DangaraBMW 0 Posted January 25, 2018 Report Share Posted January 25, 2018 Pozdrav svima...imam problem sa paljenjem kad auto malo vise stoji. Do prije mjesec dana sve je bilo tip top. Ujutru kad krenem na posao vergla bas dugo. Kad upali onda je sve ok. Pali onda bez problema. Cim malo duze odstoji odmah se pojavi problem. Svjecice sam zamijenio prije 18.000, mislio sam da je do njih pa sam opet kupio nove. Isti problem. Moze li biti do regulatora pritiska goriva ili tako nesto? Svaka pomoc je dobrodosla. Hvala unaprijed.. Link to post Share on other sites
DangaraBMW 0 Posted October 19, 2019 Author Report Share Posted October 19, 2019 Jos uvijek nijesam rijesio problem...zamijenio sam senzor radilice, nije pomoglo, stavio novi filter goriva i stavio nepovratni ventil na crijevo kod pumpe, nije pomoglo...znaci, vergla 5-6 sekundi i upali, radi kao sat, ugasim, upali odmah, posle 5 min, opet odmah upali, vec posle 15 min opet vergla... Na BMW Scanneru nema gresaka. Motor je m43b19tu.. Link to post Share on other sites
StunterSM 0 Posted October 20, 2019 Report Share Posted October 20, 2019 Imas li plin? Link to post Share on other sites
DangaraBMW 0 Posted October 20, 2019 Author Report Share Posted October 20, 2019 Imam sekvent AG Compact Link to post Share on other sites
StunterSM 0 Posted October 20, 2019 Report Share Posted October 20, 2019 Pa sto ne kazes. Otisle ti dizne. Zavrni plin i vozaj se jedan dan na benzin. Ujutru pali kao mina Link to post Share on other sites
StunterSM 0 Posted October 20, 2019 Report Share Posted October 20, 2019 Ali zavrni bocu Link to post Share on other sites
DangaraBMW 0 Posted October 20, 2019 Author Report Share Posted October 20, 2019 Jutros ugasio plin, skinuo napajanje sa + kleme i skinuo crijevo sa filtera do plinskih dizni...znaci, bukvalno uklonio plin... Svaki put auto upalio na pola kljuca, i posle sat vremena, i posle toga 3-4 sata upalio, vidjecemo ujutru...ako upali odmah, pravac kod majstora za plin.. Jbt, nijesam presao ni 40k sa tim diznama... 😞 Link to post Share on other sites
Nemanja-e36 0 Posted October 20, 2019 Report Share Posted October 20, 2019 Kod mene je bio slican problem. Nije bilo do dizni vec sam sipao na knezu plin i od tad me njakalo. Otisao kod majstora i ocistio mi je jedan ventil kod boce ili gde vec za 1000din i sve radi normalno... Link to post Share on other sites
StunterSM 0 Posted October 20, 2019 Report Share Posted October 20, 2019 Na 10.000km se menjaju filteri plina. Do dizni je sigurno, videces Link to post Share on other sites
DangaraBMW 0 Posted October 21, 2019 Author Report Share Posted October 21, 2019 Redovno sam mijenjao filtere. A reci mi, ako bude do dizni, samo zamjena dolazi u obzir ili mogu da se ociste, poprave?? Link to post Share on other sites
StunterSM 0 Posted October 21, 2019 Report Share Posted October 21, 2019 Prosla je neka necistoca. Najbolje zamena, ima i nekih setova za reparaciju za brc dizne, gumice su u pitanju. Znaci ciscenje, zamena gumica i stelovanje. Problem je sto plin udje u usisnu i presisa kad pusti benzin da pali.. Link to post Share on other sites
DangaraBMW 0 Posted October 21, 2019 Author Report Share Posted October 21, 2019 Hvala na savjetima...glavno je da sam nasao problem, da ne lutam 🙂 Koliko mogu kostati 4 nove dizne? otprilike? Link to post Share on other sites
StunterSM 0 Posted October 21, 2019 Report Share Posted October 21, 2019 Zavisi koje su 60e-80e Link to post Share on other sites
DangaraBMW 0 Posted October 21, 2019 Author Report Share Posted October 21, 2019 Hvala puno, u cetvrtak idem kod majstora koji mi je ugradjivao plin. Javicu sta sam uradio... Link to post Share on other sites
DangaraBMW 0 Posted October 30, 2019 Author Report Share Posted October 30, 2019 (edited) Bio do majstora, zavrseno sve...vakumska membrana bila problem, sve rijeseno za 10e... Hvala StunterSM 🙂 Edited October 30, 2019 by DangaraBMW Link to post Share on other sites
