susice34 0 Posted September 1, 2013 Report Share Posted September 1, 2013 Pozdrav drugari... Zanima me da li neko moze tacno da mi objasni cemu sluzi onaj prekidac pored menjaca sa tri rezima rada? Znam za ekonomicnu i sport voznju ali cemu sluzi onaj polozaj za sneg kao? Imam sper diferencijal koji radi ne zavisno od tog prekidaca... Jedino ako blokira menjac u nekoj brzini dok se ne izvuces ako si se zaglavio ili slicnio, nem pojma... Ako neko ima neku pametnu informaciju o ovom bio bih mu zahvalan... Hvala unapred! Link to post Share on other sites
vranjin 0 Posted September 1, 2013 Report Share Posted September 1, 2013 Taj treci polozaj polozaj sluzi za klizav put. Sneg, blato. Kad prekidac prebacis u polozaj M tad menjac ubaci u trecu brzinu i samo sa njom vozi. I krece onda u trecoj. Link to post Share on other sites
boris74 0 Posted September 1, 2013 Report Share Posted September 1, 2013 krece u drugoj Link to post Share on other sites
susice34 0 Posted September 1, 2013 Author Report Share Posted September 1, 2013 Ok, treca druga, sve jedno... Znaci to mu dodje kao neka kontrola proklizavanja ili sta? Link to post Share on other sites
vranjin 0 Posted September 1, 2013 Report Share Posted September 1, 2013 Ako ti je rucica u D sve radi trecom. Mozes ga rucno prebaciti u drugu kad rucicu prebacis u drugu brzinu. Protiv proklizavanja jeste jer motor nema snage kad kreces trecom :) . Link to post Share on other sites
susice34 0 Posted September 1, 2013 Author Report Share Posted September 1, 2013 Ok, hvala na informaciji. Link to post Share on other sites
StunterSM 0 Posted September 1, 2013 Report Share Posted September 1, 2013 Na e34 je oznaka kao pahulja, na e32 je oznaka M, sto znaci manual. Onda ti je manuelni mod, 1,2,3. Kao i na manuelnom menjacu, u kojoj si to ti je Link to post Share on other sites
boris74 0 Posted September 1, 2013 Report Share Posted September 1, 2013 opet kazem-druga Link to post Share on other sites
susice34 0 Posted September 1, 2013 Author Report Share Posted September 1, 2013 :) Mene zeza onaj mali displej sto pokazuje u kojoj si brzini tako da kad stavim u D i pomerim prekidac na pahuljicu ne vidim kojom tacno krece i sta se u stvari desava, sacekacu ja sneg pa cu eksperimentisem... Link to post Share on other sites
StunterSM 0 Posted September 1, 2013 Report Share Posted September 1, 2013 Nema veze dal je sneg ili nije, Ubaci u pahuljicu, stavi u 1. I videces da ti nece saltati dalje od prve. Stavi u 2 i probaj da krenes, videces da krece malo teze, tj iz druge i nece da prebaci u 3 ili 4. Znaci to je manuelni mod, najjednostavnije Link to post Share on other sites
susice34 0 Posted September 1, 2013 Author Report Share Posted September 1, 2013 Ama ljudi ja nemam 1! Moj je menjac petostepeni! Imam 2,3,4,D,N,R i P. Koliko se secam probao sam da stavim prekidac na pahulju i da vozim za D i nista nisam primecivao, to jest nisam primetio da nece da salta, mada sam ga brzo i iskljucio, sutra cu bas da probam ponovo da vidim sta se desava. Link to post Share on other sites
StunterSM 0 Posted September 1, 2013 Report Share Posted September 1, 2013 HAHAHAHA! Ok, stavi u 2 i videces da nece dalje od 2. u koju ga zabodes u toj si i kraj!!!!!!! Link to post Share on other sites
susice34 0 Posted September 1, 2013 Author Report Share Posted September 1, 2013 Ok, resismo dilemu, znaci onaj prekidac blokira menjac i u koju usaltas u toj si dok ga ne iskljucis... Reci mi samo jos jednu stvar kad ubacim u D jer ima tu prva ili ne, kojom krecem ja u stvari? Jebe me onaj displej otisli izgleda pikseli i ne vidi se nista u kojoj je brzi.. Link to post Share on other sites
StunterSM 0 Posted September 1, 2013 Report Share Posted September 1, 2013 Ako si u ekonomik, ubacis u d i on salta sve lepo redom. Znaci prva, druga i tako dalje.. Vidis po obrtajima sta se desava. Ili si mislio na pahuljicu? mislim da imam ja tablu od e34 neku od automata, ali je od tds-a. Ako mozes da preb samo taj displej dacu ti je Link to post Share on other sites
susice34 0 Posted September 1, 2013 Author Report Share Posted September 1, 2013 Da da, na ekonomik sam mislio, ma oseti se kad salta nego ko da broji to cu se polupam negde :)... Ja sam trazio ovde po kg-u sat ali nisam nasao, meni je onaj nov tip sa malim displejom za kilometrazu i ima posebnu kao kuticu u satu koja se vadi i u koju ide dzek za ovo sto pokazuje u kojoj si brzini, ako imas takav sat moze da pravimo posao ako ti je stari tip sat onaj sa velikim displejom na kom se prikazuje i spoljna temperatura i da li imas vode i tako to onda mi ne odg... Link to post Share on other sites
