Jovan Zivkovic 0 Posted December 28, 2015 Report Share Posted December 28, 2015 pozdrav jos jednom, evo da predstavim i svoj auto, u pitanju je bmw e34 2.5TDS ne izgleda lose (bar se nadam) na nejmu su Breyton inspiration r17 felne 8.5j et13 sa 235 45 17 gumama, jvc cd plejer, klima podizaci, fabricka muzika, grejaci retrovizora itd itd :) evo i par fotkica, svaki savet bi mi dobro dosao.. inace an autu su povadjeni svi lonci to jest uradio sam straight pipe i cuje se brutalno :) imam inace i e39 2.0 dizel 136ks ali o tome kasnije ;) Link to post Share on other sites
miksa 0 Posted December 28, 2015 Report Share Posted December 28, 2015 perfekcija to sam i sam zeleo,da kupim e34 sivu i da imam 2 siva,ispunio si moj san :yes: jedino na e34 ove stopke da stavis fabriku,ovo mi nesto mnogo sljasti,inace je bombona Link to post Share on other sites
Jovan Zivkovic 0 Posted December 28, 2015 Author Report Share Posted December 28, 2015 a nije los ima jos nekih sitnica da bi bio top :) a sto se stopki tice hocu da stavim one led video sam na jednoj i moram ih uzeti :) ima li neko da se razume oko ove bos pumpe na tds ima neki problemcic pa bi mi znacila pomoc... Link to post Share on other sites
BugerMan 0 Posted December 28, 2015 Report Share Posted December 28, 2015 Imenjace, imas ti ukusa. :D Lepi autici, zdravo da te sluze. :) Link to post Share on other sites
Sale-Sombor 0 Posted December 28, 2015 Report Share Posted December 28, 2015 Apatinac? :) Link to post Share on other sites
pepsy 0 Posted December 28, 2015 Report Share Posted December 28, 2015 Jako dobra e34 i sređena sa ukusom! Reši te neke sitnice i čuvaj to kao oči u glavi!!! :thumbsup: Link to post Share on other sites
ivicaflojd 0 Posted December 28, 2015 Report Share Posted December 28, 2015 Ne volim dizele ali izgleda super [emoji106] [emoji2] Послато са LG-D373 уз помоћ Тапатока Link to post Share on other sites
Jovan Zivkovic 0 Posted December 28, 2015 Author Report Share Posted December 28, 2015 da da iz apatina je auto... bas mi ej drago da vam se svidja.. a sto se tice bos pumpe trokira mi auto cim smirim nogu na gasu znaci cim prestanem da menjam obrtaje pocne da trokira i onda ga smao zgazim po gasu on povuce i ne trokirai onda opet cim smirim gas on pocne, kacio asam na dijagonostiku i izbacuje mi gresku nesto kao tipa elektromagnetni ventil na ubrizgavanu za ubrizgavanje tako nesto :) a ujutru na ovim minusima pali na sam dodir kljuca motor je odlican nije kompresija u pitanju :) Link to post Share on other sites
Ivan13 0 Posted December 29, 2015 Report Share Posted December 29, 2015 Lepo izgleda,do skoro je bio u oglasima,ti si ga prodavao ili kupio,u oglasu pisalo da je cipovan? Baci neki snimak da cujemo taj zvuk,daj neku sliku enterijera. Sto se tice variranje lera moze da bude elektronika bos pumpe,inace dosta njih ima slican problem sa TDS-om,reci ce ti neko ko se bolje razume sta je tacno. Link to post Share on other sites
Goran032 0 Posted December 29, 2015 Report Share Posted December 29, 2015 Lepo izgleda. Dobro da te sluzi. Sent from my LG G2 using Tapatalk Link to post Share on other sites
Jovan Zivkovic 0 Posted December 29, 2015 Author Report Share Posted December 29, 2015 to sam i ja mislio, e sad da li ima neko elektroniku bos pumpe da mi da proda kako god puno bi mi znacilo :) Link to post Share on other sites
Jovan Zivkovic 0 Posted December 29, 2015 Author Report Share Posted December 29, 2015 zaboravio sam da napomenem da mi trebaju bubrezi za nejga ato jest samo ona sjajna lajsn ana bubrezima i one lajsne sto idu po dnu vrata... Link to post Share on other sites
777.boban 0 Posted December 29, 2015 Report Share Posted December 29, 2015 :thumbsup: Pozdrav iz Panceva,videli smo se (gledali smo auto) Link to post Share on other sites
jasko. 0 Posted December 30, 2015 Report Share Posted December 30, 2015 mnogo dobro stoji ova boja na e34 :pilot: Link to post Share on other sites
Ivan13 0 Posted December 30, 2015 Report Share Posted December 30, 2015 Baci neki snimak da cujemo straight pipe :-) Link to post Share on other sites
wice 0 Posted December 30, 2015 Report Share Posted December 30, 2015 koliko sam ja upucen da nije dobro voyiti turbo bez svih lonaca,tj bez pritiska u izduvu Link to post Share on other sites
Jovan Zivkovic 0 Posted December 30, 2015 Author Report Share Posted December 30, 2015 snimak stize cim malo vremena uhvatim :) a swto se tice elektronike nasao sam drugu na jednom bmw otpadu pa cu uzeti i zameniti :) prekosutra lepim vizir za 2 cm dublji to jest nizi jer sam ovaj zeznuo malopre kad sam sneg skidao, a najverovatnije cu da mu pojacam malo punjenje, ali bicete obavesteni :) Link to post Share on other sites
Ivan13 0 Posted December 31, 2015 Report Share Posted December 31, 2015 koliko para je ta elektronika ako nije tajna? Punjenje cega? :-D Link to post Share on other sites
Jovan Zivkovic 0 Posted December 31, 2015 Author Report Share Posted December 31, 2015 ja sma nasao kod drugara na bmw otpadu za 30e sa stranca :) malo nafte da mu se doda :D Link to post Share on other sites
darec032 0 Posted December 31, 2015 Report Share Posted December 31, 2015 Veceras sam te pustio da se ukljucis kod Pariza :D Auto uzivo jos bolje izgleda, svaka cast :) Link to post Share on other sites
Jovan Zivkovic 0 Posted January 1, 2016 Author Report Share Posted January 1, 2016 znam brate video sam te.. hvala na propustanju :D a jbg nije los kotrlja se :D kako se zoves na fejsu da te add-ujem :) Link to post Share on other sites
Goran032 0 Posted January 1, 2016 Report Share Posted January 1, 2016 A proleteo si i pored mene ispred Sity Paba oko 1 posle nove godine. :) lepo izgleda petica. Sent from my LG G2 using Tapatalk Link to post Share on other sites
Jovan Zivkovic 0 Posted January 1, 2016 Author Report Share Posted January 1, 2016 a kako se cuje? :D Link to post Share on other sites
Goran032 0 Posted January 1, 2016 Report Share Posted January 1, 2016 Ja nisam ljubitelj onakvog urlanja ali dobro je. Bio si primecen :) Sent from my LG G2 using Tapatalk Link to post Share on other sites
darec032 0 Posted January 1, 2016 Report Share Posted January 1, 2016 znam brate video sam te.. hvala na propustanju :D a jbg nije los kotrlja se :D kako se zoves na fejsu da te add-ujem :)Darko Vuković :) Link to post Share on other sites
