slavisa27 0 Posted October 8, 2015 Report Share Posted October 8, 2015 Prijavljuje mi gresku od ove pumpe. Izbrisem je DiS i Inpa dijagnostikom ali se ucestalo vraca. Neko ko zna, malo objasnjenje u vezi ove vodene pumpe.. Dal se bez nje moze i cemu sluzi. Hvala Link to post Share on other sites
Elvir 0 Posted October 16, 2015 Report Share Posted October 16, 2015 Stavka br. 10. Sluzi za pomocno hladjenje motora/kabine i posle gasenja motora. http://bmwfans.info/parts-catalog/E46-Sedan/Europe/320d-M47/L-N/feb2001/browse/heater_and_air_conditioning/water_hoses_water_valve#8369806_10 Link to post Share on other sites
StunterSM 0 Posted October 16, 2015 Report Share Posted October 16, 2015 Sluzi da se grejes u kolima pomocu ventilacije dok su ona ugasena i jos topla Link to post Share on other sites
Elvir 0 Posted October 16, 2015 Report Share Posted October 16, 2015 Sluzi da se grejes u kolima pomocu ventilacije dok su ona ugasena i jos topla A jel bese imaju i neku pomocnu funkciju hladjenja ? Link to post Share on other sites
miksa 0 Posted October 16, 2015 Report Share Posted October 16, 2015 Jel to ona fora,kad auto dostigne radnu temperaturu,tj na pola,a napolju je ispod 3c,ugasis auto i pritisnes MAX,duva toplo unutra,probao jednom kod mene,radi. Jedino neznam kolko brzo sjebe akumulator. Link to post Share on other sites
StunterSM 0 Posted October 16, 2015 Report Share Posted October 16, 2015 Bas to, takodje se i pali kad se stavi na maximalni temperaturu 32C. Jer na leru nema dovoljan protok vode da bi je odrzavao. Imao sam na e34 jednom da na semoforu gubio grejanje, do ove pumpe je bilo. Istu ulogu ima i na e46, plus na e39 ima max ili rest dugme za dogrevanje kabine posle gasenja Link to post Share on other sites
slavisa27 0 Posted October 26, 2015 Author Report Share Posted October 26, 2015 Pa jel problem sto mi ne radi?? To mi je jedina greska koja se prikazuje na dijagnostici dis i inpa...Imam problema sa paljenjem kad mi je temperatura na sredini plave... kad je skroz ladan pali kao mina i kad je topao pali kao mina. Samo kad je na plavo tj negdje oko sredine vergla puno i navergla goriva pa izbaci plavi dim kad upali.. Link to post Share on other sites
StunterSM 0 Posted October 26, 2015 Report Share Posted October 26, 2015 Grejaci ti ne rade ili relej ne pali. Prosto moze da se proveri, mogu da ti objasnim preko telefona sta da uradis i proveris kako ce da upali.. Imao sam skoro isti problem Link to post Share on other sites
slavisa27 0 Posted October 31, 2015 Author Report Share Posted October 31, 2015 Ja sam iz republike srpske. Sad je kasno da te zovem al narednih dana cu ili ako ti nije tesko da preko poruke skuckas kako i sta. Mislim da bi preko dijagnostike pokazalo ako relej ili grejac ne rade u tom trenutku. Ne vjerujem da je do grijaca jer mi je neki dan na -6 upalio kao mina na po kljuca.. Hvala unaprijed :) Link to post Share on other sites
StunterSM 0 Posted October 31, 2015 Report Share Posted October 31, 2015 Slusaj, na -6 bosh pumpa daje veci pritisak i taj motor pali relativno dobro i na -20. Problem je kad je u plavom, pritisak pumpe je mali a grejaci ne rade. Uglavnom sredicemo ;) Link to post Share on other sites
slavisa27 0 Posted November 1, 2015 Author Report Share Posted November 1, 2015 Pa kako da to sredim majstore :D Link to post Share on other sites
slavisa27 0 Posted November 5, 2015 Author Report Share Posted November 5, 2015 ae pomozii StunterSM Link to post Share on other sites
slavisa27 0 Posted November 20, 2015 Author Report Share Posted November 20, 2015 Pa jel problem sto mi ne radi?? To mi je jedina greska koja se prikazuje na dijagnostici dis i inpa...Imam problema sa paljenjem kad mi je temperatura na sredini plave... kad je skroz ladan pali kao mina i kad je topao pali kao mina. Samo kad je na plavo tj negdje oko sredine vergla puno i navergla goriva pa izbaci plavi dim kad upali.. Problem rijesen zahvaljujuci StunterSM Hvala Prijatelju :) Link to post Share on other sites
