kako iskljuciti lampicu pritiska u gumama
Da li mozda neko kojim slucajem zna kako da iskljucim lampicu za pritisak u gumama na 318i koja mi stalno svetli...pokusao sam da drzim i vise puta i nece, pa sam i gume proveravao i opet nista, pitao sam jednog majstora ni on nije uspeo..ako ima neko ideju molim vas da pomogne..unapred hvala!
koliko sam citao to sto je google izbacio sve se svodi na
1. Check Tire Pressure to make sure no variance from side to side.
2. Sit in car, with out touching the pedals.
3. Key in ignition, Turn key on to engine off position (second position).
4. Press and hold TPM until TPM lights go out completely on the dash.
5. Press and hold TPM again until yellow TPM light indicator comes lit on dash.
6. Start car and drive. Light will go off itself once it has calibrated tire pressure. (might go out at idle).
Bitno je da po zavrsetku vozis par kilometara da se sistem kalibrise.
