to post Share on other sites
percon 0 Posted February 27, 2011 Report Share Posted February 27, 2011 ima neko ideju sta da radim uzasno me nervira :angry: :angry: :angry: isti simptomi i dalje.hvala losi ti hidro podizaci, nekada zadrze ulje u sebi pa ti se nista ne cuje kada ga upalais a nekada ostanu bez ulja po dok ih pumpa ne napuni oni zveckaju. nista strasno to ti je kod trecine starijih bmw. Link to post Share on other sites
777.boban 0 Posted February 27, 2011 Report Share Posted February 27, 2011 Bas sam to hteo da kazem,uljna pumpa je ili prljava od raznih taloga iz ulja,ili je oslabila,ali s obzirom da sipamo svakojaka ulja od svakojakih proizvodjaca i punjaca nije ni cudo!!!A stoji i to da m40 motori imaju tu boljku sa podizacima klackalicama i bregastom,retko koji radi a da ne klapara. Link to post Share on other sites
sladjanbekonja 0 Posted February 28, 2011 Author Report Share Posted February 28, 2011 hvala svima probacu jos kad budem menjao ulje da skinem karter i ocistim uljnu pumpu a i majstor mi rekao da poskida podizace pa da ih ocisti kaze moze biti to pa cu da vidim sta ce tad da se desava.motor je m43. Link to post Share on other sites
face 0 Posted March 6, 2011 Report Share Posted March 6, 2011 Verovatno sam zakasnio al ajde! :) Jeste, koristi se instrument koji se nabudži na blok motora, zakači se umesto senzora od lampice za ulje (tako je bar za E30 M10) Pritisak ulja mora da se meri kad je motor hladan. Ja isto imam taj problem, nikako da ga rešim, pri hladnom startu prvih par sekundi nemam pritisak uopšte, posle se pojavi i bude u granicama normale. Menjao sam i ulje i filter ali opet isto. Moraću da vadim pumpu. e moram i ja da se ukljucim na ovu temu i da dam odgovor. na uljnoj pumpi ima membrana tj. kao neki filter i ona se zaprlja tako da i da pumpa hoce da pvuce dovoljno ulja ona nemoze. treba skinuti karter i ocisti taj deo pa onda videti koji od hidro podizaca lupa i taj zameniti jer je on ostecen zbog nedostatka ulja prilikom starta i sad ne drzi pritisak pa onda nije ni vazno koje je ulje. zameni taj podizac i ocisti filter uljne pumpe i bice sve uredu Link to post Share on other sites
sladjanbekonja 0 Posted March 17, 2011 Author Report Share Posted March 17, 2011 face jesi ti skidao karter posto vidim da imas isti motor ja moj nemogu da skinem posto mi smeta kolevka i menjac pokusao sam al nisam uspeo nemam predstavu kako da ga skinem :angry: Link to post Share on other sites
