duje96 0 Posted December 29, 2016 Report Share Posted December 29, 2016 Imam bmw e36 316i te planiram u njega ubacit 1.8is, zanima me sta nije isto te sta moram uz motor promijeniti? Link to post Share on other sites
777.boban 0 Posted December 29, 2016 Report Share Posted December 29, 2016 Sve je isto,samo spustis motor udzekas i gas Link to post Share on other sites
duje96 0 Posted January 7, 2017 Author Report Share Posted January 7, 2017 struja je također ista? Link to post Share on other sites
777.boban 0 Posted January 7, 2017 Report Share Posted January 7, 2017 1 hour ago, duje96 said: struja je također ista? Da,glavni vodovi,mozda neki davac treba prevezati,ne secam se najbolje ja sam ubacivao 318 m43 u auto u kojem je bio IS,samo sam udzekao motornu instalaciju na dzek i sve je radilo.Jedino ako imas ews(imobilajzer) to ces morati da preskocis. Link to post Share on other sites
Paun_e36 0 Posted January 7, 2017 Report Share Posted January 7, 2017 a menjac sa m43 jel dolazi na m44 ? I diff jel isti prenos? Link to post Share on other sites
duje96 0 Posted January 8, 2017 Author Report Share Posted January 8, 2017 pase, mislim da getriba i od dizela pase, a diff u 1.6 je 3.38 a u 18.is 3.45 ali naravno pase mozda je cak ubrzanje bolje kad se ostavi diff od 1.6 Link to post Share on other sites
DEJAN74 0 Posted January 9, 2017 Report Share Posted January 9, 2017 A jel zna neko dali je moguce ubaciti u e39 recimo 2.0 motor umesto 2.2,imam ceo auto 2.0 ali ne moze da se carini,kako ide sa papirima kasnije,jel moguce regularno ga registrovati Link to post Share on other sites
777.boban 0 Posted January 9, 2017 Report Share Posted January 9, 2017 AKo je ista kodna oznaka motora da,ali nije tako da nemoze. Link to post Share on other sites
DEJAN74 0 Posted January 9, 2017 Report Share Posted January 9, 2017 sta je kodna oznaka,to mi nije jasno malo Link to post Share on other sites
DEJAN74 0 Posted January 9, 2017 Report Share Posted January 9, 2017 predpostavljan da mogu samo ubaciti neki drugi 2.2 motor,nikako slabiji,jel u tome poenta? Link to post Share on other sites
wice 0 Posted January 9, 2017 Report Share Posted January 9, 2017 recimo ako je bio m50moze samo m50 ne i m52 iako je ista kubikaza.znaci samo isti Link to post Share on other sites
DEJAN74 0 Posted January 9, 2017 Report Share Posted January 9, 2017 aha ok,znaci snasli se politicari haha,kakva banda Link to post Share on other sites
StunterSM 0 Posted January 9, 2017 Report Share Posted January 9, 2017 Moze da se upise ako taj motor postoji fabricki u e39 sasiji. Molim bez pogresnih informacija Link to post Share on other sites
wice 0 Posted January 9, 2017 Report Share Posted January 9, 2017 da moze ali da rodis mecku dok dobijes sve potrebne papire,uverenja i potvrde,uz sve to sve to kosta i pitanje na kraju koji ce auto proci zavrsni atewt jer traze da sve bude u fabrickom stanju.mada kome je fetis seksanje po salterima samo napred,a da je neki vredan auto pa da se covek i zeza Link to post Share on other sites
duje96 0 Posted January 9, 2017 Author Report Share Posted January 9, 2017 e da zaboravio sam pitati sta je sa kilerom(hladnjakom) moze li ostat od 1.6 a ako ne moze jesu nosaci isti? Link to post Share on other sites
DEJAN74 0 Posted January 9, 2017 Report Share Posted January 9, 2017 2 hours ago, StunterSM said: Moze da se upise ako taj motor postoji fabricki u e39 sasiji. Molim bez pogresnih informacija cekam odgovor direktno iz mup-a,pa cu videti,mislim da mi je drugar to radio i da traze atest samo ako se prelazi na vecu kubikazu,nisam jos siguran a drugar u Svedskoj pa ne mogu da ga pitam Link to post Share on other sites
StunterSM 0 Posted January 9, 2017 Report Share Posted January 9, 2017 Trazi se atest kako god, ali se i prolazi. Ja radio 2016 god. Prolazi se glat, bez saltera Link to post Share on other sites
DEJAN74 0 Posted January 10, 2017 Report Share Posted January 10, 2017 popricacemo na tu temu ali ne ovako,uz neko picence,mezence... Link to post Share on other sites
La Haine 0 Posted January 10, 2017 Report Share Posted January 10, 2017 On 9.1.2017. at 10:33 AM, DEJAN74 said: A jel zna neko dali je moguce ubaciti u e39 recimo 2.0 motor umesto 2.2,imam ceo auto 2.0 ali ne moze da se carini,kako ide sa papirima kasnije,jel moguce regularno ga registrovati Taj 2.0 ako je sa 6 , ne gadja se mehanicki sa m54, mislim da ne moze. Link to post Share on other sites
777.boban 0 Posted January 10, 2017 Report Share Posted January 10, 2017 3 hours ago, Shy said: Taj 2.0 ako je sa 6 , ne gadja se mehanicki sa m54, mislim da ne moze. Ako je m52tu sve se gadja AKo je m52 onda se gadja mehanicki ali struja je problem(ali i to se resava) Link to post Share on other sites
La Haine 0 Posted January 10, 2017 Report Share Posted January 10, 2017 OK, drugar mi je onda pogresno objasnio. Eto, ima ko zna. Link to post Share on other sites
DEJAN74 0 Posted January 11, 2017 Report Share Posted January 11, 2017 moze da se ubaci i upise bilo koji motor koji je fabricki isao u e39,to je podatak vazeci Link to post Share on other sites
777.boban 0 Posted January 11, 2017 Report Share Posted January 11, 2017 8 hours ago, DEJAN74 said: moze da se ubaci i upise bilo koji motor koji je fabricki isao u e39,to je podatak vazeci MOze,ali dok to sve pozavrsavas useres se sebi u zivot,mozda je stunter to resio bez problema ali veruj da mozes da imas ozbiljnih problema sa papirima i da nista ne uradis. Link to post Share on other sites
DEJAN74 0 Posted January 11, 2017 Report Share Posted January 11, 2017 2 hours ago, 777.boban said: MOze,ali dok to sve pozavrsavas useres se sebi u zivot,mozda je stunter to resio bez problema ali veruj da mozes da imas ozbiljnih problema sa papirima i da nista ne uradis. naravno,zivimo u drzavi gde ni ono sto su ti odobrili ne mora da znaci da ce uspeti,na kraju krajeva drzava ti garantuje platu a ne da ti,sve je moguce u banana republikama ali sta da radimo Link to post Share on other sites
La Haine 0 Posted January 11, 2017 Report Share Posted January 11, 2017 Ja sam pre par godina bio voljan da uguram u e46 neki poveci motor starije generacije npr, jer ih je bilo u ponudi i dobri su itd. A onda mi moj majstor kaze "ima mnogo posla oko struje, necu to da radim", a Boban mi kaze "ne gadjaju se mehanicki, ne mogu to da radim" , a neko cetvrti kaze kaze ne moze to u e46. Ajde sad neka mi neko kaze da li moze ili ne moze to fizicki da se uradi ili ljudi ne zele to da rade. Link to post Share on other sites
