pimp 0 Posted October 7, 2016 Report Share Posted October 7, 2016 Pozdrav. Cuje mi se malo lezaj na altenatoru, pa reko da ih promenim. Jel zna neko dimezije lezajeva, oba ? Altenator za E46 N42 Valeo 110a. Da uzmem prvo lezajeve, pa posle da ga skidam i rastavljam. Link to post Share on other sites
BMW_E30 0 Posted October 7, 2016 Report Share Posted October 7, 2016 Ako imas napisi broj alternatora, tj. Valeo oznaku sa alternatora pa cu ti reci koji lezajevi tacno idu. Link to post Share on other sites
pimp 0 Posted October 7, 2016 Author Report Share Posted October 7, 2016 Ipak je Bosch, sad sam pogledao sliku.. Broj na njemu je 0 124 325 087 55-110A , ako imas i dimenziju cetkica bilo bi idealno Link to post Share on other sites
BMW_E30 0 Posted October 7, 2016 Report Share Posted October 7, 2016 Javicu ti u ponedeljak, nemam trenutno sad taj katalog. Dacu ti sifre za sve delove sa dimenzijama. Link to post Share on other sites
pimp 0 Posted October 7, 2016 Author Report Share Posted October 7, 2016 Vazi, hvala puno Link to post Share on other sites
ianullrich 0 Posted October 7, 2016 Report Share Posted October 7, 2016 Odes kod prodavaca i kazes taj broj i kupis....ja sam kod sebe pre par dana menjao Link to post Share on other sites
pimp 0 Posted October 8, 2016 Author Report Share Posted October 8, 2016 Volim da proverim sve dva put, imao sam dosta losih iskustava sa prodavcima i njihovim poznavanjem delova Kad znam dimenzije kazem i to je to, nema da me ubedjuju, i kvalitetne lezajeve i cetkice i miran sam. Link to post Share on other sites
ianullrich 0 Posted October 8, 2016 Report Share Posted October 8, 2016 2 hours ago, pimp said: Volim da proverim sve dva put, imao sam dosta losih iskustava sa prodavcima i njihovim poznavanjem delova Kad znam dimenzije kazem i to je to, nema da me ubedjuju, i kvalitetne lezajeve i cetkice i miran sam. pa ok, ali prostije da ti nadju po broju i sigurnije, ako ne odgovara kad skines tvoje lako vratis i uzmes druge........... Link to post Share on other sites
pimp 0 Posted October 8, 2016 Author Report Share Posted October 8, 2016 Lako bi bilo da sam u gradu, ne bih razmisljao al posto mi je Pancevo na 50km, BG na 70km, veruj da je bolje ovako Link to post Share on other sites
BMW_E30 0 Posted October 11, 2016 Report Share Posted October 11, 2016 Cetkice: Voltage 14, Length mm 16.50, Thickness mm 3.90, Height mm 5.90, Lead length 1 118.00. Cargo sifra za cetkice je BX2132. Lezajevi: 6003 OD 35.00, ID 17.00, Height 1 10.00 i 6303 OD 47.00, ID 17.00, Height 1 14.00. To je to sto daje po katalogu, ne stigoh juče da ti napišem. Link to post Share on other sites
pimp 0 Posted October 11, 2016 Author Report Share Posted October 11, 2016 Nema veze, svejedno hvala Sad da ih pokupim, remontujem i gas Link to post Share on other sites
pimp 0 Posted October 13, 2016 Author Report Share Posted October 13, 2016 On 11/10/2016 at 4:28 PM, BMW_E30 said: Cetkice: Voltage 14, Length mm 16.50, Thickness mm 3.90, Height mm 5.90, Lead length 1 118.00. Cargo sifra za cetkice je BX2132. Lezajevi: 6003 OD 35.00, ID 17.00, Height 1 10.00 i 6303 OD 47.00, ID 17.00, Height 1 14.00. To je to sto daje po katalogu, ne stigoh juče da ti napišem. Jel je bitno da je lezaj 2Z ili C3 ? Link to post Share on other sites
BMW_E30 0 Posted October 13, 2016 Report Share Posted October 13, 2016 Nisam siguran, ali valjda ako je Z onda je metalno kuciste, a koliko se secam rekli su mi da je bolje sa plasticnim kucistem pa ti vidi sta ima. U sustini bitno je da bude ova oznaka lezaja koja pise 6003 i 6303. Link to post Share on other sites
pimp 0 Posted October 13, 2016 Author Report Share Posted October 13, 2016 Uzeo lezajeve, u cetkice. Cim ugrabim slobodno remont Hvala jos jednom. Link to post Share on other sites
pimp 0 Posted October 18, 2016 Author Report Share Posted October 18, 2016 Skinuo danas altenator, al sam morao do druga, posto nisam imao alat da skinem remenicu altenatora. I zamenimo lezajeve, al naravno ne moze da bude sve prosto i jeftino, ispostavi se da je remenica altenatora otisla, pa sam i nju zamenio. Sad sam bar miran sto se tice altenatora Link to post Share on other sites
Oddo_mne 0 Posted October 20, 2016 Report Share Posted October 20, 2016 Mozda je malo glupo pitanje, ali kako znas da je remenica za zamjenu? Odokativnom metodom il ? Pitam zato sto i ja moram uskoro da mijenjam lezajeve alternatora na mom E36, pa da promijenim i remenicu ako je crkla. Inace mi se ponekad desi da zaskripi kais, iako je stavljen novi. Hvala unaprijed. Pozdrav! Link to post Share on other sites
StunterSM 0 Posted October 20, 2016 Report Share Posted October 20, 2016 Skripi jer je kontinental Link to post Share on other sites
pimp 0 Posted October 20, 2016 Author Report Share Posted October 20, 2016 49 minutes ago, Oddo_mne said: Mozda je malo glupo pitanje, ali kako znas da je remenica za zamjenu? Odokativnom metodom il ? Pitam zato sto i ja moram uskoro da mijenjam lezajeve alternatora na mom E36, pa da promijenim i remenicu ako je crkla. Inace mi se ponekad desi da zaskripi kais, iako je stavljen novi. Hvala unaprijed. Pozdrav! U jednom smeru treba da se malo krece, kao blagi luft, a u drugom da hvata, moja je blokirala u oba smera je okretala altenator. Ne znam da li E36 ima altenator sa tom kvacilo/remenicom, to pitaj nekog, ili proveri sam ako se razumes. Moja E36 1991g 318i je imala obicnu remenicu. Link to post Share on other sites
pimp 0 Posted October 20, 2016 Author Report Share Posted October 20, 2016 Kakvi su Gates kaijsevi ? Bila je obicna i kao ojacana verzija. Link to post Share on other sites
Oddo_mne 0 Posted October 31, 2016 Report Share Posted October 31, 2016 On 10/20/2016 at 8:24 PM, pimp said: U jednom smeru treba da se malo krece, kao blagi luft, a u drugom da hvata, moja je blokirala u oba smera je okretala altenator. Ne znam da li E36 ima altenator sa tom kvacilo/remenicom, to pitaj nekog, ili proveri sam ako se razumes. Moja E36 1991g 318i je imala obicnu remenicu. Kod mene je obicna remenica. Zamijenio lezajeve, zategao kais i za sad nema nikakvih nezeljenih zvukova. Ja zadovoljan!:) Link to post Share on other sites
