Aleksa Aničić 0 Posted January 5, 2017 Report Share Posted January 5, 2017 Hteo bih da "ugradim" AUX u svoj e 46. video sam dosta linkova, yt klipova i svasta . pa sam hteo da pitam da li bi jednostavno mogao ovo da uradim ? da ne bih kupovao bzv onaj kabal ?http://www.diymybmw.com/e46/aux-input-cable/ inace ovakav mi je cd, nemam sanzer u gepeku .fotos hochladen Link to post Share on other sites
StunterSM 0 Posted January 5, 2017 Report Share Posted January 5, 2017 Nemas dugmeMODE, tako da ne moze Link to post Share on other sites
Aleksa Aničić 0 Posted January 6, 2017 Author Report Share Posted January 6, 2017 Izgleda da moze , nego mi nije jasno sta radi to u gepeku ? Link to post Share on other sites
wice 0 Posted January 6, 2017 Report Share Posted January 6, 2017 pa dodao je neki modul za ipad ili tako nesto Link to post Share on other sites
leon63 0 Posted January 6, 2017 Report Share Posted January 6, 2017 Koje je godiste auto tacno. Proveri po VIN. I recicu ti moze li ili ne. Link to post Share on other sites
Aleksa Aničić 0 Posted January 8, 2017 Author Report Share Posted January 8, 2017 gratis bilder hochladen Link to post Share on other sites
leon63 0 Posted January 8, 2017 Report Share Posted January 8, 2017 Od juna 2002 moze. Ista je prica i za BM54. Link to post Share on other sites
Aleksa Aničić 0 Posted January 8, 2017 Author Report Share Posted January 8, 2017 Znaci nema nikakvo resenje da preko fona pustam muziku ? Link to post Share on other sites
leon63 0 Posted January 8, 2017 Report Share Posted January 8, 2017 Nazalost ne. BMW je kao muzickih uredjaja tek od 06.2002. ubacio opciju aux u hardwer, jer sam imao muku dok nisam to provalio, na nekim CD C53 i pojacalima BM53 i BM54, nisam mogao da dobijem MODE AUX, pa sam malo proguglao i nasao taj podatak.Mislim da imam takav CD, pa cu proverim koje je godiste, pa ako je posle 06.2002. ti mi posalji tvoj, ja cu tebi taj i resi problem. Link to post Share on other sites
Aleksa Aničić 0 Posted January 8, 2017 Author Report Share Posted January 8, 2017 Hvala, vazi , javi kad budes nasao . Link to post Share on other sites
Desmo 0 Posted January 8, 2017 Report Share Posted January 8, 2017 Moze li na ovaj aux ili neka sd kartica? E46 2003g Link to post Share on other sites
PostarSD 0 Posted January 8, 2017 Report Share Posted January 8, 2017 2 hours ago, leon63 said: Nazalost ne. BMW je kao muzickih uredjaja tek od 06.2002. ubacio opciju aux u hardwer, jer sam imao muku dok nisam to provalio, na nekim CD C53 i pojacalima BM53 i BM54, nisam mogao da dobijem MODE AUX, pa sam malo proguglao i nasao taj podatak.Mislim da imam takav CD, pa cu proverim koje je godiste, pa ako je posle 06.2002. ti mi posalji tvoj, ja cu tebi taj i resi problem. a ovako dali moze? http://www.instructables.com/id/Aux-Input-for-BMW-325i-Business-CD/ Link to post Share on other sites
Aleksa Aničić 0 Posted January 8, 2017 Author Report Share Posted January 8, 2017 Ovo je isto kao moj , to su modeli(bez onog drugog prikljucka) do 06.2002.Mislim da moze ovo da se napravi samo treba dobar elektircar i dobro upustvo za rad, da se ovo lepo prevede i odradi . Link to post Share on other sites
Aleksa Aničić 0 Posted January 9, 2017 Author Report Share Posted January 9, 2017 2 hours ago, Desmo said: Moze li na ovaj aux ili neka sd kartica? E46 2003g Prvo bih hteo da te pitam jel ti radi navigacija i jel ima neku svrhu u Srbiji sd msm da nema prikljucak za tako nesto . a aux msm da moze posto je 2003 , najbolje da ga izvuces (imaces posla oko 5 min) i vidis da li ima onaj 2 prikljucak ako ima onda moze .napravis kabal kao na ovom linku ili kupis preko neeta i samo spojih , msm da je oko 10 e kabal. pogledaj ovaj link http://www.diymybmw.com/e46/aux-input-cable/ Link to post Share on other sites
Desmo 0 Posted January 9, 2017 Report Share Posted January 9, 2017 Probao sam kad sam kupio auto, mislim da radi al ne koristim je. Hvala za link! Link to post Share on other sites
Desmo 0 Posted January 31, 2017 Report Share Posted January 31, 2017 http://www.ge39.com/files/EBADoc11512-auxin.pdf Link to post Share on other sites
Mare ETF 0 Posted May 20, 2017 Report Share Posted May 20, 2017 Zdravo ljudi, vidim odavno je bio poslednji odgovor na ovu temu pa ne znam da li je problem resen ja ugradih aux na moj bmw, doduse moj plejer je vec imao pinove za aux, samo je bio potreban kabl. Ja probah da odradim kao onaj lik na onom linku sto je Aleksa postavio ali meni nije hteo da prepozna aux vec sam morao da postavim otpornik od 300k Ohm da bi proradilo. E sad tamo pise da se trebaju postaviti i kondenzatori na red sa L/R linijama (levi i desni ulaz) ali mislim da mi je bas malo slabiji. Za tvoj plejer Aleksa mislim da postoji varijanta da se preko cd sarzera pusti aux ulaz pa valjda kada pustas preko telefona tamo na displeju pise CD 1-99 ili tako nesto. E sad kako to ide preko sarzera nisam siguran ali garant i tamo imaju dva pina za levi i desni kanal (i masa naravno kao treci pin). Ali prvo mi javi da li si resio problem Veliki pozdrav Link to post Share on other sites
