Danas sam pazario jedan m50b20 i sutra ga ubacujemo u auto, e sad treba mi savet u vezi instalacije. Uz motor je dosao ecu sa instalacijom. Da li treba na onom krugu gde se spajaju instalacije nesto prevezivati? U autu je ranije prvo bio m30, pa m20. Drugo u kutiji gde su ecu motora i abs-a i pored ona 3 standardna releja imam cetvrti relej na kome pise lambda sond M30 i do njega je dovedena debelom zicom stalna struja i 2 zice koje idu u onaj krug gde se spajaju instalacije. Posto ja nemam lambda sondu da li da cupam taj relej ili da ga montiram drugacije ili nesto trece? Da li ima neko neku shemu za prevezivanje tih zezalica ili se to "buta jedno u drugo zmurecki" pa sta gde upadne "to tako treba" :D
Kakvo bre butanje :D
Evo seme zica na konektoru m50
M50 1/ blue/white (dynamic oil level)
M50 2/ blue/yellw (static oil level)
M50 3/ red/white (ABS)
M50 4/ black/blue (aircon)
M50 5/ black/grey (aircon)
M50 6/ purple/grey (aircon)
M50 7/ black/purple (drive away)
M50 8/ grey (engine check light)
M50 9/ NC
M50 10/ NC
M50 11/ brown/yellow (water temp)
M50 12/ brown/purple (water temp)
M50 13/ green/purple(fuel pump)
M50 14/ black/white (speed)
M50 15/ black/green (unloader relays)
M50 16/ white/yellow (Rx data)
M50 17/ white purple (Tx data)
M50 18/ black/yellow (starter)
M50 19/ white/green (service reset)
M50 20/ black (engine speed)
M50 21/ green (ignition)
M50 22/ green/white (diagnostic connector)
M50 23/ brown/grey (oil pressure)
M50 24/ white/black (fuel rate)
M50 25/ blue (ignition warning)
Evo za m30, proveri boje zica na konektorima, ako je isto - butaj :D
pin 1: Blue/White Oil Level Dynamic
pin 2: Blue/Yellow Oil Level Static
pin 3: Red/White 12v ABS Power
pin 4: Not Used (M5 Only Brown/Blue Full Load Compressor Cutoff from Air-Intake Control Unit)
pin 5: Black/Grey Pressure Switch Compressor Relay
pin 6: Black/Blue Auxiliary Fan (ECU Aux Fan On Alert)
pin 7: Black/Violet Driveaway Protection from OBC
pin 8: Gray Check Engine Light
pin 9: Green/Blue Not Used (M5 Only Brown/Violet Oil Temperature Sensor to Gauge in Cluster)
pin 10: Brown/Black Transmission Park/Neutral (Lets the ECU know when you're in Park/Neutral)
pin 11: Brown/Yellow Ground For Temp Sender Gauge
pin 12: Brown/Violet Coolant Temp Sender Gauge
pin 13: Green/Violet Fuel Pump Relay
pin 14: Black/White Vehicle Speed Signal
pin 15: Black/Green Unloader Relay
pin 16: White/Yellow RxD
pin 17: White/Violet TxD
pin 18: Black/Yellow Starter Terminal 50
pin 19: White/Green Service Indicator to SI board
pin 20: Black Engine Speed (RPM)
pin 21: Green Ignition
pin 22: Green/White o2 sensor relay
pin 23: Brown/Green Oil Pressure Switch
pin 24: White/Black Present Rate Fuel Output
pin 25: Blue Alternator
Uuuu, svaka ti dala. Ako se budemo ikad sreli imas pice od mene., a ako mi jos i ovu nedoumicu razresis imas i rucak :D Salim se imas svakako i rucak;). Oko 4, 5, 6 pina da li da ostavljam isto (deluje da su iste stvari, ali za m50 nije objasnjeno sta tacno koji radi, nego generalno. Takodje su mi nejasni 22 i 25 pin. Do sad nikad nisam uspeo da resetujem servisni interval, verovatno iz razloga jer na m30 je na tom pinu relej lambda sonde. Da li da skinem taj relej(bezbolno ili ima tu neka zvrcka da treba nesto da prespojim ako skidam). I naravno 25 pin sta sa njim, i sta ustvari predstavlja to upozorenje paljenja kako se ono manifestuje. Jel da ga butam :D 25 na 25
4, 5 i 6 ostavi isto, 25 je signal sa alternatora za lampicu na tabli, a za budzevinu sa lambda sondom ne mogu nista da ti kazem :)
A za 22 probaj da nadjes jos neki raspored pinova za m30 pa pogledaj
U xtra onda da ne mucim novcanik, ja bas najboljeobozavam kad mi trosi vise na sat, a manje na L/100km. Ovaj do sad sto je bio u autu nije imao lambdu, a po kompu je trosio 2.5-3.5L na sat.
Opet mi teba pomoc, ovog puta u vezi davaca za kolicinu ulja u m50 motoru onaj sto ide u karter odozdole. Danas sam kupio, a dobio sam samo jedan kraj dzeka sto ide u njega, sad je pitanje gde treba da se spoji na drugu stranu. Taj kraj kabla koji sam dobio ima 3 zicke.
