Moki88 0 Posted August 8, 2014 Report Share Posted August 8, 2014 Od kada sam prao usisnu granu faminom desava se to da se auto pri padanju obrtaja ugasi,na plin cesce na benzin kako kad... Sta sam tu mogao da s..bem,vec duze vreme vozim auto i nikako da se normalizuje,mislio sam dok sasusi vodu ako je negde ostalo ali nista od toga. Jel ima neko ideju sta je moglo da se desi? Link to post Share on other sites
vlada7891 0 Posted August 8, 2014 Report Share Posted August 8, 2014 Ako si kojim slucajem skidao usisnu granu,proveri dihtung na grani,negde vuce fals vazduh Link to post Share on other sites
777.boban 0 Posted August 8, 2014 Report Share Posted August 8, 2014 A sto si je prao? Link to post Share on other sites
vlada-t 0 Posted August 8, 2014 Report Share Posted August 8, 2014 Ler ventil ili creva oko ler ventila... Crevo od ler ventila ka crevu,gumi protokomera. Neki fals... Kod mene se to desavalo... Skini ler ventil i ocisti ga... Link to post Share on other sites
Moki88 0 Posted August 11, 2014 Author Report Share Posted August 11, 2014 Sve sam to isproveravao,sad je kao par dana ok,samo jako nisko drzi ler par sekundi na oko 400 rpm i onda podigne na 600... Link to post Share on other sites
vlada-t 0 Posted August 11, 2014 Report Share Posted August 11, 2014 Koji motor bese? M50? Ako je m50, podesi mu malo ler... mada meni to 'smrdi' na icv Link to post Share on other sites
StunterSM 0 Posted August 11, 2014 Report Share Posted August 11, 2014 Nema m50 podesavanje lera. Vidi fals ili zaprljan icv Link to post Share on other sites
Moki88 0 Posted August 11, 2014 Author Report Share Posted August 11, 2014 M20... Sta bese ICV? Link to post Share on other sites
vlada-t 0 Posted August 12, 2014 Report Share Posted August 12, 2014 Nema m50 podesavanje lera. Vidi fals ili zaprljan icv Onda izgleda samo moj ima?? :-) Link to post Share on other sites
vranjin 0 Posted August 12, 2014 Report Share Posted August 12, 2014 icv je ler ventil a pogledaj i senzor pozicije leptira. Pogledaj i svecice. Link to post Share on other sites
StunterSM 0 Posted August 12, 2014 Report Share Posted August 12, 2014 Onda izgleda samo moj ima?? :-) Moze da ti lici da to za to sluzi, ali ne steluje se ler nigde Link to post Share on other sites
Moki88 0 Posted September 17, 2014 Author Report Share Posted September 17, 2014 Skinuo sam usisnu granu posto konstantno negde sisti vazduh a nikako nemugu da lociram gde,dihtunzi deluju ok,nigde ne fali parce i to,e sad,na ovoj sipki sto ide iz kartera u granu se raspala ona mala gumica na gornjem delu sto dihtuje to,dali je moguce da mi to pravi problem? evo slika... i da dodam da auto na nizim obrtajima ne radi na svim cilindrima,verovatno zbog tog falsa koji vuce Link to post Share on other sites
vlada7891 0 Posted September 19, 2014 Report Share Posted September 19, 2014 Skinuo sam usisnu granu posto konstantno negde sisti vazduh a nikako nemugu da lociram gde,dihtunzi deluju ok,nigde ne fali parce i to,e sad,na ovoj sipki sto ide iz kartera u granu se raspala ona mala gumica na gornjem delu sto dihtuje to,dali je moguce da mi to pravi problem? evo slika... i da dodam da auto na nizim obrtajima ne radi na svim cilindrima,verovatno zbog tog falsa koji vuce E,to je to.Kao sto sam i rekao,vuce fals vazduh Link to post Share on other sites
Moki88 0 Posted September 19, 2014 Author Report Share Posted September 19, 2014 Jeste,tu je bio problem.. Fala kolega! :) Link to post Share on other sites
vlada7891 0 Posted September 20, 2014 Report Share Posted September 20, 2014 Jeste,tu je bio problem.. Fala kolega! :) Nema na cemu,tu smo da se pomazemo Link to post Share on other sites
