vozdovac 0 Posted December 19, 2016 Report Share Posted December 19, 2016 Poz drugari, zna li neko da li je moguce 2.5 koji je registrovan na 2.0 vratiti ponovo na 2.5,i ako je moguce koja je procedura? Unapred hvala.. Link to post Share on other sites
SSloba 0 Posted December 19, 2016 Report Share Posted December 19, 2016 Sutra zovem ujaka sad je kasno inace glavni inpektor za vozila na teritoriji vojvodine a mozda i sire nzm verovatno zna da li je moguce..i ako jeste kako se to radi..ne brini ujka je legenda opusteno ce reci i teoriju i zakon.. Sad posle nove god sam nesto nacuo ide novi zakon 2.5 izlazi iz luksuza ali nisam proverio info i to cu sut.. Link to post Share on other sites
vozdovac 0 Posted December 19, 2016 Author Report Share Posted December 19, 2016 3 minutes ago, SSloba said: Sutra zovem ujaka sad je kasno inace glavni inpektor za vozila na teritoriji vojvodine a mozda i sire nzm verovatno zna da li je moguce..i ako jeste kako se to radi..ne brini ujka je legenda opusteno ce reci i teoriju i zakon.. Odlicno,hvala druze Link to post Share on other sites
PostarSD 0 Posted December 19, 2016 Report Share Posted December 19, 2016 A zasto bi to radio?onda ti je registracija veca.... Link to post Share on other sites
vozdovac 0 Posted December 19, 2016 Author Report Share Posted December 19, 2016 1 minute ago, PostarSD said: A zasto bi to radio?onda ti je registracija veca.... Treba da ide napolje,kod nas takve mucke prolaze,ali preko se lako moze desiti da zaplene vozilo. Ne bih da rizikujem.. Link to post Share on other sites
PostarSD 0 Posted December 19, 2016 Report Share Posted December 19, 2016 E to je druga prica...nisam znao sta smeras Link to post Share on other sites
vozdovac 0 Posted December 20, 2016 Author Report Share Posted December 20, 2016 2 hours ago, PostarSD said: E to je druga prica...nisam znao sta smeras Nisam ni planirao,ali kombinacija se sama nekako namestila Link to post Share on other sites
Delija 0 Posted December 20, 2016 Report Share Posted December 20, 2016 Samo pazi, vozdovac, da ti ujak ne zakuca na vrata Link to post Share on other sites
vozdovac 0 Posted December 20, 2016 Author Report Share Posted December 20, 2016 10 hours ago, Delija said: Samo pazi, vozdovac, da ti ujak ne zakuca na vrata Previse vrata,treba potrefiti Link to post Share on other sites
gtrunner 0 Posted December 21, 2016 Report Share Posted December 21, 2016 nazovi ams i trazi homoligaciju, objasni problem i bice resen samo je bitno da je auto fabricki 2.5, ako je npr 318 kom je ubacen 2.5 a reg na 2.0 onda moras vratiti fabricki motor mada ako je 2.0 moze biti stroker jer kolenasto iz b25 pasuje u b20, onda ne moras raditi homologaciju preko vina proveri fabricku oznaku modela Link to post Share on other sites
SSloba 0 Posted December 21, 2016 Report Share Posted December 21, 2016 Info koji mogu da ti dam a iz proverenih izvora je da slobodno mozes da putujes sa tim autom preko ne mogu ti nista.. Ako stvarno prebacujes sa 2.0 na 2.5 zbog inostranstva onda ti je ova informacija najbolja koju si mogao da cujes.. Pozz Link to post Share on other sites
vozdovac 0 Posted December 22, 2016 Author Report Share Posted December 22, 2016 18 hours ago, gtrunner said: nazovi ams i trazi homoligaciju, objasni problem i bice resen samo je bitno da je auto fabricki 2.5, ako je npr 318 kom je ubacen 2.5 a reg na 2.0 onda moras vratiti fabricki motor mada ako je 2.0 moze biti stroker jer kolenasto iz b25 pasuje u b20, onda ne moras raditi homologaciju preko vina proveri fabricku oznaku modela 2.5 je sigurno,na kraju stoji 885. Hvala na informaciji Link to post Share on other sites
vozdovac 0 Posted December 22, 2016 Author Report Share Posted December 22, 2016 7 hours ago, SSloba said: Info koji mogu da ti dam a iz proverenih izvora je da slobodno mozes da putujes sa tim autom preko ne mogu ti nista.. Ako stvarno prebacujes sa 2.0 na 2.5 zbog inostranstva onda ti je ova informacija najbolja koju si mogao da cujes.. Pozz Reci mi da li se to odnosi i na eventualnu prodaju vozila u inostranstvu? Jos jednom hvala na informacijama Link to post Share on other sites
gtrunner 0 Posted December 22, 2016 Report Share Posted December 22, 2016 za prodaju mora auto biti cist brojevi se moraju podudarati sa fabrickom specifikacijom Link to post Share on other sites
vozdovac 0 Posted December 22, 2016 Author Report Share Posted December 22, 2016 9 hours ago, gtrunner said: za prodaju mora auto biti cist brojevi se moraju podudarati sa fabrickom specifikacijom Zato i hocu da vratim u saobracajnoj na 2500. Kod nas te muljaze prolaze,ali tamo.. Link to post Share on other sites
miksa 0 Posted December 22, 2016 Report Share Posted December 22, 2016 Pisao je neko od starih clanova za neku e36cu koju je oterao u irsku ili tako negde,nesecam se. Tamo je imao problem i nije mogao da registruje auto. Mislim da je isto 2.5 na 2.0 bio Link to post Share on other sites
vozdovac 0 Posted December 22, 2016 Author Report Share Posted December 22, 2016 4 minutes ago, miksa said: Pisao je neko od starih clanova za neku e36cu koju je oterao u irsku ili tako negde,nesecam se. Tamo je imao problem i nije mogao da registruje auto. Mislim da je isto 2.5 na 2.0 bio Casper je nesto pisao pre 3 godine o slicnoj temi,cekam da mi odgovori. To je ono sto bih zeleo da izbegnem,kupca imam,samo to da zavrsim.. Link to post Share on other sites
miksa 0 Posted December 22, 2016 Report Share Posted December 22, 2016 Mislim da nije Casper,nemogu da se setim kako je nick,secam se da je e36 karavan u pitanju Kucam sa telefona,pa nemogu da pretrazim forum mrsko mi. Ali nacicu temu sa kompa i ubacicu ti da procitas Link to post Share on other sites
vozdovac 0 Posted December 22, 2016 Author Report Share Posted December 22, 2016 Just now, miksa said: Mislim da nije Casper,nemogu da se setim kako je nick,secam se da je e36 karavan u pitanju Kucam sa telefona,pa nemogu da pretrazim forum mrsko mi. Ali nacicu temu sa kompa i ubacicu ti da procitas Vazi,hvala Link to post Share on other sites
vozdovac 0 Posted December 23, 2016 Author Report Share Posted December 23, 2016 On 21.12.2016. at 6:29 AM, gtrunner said: nazovi ams i trazi homoligaciju, objasni problem i bice resen samo je bitno da je auto fabricki 2.5, ako je npr 318 kom je ubacen 2.5 a reg na 2.0 onda moras vratiti fabricki motor mada ako je 2.0 moze biti stroker jer kolenasto iz b25 pasuje u b20, onda ne moras raditi homologaciju preko vina proveri fabricku oznaku modela Bio sam danas do AMSS,kazu da oni tu ne mogu nista. Poslali su me u SUP,odakle me salju na tehnicki. Tek nakon tehnickog mogu na Vozdovcu da trazim novu saobracajnu. Link to post Share on other sites
