leon63 0 Posted December 17, 2007 Author Report Share Posted December 17, 2007 model E36 320i coupe iz 1998. godine, kada se pritisne dugme za resetovanje trocifrene kilometraze i da polu kontakt, pojave se sledece cifre: - 363748 km, - 00000km, - 4663 km, - 15700 km, ovo je broj sasije po saobracajnoj dozvoli, - 230 km, - 06 km i - Na kraju odradi proveru kazaljki i lampica na tabli. Uz automobil imam i servisnu knjizicu po kojoj je presao onoliko koliko i pise na instrument tabli 101000 km. Posle prve provere sam presao oko 500 km, ali cifre su dalje iste i nijedna neodgovara broju sasije(sem cetvrte) ili motora. Auto sam pri kupovini proverio u SUP-u Nis u odeljenju saobracajne policije ion je potpuno legalan.Veliki pozdrav svim fanovima Bavarske industrije. Link to post Share on other sites
BMW E36 POWER 0 Posted December 17, 2007 Report Share Posted December 17, 2007 ma ta prva cifra nema veze sa kolometrazom...evo ponavljam...tetak mi je uzeo e36 iz salona i njemu izlistava skoro 400 000 na onaj prvi... Link to post Share on other sites
gadafi 0 Posted December 21, 2007 Report Share Posted December 21, 2007 :kiss3: NOTE: Just for the hell of it. KLR means ignition switch position #1 (accessory) KL-15 is ignition switch position #2 (on), and KL-50 is ignition position #3 (start) This works on all instrument clusters 1992-1999 E36 - 4 door/coupe/convertible/M3. Step 1. Press and hold the mileage reset button. Step 2. Put key into ignition switch and turn to KLR (Ignition switch position #1) Your LCD display will show something like this "tESt 01" Step 3. Once "tESt 01" is shown, let go of reset button and the IC (Instrument Cluster) will go through some test cycles. Numbers will be shown and here's what they mean: 1st display: BMW PART NUMBER (6 digits) 2nd display: CODE NUMBER (5 digits) Internal Coding Plug # 3rd display: K NUMBER (4 digits) 4th display: CHASSIS NUMBER (5 digits) this is part of your VIN 5th display: SOFTWARE VERSION (3 digits) 6th display: REVISION INDEX (2 digits) Hardware # After all 6 displays are finished, an analog gauge test will be performed. The self-test is canceled by switching the ignition off or to KL-15 (ignition switch position 2) IC (instrument cluster) tests 1-15 1995 - 1998 (99) 318ti 1996 - 2000? Z3 1997 - 1999 E36 4dr/coupe/convertible/M3 NOTE: *Test functions 1-4 are unlocked tests and can be called up at any time for display. *Test functions 5-14 are locked and require unlocking the test mode before they can be displayed. *Test functions 2-14 can be selected at any time when the cluster is unlocked, even when vehicle is moving. *Test function 15 is the lock/unlock function. Step 1: Press and hold the mileage reset button. Step 2: Put key into ignition switch and turn to KLR (Ignition switch position #1) Your LCD display will show something like this "tESt 01" Step 3: You will need to unlock the test function first so when the LCD Display shows "tESt 01," press the reset button till you get to "tESt 15." Once you're on test 15 press, and hold the reset button for a few seconds until it displays "off." Now you can cycle through the test features. Here they are as they follow: Test 1: Instrument self test Test 2: Engine Data - This display is an "engine factor" value that is stored in the coding plug. The instrument cluster processor uses this factor in addition to the "TD" signal from the DME control module to process and display tachometer RPM based on the engine installed. For EXAMPLE: *ENGINE FACTOR 2 = 4 CYLINDER *ENGINE FACTOR 3 = 6 CYLINDER *ENGINE FACTOR 4 = 8 CYLINDER Test 3: SI elapsed distance - the total mileage in kilometer since the last reset. Which service is due at the next inspection (OIL SERVICE or INSPECTION) Test 4: SI elapsed days - no value for US vehicles. Relates to Euro annual inspections. Test 5: SI evaluation factor - for engine speed and temp. thresholds being passed. Display: n = 0 or 1. Engine speed (over-rev) t = 0 or 1. Engine temp. NOTE: "n0" means that you hit the maximum threshold for engine speed and "t1" means you overheated the engine. I found out from my instructor that this test 5 is false due to software related problems. Test 6: Fuel Level and coolant temp. - Display of hexadecimal codes in relation to gauge position. Fuel gauge ----> Hex value A (empty)---------> 0d End of reserve---> 37 B-------------------> 54 C-------------------> 90 D------------------> c4 E (full)-----------> f0 Engine temp. ----- Hex Value A----------------------> ce B----------------------> 6d C----------------------> 5c D (center)----------> 4f-23 E-----------------------> 1e F-----------------------> 18 Test 7: Engine speed (Digital Tach)- display of current engine speed Test 8: Road speed - display of current road speed in km/h Test 9 Distance reading - this allows the total stored mileage to be updated if one of the storage components has to be replaced. This test step will be used if the manipulation dot is illuminated in the cluster display. This display will show the component with the lower mileage. For example: Display of 012654 l indicates that the mileage in the internal EEPROM is lower than the mileage stored in the coding plug. Display of 000325 E indicates that the mileage in external coding plug is lower then the total mileage stored in the internal EEPROM. Pressing the reset button for 4 seconds will over write the lower mileage with the higher mileage and cancel the manipulation dot. The SI data will also be transferred at the same time. Test 10: Status bits (input signals) - the status of digital inputs to the cluster are displayed as 0 or 1. Display: 0 = input low, 1 = input high. _ _ _ _ _ _ <--- Mileage display...6 digits left to right 1st - belt contact, seat belt fastened = 0 2nd - ignition lock contact, key inserted = 0 3rd - door contact, door open = 0 4th - clock button pressed = 0 5th - SI reset = 0, for reset = 0 6th - EGS transmission failure = 0 Test 11: Status Bits (output signals) - the status of digital outputs is displayed. Display: 0 = output inactive, 1 = output active _ _ _ _ _ _ <--- Mileage display...6 digits left to right 1st - Gong output 2nd - Brake warning lamp 3rd - Low fuel warning lamp 4th - EGA lamp 5th - seat belt lamp 6th - manipulation dot Test 12: not used Test 13: Country code of cluster - the display indicates the country version of the cluster. This cannot be changed in the workshop. Display: USA 02 Test 14: Software Reset - The reset must be carried out if any faults are present that are not plausible before any components are replaced. After the reset, the system will exit the TEST mode and the lock will be reactived. Link to post Share on other sites
Obi1 0 Posted December 21, 2007 Report Share Posted December 21, 2007 Gadafi, care, pretece me.. Inace lepo pise da je prve cifra bmw part number, sto bi trebalo da znaci kataloski broj kilometar sata ili compa koji ovaj test odradjuje. Kod nekog pored stoji ''km'' tako da deluje zbunjujuce. A tom ''majstoru'' sto ti je rekao da je to stvarna kilometraza, kazi da se drzi kanala i pranja ruku uljem, najbolje onim od 50000km.. 375044 je prvi broj na 318is i na 316i , toliko.. Link to post Share on other sites
leon63 0 Posted December 23, 2007 Author Report Share Posted December 23, 2007 [Gadafi veliko hvala. Jer neki samozvani strucnjaci ( citaj ljubomorni ), mi tvrde da je auto tolliko presao,( kod mene je prvi broj 363748) pa da je onda resetovana kilometraza ili smanjena. Veliko hvala i pozdrav. Link to post Share on other sites
srlebmw 0 Posted December 23, 2007 Report Share Posted December 23, 2007 Ma to su sve veliki majstori,kad ih čujem kako se gleda prava pređena kilometraža samo se kiselo nasmejem i više mu ne teram auto!!! Link to post Share on other sites
BMW E36 POWER 0 Posted December 23, 2007 Report Share Posted December 23, 2007 i ja jednom dosao do ''majstora" samo ulje i filter da promjenim...udje on u auto,sav ponosan ispritiska na brzinu(mislio da ja ne znam za to)i poce odbrojavati a prva cifra blizu 400 000 kad on skoci!!!vidi koliko ti je auto preslo,baci me covijek na sprdnju....ubi me... Link to post Share on other sites
