k B r M l W e 0 Posted May 14, 2014 Report Share Posted May 14, 2014 Cao,imam e36 compact od skoro,uzeo sam ga u osrednjem stanju i sredio ga koliko sam znao znaci servisi ulje filteri svecice cistio step motor menjao zamenio protokomer i da skratim,auto kad ga upalim dok se ne zagreje motor varira ler gas znaci ka dam gas i pustim papucicu obrtaji padnu maltene da se ugasi i sve tako dog se malo ne zagreje cim malo postigne temperaturu radi odlicno ako neko zna sta je problem neka pise,da menjao sam i cold start senzor i nista. Link to post Share on other sites
StunterSM 0 Posted May 14, 2014 Report Share Posted May 14, 2014 Cime si cistio icv Link to post Share on other sites
k B r M l W e 0 Posted May 14, 2014 Author Report Share Posted May 14, 2014 carburator cleanerom. Link to post Share on other sites
StunterSM 0 Posted May 14, 2014 Report Share Posted May 14, 2014 Gurni u ultrazvucnu kadu i ocisti, i vidi jel ima fals neki Link to post Share on other sites
k B r M l W e 0 Posted May 14, 2014 Author Report Share Posted May 14, 2014 ok probacu i sa kadom ono gibljivo crevo sam gledao nije busno dotezao selne e jedino ono crevo sto ide ispod usisne proverici i njega,i gde bi jos mogao da ima fals. Link to post Share on other sites
k B r M l W e 0 Posted May 14, 2014 Author Report Share Posted May 14, 2014 ali cudno je to sto se to desava samo dok je auto hladan kad se zagreje sve je ok radi bez greske. Link to post Share on other sites
StunterSM 0 Posted May 14, 2014 Report Share Posted May 14, 2014 Visak vazduha ne prija dok je auto hladan, sta je cudno? Link to post Share on other sites
k B r M l W e 0 Posted May 14, 2014 Author Report Share Posted May 14, 2014 Aha,nisam znao,ok,jer znas gde bi sve mogao da vuce fals. Link to post Share on other sites
k B r M l W e 0 Posted May 14, 2014 Author Report Share Posted May 14, 2014 mislim na kojim mestima da gledam. Link to post Share on other sites
Stefan L. 0 Posted May 14, 2014 Report Share Posted May 14, 2014 nakaci ga na dijagnostiku vidi dal ti je senzor temperature motora ispravan i senzor bregaste, naravno ako ustanovis da nemas falsiranje. Kriticna mesta su ti tamo gde je step motor, ne znam kako je to na kompaktu ali na e46ici kupeu ima kriticna 2-3 mesta od kojih je najcesce tu u blizini stepa gde se racva guma do njega samog i klapne gasa, a drugo mesto gore kod protokomera, al cisto sumnjam da ti je do toga, ovo je malo ozbiljniji kvar. Ako ne resis ovim javi se preko privatne da ti objasnim jos neke stvari da ne bacas pare uzalud Link to post Share on other sites
k B r M l W e 0 Posted May 14, 2014 Author Report Share Posted May 14, 2014 Ok,provericu pa se javljam.Pozz. Link to post Share on other sites
777.boban 0 Posted May 14, 2014 Report Share Posted May 14, 2014 Vakum na usisu tzv pasteta,klasicna boljka m43 motora Link to post Share on other sites
k B r M l W e 0 Posted May 14, 2014 Author Report Share Posted May 14, 2014 E jos nju nisam zamenio a planiram i nju da zamenim,bio sam kod pirketa na zrenjanincu jer mi je zadnji lonac busan njega cu zameniti i planiram da zamenim lambda sondu onu na auspuhu tj ako nadjem jeftino polovnu ili da je ocistim ako se uopste moze cistiti,mozda i ona zeza,eto sad imam zezalica onoliko pa javljam kad sve to odradim,hvala na savetima i misljenjima,pozz. Link to post Share on other sites
