spajanje instalacije od m40 na tds
  • 3 weeks later...
Evo nesto
The only problem is the M51 uses two connectors. On the second connector there are only special diesel features;
- electronic throttle ( 6 wires if i recall correctly).
- glowplug light
- ecu warning light/water in filter-light.
There are also wires on that connector that would go the clutch switch and brake switch but i didn't connect those, i think they're for cruisecontrol only. the throttle system and glowluglight and warninglight got their own little loom that goes to the dash and throttle potmeter. The 2 lights need a 12v supply that comes on when the car is on ignition.
On the main connector there are the same functions as on the E30; starter, alternator, tacho, water temp, fuel pump. Most of the colors were the same for my 2 looms, but that is no guarantee for all looms...
Evo jedan swap
http://www.e30tech.com/forum/showthread.php?t=109797
A ovde raspored zica na e30 i na e36 prvom konektoru, gledaj boje zica
http://www.rmeuropean.com/bmw-e30-m50-swap.aspx
A senzor polozaja pedale gasa?
