mica bg 0 Posted November 30, 2014 Report Share Posted November 30, 2014 pozdrav svima.danas sam menjao termostat,ozracio auto,sva creva su topla,ali motor ne dostize radnu temperaturu na polovini da stoji kazaljka,nego stoji zakucana na crti ispred polovine.grejanje ima kada se usmeri na sofersajbnu i dole na noge,ali duva hladno kada se usmeri na duvanje u sredisnjem delu,a pozadi na ventilaciji kod tunela non-stop duva hladno.da li neko ima pametan odgovor.ja nisam pametan Link to post Share on other sites
dredger 0 Posted November 30, 2014 Report Share Posted November 30, 2014 Mozda nije ispravan termostat. Moguce da je otvorio i zaglavio. Link to post Share on other sites
mica bg 0 Posted November 30, 2014 Author Report Share Posted November 30, 2014 stavio sam nov termostat proizvodjac meyle Link to post Share on other sites
dredger 0 Posted November 30, 2014 Report Share Posted November 30, 2014 Nema veze sto je nov. Skini ga pa ga probaj u dzezvi s vodom. Link to post Share on other sites
gagi225 0 Posted November 30, 2014 Report Share Posted November 30, 2014 Provjeri ga bez skidanja ako vec nisi skinuo, upali auto neka bude hladan i kako se zagrijava provjeravas toplinu crijeva gornjeg na hladnjaku i donjeg ako se griju istovremeno oba znaci kupuj drugi termostat Link to post Share on other sites
mica bg 0 Posted November 30, 2014 Author Report Share Posted November 30, 2014 razlicita je temperatura creva kada otvori termostat onda su topla oba creva,to znam Link to post Share on other sites
mica bg 0 Posted November 30, 2014 Author Report Share Posted November 30, 2014 to je sve normalno kod mene Link to post Share on other sites
777.boban 0 Posted November 30, 2014 Report Share Posted November 30, 2014 Ako imas klimu onda moze da bude modul klime,da ne otvara klapne kako treba,ako nemas klimu normalno je tj fabricki da na sredini duva hladno. Link to post Share on other sites
mica bg 0 Posted November 30, 2014 Author Report Share Posted November 30, 2014 Ako imas klimu onda moze da bude modul klime,da ne otvara klapne kako treba,ako nemas klimu normalno je tj fabricki da na sredini duva hladno. nema klimu,znaci onda je tako da duva hladno,a zasto duva hladno nazad na ventilacionim otvorima na tunelu i napred sa strane u vratima,ajde sad da te vidim :rolleyes: Link to post Share on other sites
vranjin 0 Posted November 30, 2014 Report Share Posted November 30, 2014 To ti je sve jedna klapna, ona srednja rucica na konzola. Link to post Share on other sites
mica bg 0 Posted December 1, 2014 Author Report Share Posted December 1, 2014 Hvala☺ Link to post Share on other sites
