NINO BMW 0 Posted February 7, 2011 Report Share Posted February 7, 2011 Šampionske :dance3: .BMW,NGK,BOSCH može,Ostalo je :lol: Link to post Share on other sites
majstorbob80 0 Posted January 23, 2012 Report Share Posted January 23, 2012 Dok sam vozio e30 m40 1,6 skinem stare svecke sa kojima sam ga kupio a na njnima pise NGK i BMW, stavim bosch po katalogu kupljene, i auto mnogo losije radi. Vratim stare, narucim iste takve i vozi ne razmisljaj.Znaci NGK. Link to post Share on other sites
BMW_E30 0 Posted May 28, 2014 Report Share Posted May 28, 2014 Imam problema sa autom, ponekad trokira, secka i pukne u auspuhu, uglavnom kad je hladan, kad se ugreje uglavnom nema problema. Nekad se desi upalim i sve radi kako treba, ne znam od cega da pocnem? Da li svecice mogu da prave problem da nekad trokira a nekad ne? Link to post Share on other sites
bemveac 0 Posted May 28, 2014 Report Share Posted May 28, 2014 kreni od svecica jer su najjeftinije i jos ako nisi skoro menjao. kablove i bobinu treba preispitati Link to post Share on other sites
Sicko 0 Posted January 27, 2015 Report Share Posted January 27, 2015 Malo sam u dilemi oko svećica koje bi trebalo da zamenim. Za brend nisam u dilemi idu NGK, ali koje od ovih ponudjenih sa njihovog sajta. Auto ima plin. Po forumima raznim vidim da preporučuju ove najskuplje (4 kraka). Ne znam da li zbog plina treba sa jednim krakom (smeša drugačija bla, bla...). Za m54 motore ove preporučuju: http://www.ngk.com/Automotive-NGK-c1411.aspx Link to post Share on other sites
hermes 0 Posted January 27, 2015 Report Share Posted January 27, 2015 Bas to, bla,bla. Link to post Share on other sites
Sicko 0 Posted January 28, 2015 Report Share Posted January 28, 2015 Ma za tebe znam... Još neko. Link to post Share on other sites
Sicko 0 Posted January 28, 2015 Report Share Posted January 28, 2015 Special spark plugs from NGK: Specifically developed for gas operation As well as the current iridium types, NGK now also offers special spark plugs for gas-powered vehicles. They are specifically manufactured for use in retro-fitted vehicles and have proven themselves in Japan for many years – for example in taxis, which are without exception gas-powered in that country. It’s the plating that does it. The spark plugs for use with gas are plated with a chrome alloy specifically developed by NGK for this purpose. It is able to resist the aggressive conditions of gas operation for longer than normal platings. At present for cars there is no other spark plug which can offer a similar plating. Platinum and iridium: The dynamic duo. In the same way as with standard iridium and platinum spark plugs, the special spark plugs for gas-powered cars also have a laser welded centre electrode using an iridium chip of only 0.6 mm diameter. In addition, the ground electrode is fitted with a platinum chip which further improves the durability and therefore the lifetime of the spark plug. An overview of the special spark plugs: ● A particularly long life thanks to a special plating for the metal shell as well as electrodes of platinum and iridium. ● Reliable ignition and an even spread of the flame core. ● The best ignition properties also when operating with gas. ● Low ignition voltage requirement. ● In comparison with standard spark plugs, improved emission values also when operating with gas. A word on installation. There is no difference between installing a spark plug in a dual fuel engine and installing one in a normal engine. Before removing the old spark plug, the cylinder head should be cleaned. The new spark plug is then screwed in by hand and then tightened with a torque wrench to the correct torque setting. In some cases it has proven effective when retro-fitting for gas operation to reduce the electrode gap slightly, 0.3 mm at the most, in comparison to the normal recommendation for petrol operation to facilitate the spark discharge. Iridium spark plug BPR6EIX-LPG Ovo kaže ngk lično :-) Link to post Share on other sites
Sicko 0 Posted January 28, 2015 Report Share Posted January 28, 2015 Hahah cena ove svećice je nešto preko 1900 din. Mnogo bre. http://e-mass.rs/proizvod.php?LID=023kjj0ccae9hw1&idA=5744 Link to post Share on other sites
Stefan L. 0 Posted January 28, 2015 Report Share Posted January 28, 2015 ja sam stavio sve ngk samo se ne secam cene, radi ko sat Link to post Share on other sites
