nino_os 0 Posted January 26, 2010 Report Share Posted January 26, 2010 Imam BMW 520, benzinac, 98 godiste. vrsio sam redovne servise na njemu, ali mi je problem sto kada krecem kao da "trokira" oce nece, do jedne granice obrtaja, kad se obrtaji podignu kao da ga nesto ispuca i krene ko lud, nema pucanja, nema cudnih zvukova, samo jednostavno gusenje u niskim obrtajima. najvise prilikom kretanja, ali to se desava i u drugim brzinama. Link to post Share on other sites
BMW 528iA 0 Posted January 26, 2010 Report Share Posted January 26, 2010 Imas li fals vazduh? Link to post Share on other sites
AlexBMW 0 Posted January 26, 2010 Report Share Posted January 26, 2010 Potrosnja, na sta ga vozis plin ili benz? Link to post Share on other sites
nino_os 0 Posted January 26, 2010 Author Report Share Posted January 26, 2010 vozim ga na plin ali isto se desava i na gorivo i na plin. Link to post Share on other sites
AlexBMW 0 Posted January 26, 2010 Report Share Posted January 26, 2010 Jel sekvent, daj malo vise informacija, nemoj da te ispitujemo ko na faxu? Link to post Share on other sites
AlexBMW 0 Posted January 26, 2010 Report Share Posted January 26, 2010 i opet nerecce za potrosnju Link to post Share on other sites
nino_os 0 Posted January 27, 2010 Author Report Share Posted January 27, 2010 Potrosnja je veca, isto se desava i na plinu i na benzinu...i sve ono sto sam vec gore naveo, obiso sam majstora i majstora, oni to ustelaju, drzi par dana i opet pocne trokirat i gubit snagu. Link to post Share on other sites
zoki04 0 Posted January 27, 2010 Report Share Posted January 27, 2010 STRUJA!!! Link to post Share on other sites
Miki s38 0 Posted January 27, 2010 Report Share Posted January 27, 2010 da losa to je faza ili nula!!!! Proveri da ne vuce vals negde Link to post Share on other sites
BMW 528iA 0 Posted January 28, 2010 Report Share Posted January 28, 2010 Fals lambde los senzor radilice Link to post Share on other sites
nino_os 0 Posted January 29, 2010 Author Report Share Posted January 29, 2010 Falslambde los senzor radilice jel mi mozete reci gdje se nalazi taj senzor radilice i koliko je tesko to zamjeniti dal se to mora terat kod majstora ili mogu to i sam zamjeniti??? Link to post Share on other sites
R.P.M. 0 Posted January 29, 2010 Report Share Posted January 29, 2010 i ja imam isti problem sa 520i + plin radije bi taj plin izbacio nego tako sam ga kupio koji god sam vidio auto sa ugrađenim plinom imali su problema sa paljenjem te ne radi pravilno na benzin itd Link to post Share on other sites
NINO BMW 0 Posted January 30, 2010 Report Share Posted January 30, 2010 jel mi mozete reci gdje se nalazi taj senzor radilice i koliko je tesko to zamjeniti dal se to mora terat kod majstora ili mogu to i sam zamjeniti??? Senzor radilice je ispod pumpe ze vodu,cesto se desava da kad rikne pumpa voda koja curi kapa direktno na senzor i on jednostavno poludi ili crkne tako da zbog njega dolazi do trokiranja ili nece da upali auto. Link to post Share on other sites
BMW 528iA 0 Posted January 30, 2010 Report Share Posted January 30, 2010 Senzoru voda ne smeta jer on je vodotporan, on crkava jer nije nekog kvaliteta. Neki M52 motori ga imaju pozadi na blok. Link to post Share on other sites
nino_os 0 Posted January 31, 2010 Author Report Share Posted January 31, 2010 Hvala ljudi pogledat cu oko toga pa cu se javiti s novim pitanjima vjerovatno, to je nesto sto me najvise pati, auto je stvarno odlican, zadovoljan sam ali ovo me ubija... Link to post Share on other sites
BMW 528iA 0 Posted February 1, 2010 Report Share Posted February 1, 2010 Kontrolisi sve to. A CCV-a si mogao sam testirat, to traje minut i jednostavno je. Upalis motor, otvoris cep za ulje i onda pisi jel doslo do neke promjene u radu motora. Link to post Share on other sites
nino_os 0 Posted February 18, 2010 Author Report Share Posted February 18, 2010 Nisam bio u mogucnosti prije se javiti, problem sa nepravilnim radom i manjkom snage je jos tu, jel bi mi mogao neko objasniti gdje se nalazi "regulator ler gasa" da ga probam ocistiti mozda mu je to problem jer sam citao malo po slajdovima ovdje.... Kad skinem cep od ulja motor radi isto, mozda malo se jedva primjeti da je promjenio rad. Kad krecem gusi se, nema snagu i onda odjednom krene ko lud, i desava mi se da mi izbacuje sa plina na benzin.Ako netko bilo sto zna recite da znam od cega da krenem.... hvala puno. pozdrav Link to post Share on other sites
Suki 0 Posted February 18, 2010 Report Share Posted February 18, 2010 pa nisi nista provjerio od navedeng... najprije fals vazduh vidi jel ima nekih cudnih zvukova,vrlo lako moguce i da je neki vanos prdnuo... Link to post Share on other sites
boki08 0 Posted February 18, 2010 Report Share Posted February 18, 2010 fals vazduh najverovatnije !!! proveri sva creva od filtera do usisne grane!! i ako imas neka na usisnoj proveri i njih. hoce od plina da ispadnu sama iz lezista i kad je sekvent u pitanju. Link to post Share on other sites
lazanebo 0 Posted February 22, 2010 Report Share Posted February 22, 2010 mozda proveriti i svecice...ja uvek 'pucam' na kompjuter i senzore ali nekada zna biti jako sitan problem....mislim da vecina nasih BMWa starijih ima taj problem ali u manjoj meri prisutan...mozda je masa negde slabo zavijena pa pomalo gubi struju, meni se to desilo na 518 pa sam pretegao sve mase i zaista mi je lepse radio i na leru podigao malo obrtaje a i primetio sam da sam dobio snagu, isto se desava kada covek promeni svecice i filter vazduha, kao da sednes u novi auto...a i fals vazduh je vrlo diskutabilan jer ako imas obican plin (vakuumski) onda zna zaista da pravi problem ali ja mislim da se ne izrazava na taj nacin vec kroz povecanu potrosju i generalno slabiju vucu u svim rezimima...isto pogledaj da nije mozda katalizator zapusen...i kao sto su ti i pre meni komentarisali, kada otklonis te 'sitnije' stvari onda predji na senzore itd...ajde i ja da pitam, sta znaci ako motor menja zvuk kada mu se odvrne poklopac, cep....vidim da to sugerisete da se pogleda pa rekoh da pitam sta se time utvrdjuje? Link to post Share on other sites
StunterSM 0 Posted February 23, 2010 Report Share Posted February 23, 2010 Meni ispala a imam sekvent... Link to post Share on other sites
BMW 528iA 0 Posted February 25, 2010 Report Share Posted February 25, 2010 What's going on sa ovim BMW-om? Link to post Share on other sites
