FloydM3 0 Posted December 13, 2009 Report Share Posted December 13, 2009 Evo ovako , auto mnogo trosi , konkretno 14l na otvorenom putu inace motor je u perfektnom stanju, dizne nisu ciscene, ali se bojim da je protokomer ,pa bih molio za savet ,pomoc ako je neko imao slicna desavanja... Hvala unapred... Link to post Share on other sites
Vanyonni 0 Posted December 13, 2009 Report Share Posted December 13, 2009 Zimi uvek vise trosi, ali ne toliko. Lamdba? Link to post Share on other sites
BMW 528iA 0 Posted December 13, 2009 Report Share Posted December 13, 2009 MAF, fals vazduh, lose svecice, dizne, ulje i td. Link to post Share on other sites
FloydM3 0 Posted December 13, 2009 Author Report Share Posted December 13, 2009 MAF, fals vazduh, lose svecice, dizne, ulje i td. Ovako zanenjeno ulje pre 100 km Castrol, svecice Ngk, e sad zanima me taj maf senzor gde se tacno nalazi kod mog motora , i da li mogu da ga ocistim sa alkoholom kao na snimku sto radi Kajza na M3.... Link to post Share on other sites
FloydM3 0 Posted December 13, 2009 Author Report Share Posted December 13, 2009 Ovako zanenjeno ulje pre 100 km Castrol, svecice Ngk, e sad zanima me taj maf senzor gde se tacno nalazi kod mog motora , i da li mogu da ga ocistim sa alkoholom kao na snimku sto radi Kajza na M3.... I da ubrzava jednako i fenomenalno al varira na leru izmedju 500- 800o/min ali samo kad je zagrejan... Link to post Share on other sites
BMW 528iA 0 Posted December 13, 2009 Report Share Posted December 13, 2009 O2 senzori. Link to post Share on other sites
FloydM3 0 Posted December 13, 2009 Author Report Share Posted December 13, 2009 O2 senzori. Gde se nalaze ako nije problem da mi objasnis gde se nalazi i sat se radi jel se menjaju, kako se proverava dal su oni...hvala Link to post Share on other sites
Nidza crveni 0 Posted December 13, 2009 Report Share Posted December 13, 2009 lambda kad se pojebe trosi kao sleper! Link to post Share on other sites
error 0 Posted December 13, 2009 Report Share Posted December 13, 2009 prvu ćeš nekako i da nadješ, katalizator možda, a drugu nećeš naći sigurno Link to post Share on other sites
FloydM3 0 Posted December 13, 2009 Author Report Share Posted December 13, 2009 lambda kad se pojebe trosi kao sleper! kako da proverim dal je lamda jel na dijagnostiku il kako Link to post Share on other sites
AlexBMW 0 Posted December 13, 2009 Report Share Posted December 13, 2009 Ma oladi... MAF moze da utice na potrosnju dosta, to sto pricaju daa utice samo malo kenjaju, znaci najjeftinija solucija da pocnes da resavas problem je da recimo ides 50kmh u drugoj brzini i na ekonomeru vidi potrosnju, zatim dok je upaljen auto skini dzek od protokomera( moze da se ugasi zato malo dodaj gas dok skidas dzek) i ponovi isto, ako ima razlike u potrosnji onda menjaj. Na dijagnostici nece izbaciti gresku da protokomer ne valja vec ce dati ocitavanja kolko kilograma vazduha ulazi u motor na leru, a onaj sto ti radi dijagnostiku mora da zna koji je ispravan podatak, takodje je slicna stvar i sa sondama, neka ti na dijagnostici provere senzor temperature motora i senzor temp. usisnog vazduha koji je na kutiji filtera vazduha. MAF: Link to post Share on other sites
zeljko_srb 0 Posted December 13, 2009 Report Share Posted December 13, 2009 i meni 2.5 trosi preterano puno benzina, a ne cepam ga kad trosi puno. isao sam na aerodrom pre neki dan, posrko mi je skoro 3 iljade na 200 i nesto kilometara. to je abnormalna potrosnja, jos je i na otvorenom bila voznja. Link to post Share on other sites
[kick] 0 Posted December 14, 2009 Report Share Posted December 14, 2009 Ja ne mogu ni 200km da predjem sa 3000din sa 2.0 a ti se tu zalis sto ti 2.5 trosi toliko :heat: Link to post Share on other sites
zeljko_srb 0 Posted December 14, 2009 Report Share Posted December 14, 2009 oces da kazes da je to normalno? pa kolko ce da mi trosi plina onda, 25 litara? Link to post Share on other sites
djokicbmw2 0 Posted December 14, 2009 Report Share Posted December 14, 2009 pa nece 25,ali 20 sigurno :heat: Link to post Share on other sites
ma men 0 Posted December 14, 2009 Report Share Posted December 14, 2009 A koliko ti je prije onda trošio ako ti sada troši 14L? Link to post Share on other sites
wice 0 Posted December 14, 2009 Report Share Posted December 14, 2009 "i meni 2.5 trosi preterano puno benzina, a ne cepam ga kad trosi puno. isao sam na aerodrom pre neki dan, posrko mi je skoro 3 iljade na 200 i nesto kilometara. to je abnormalna potrosnja, jos je i na otvorenom bila voznja." jbg pa to je oko 28 litara zar ne?ako si presao preko 200 km to je potrosnja ispo 14 litara,a jos je automatik,mislim da to nije previse jbg vozio si 318 na plin pa ti je tukao preko 15 litara plina tako da mislim da je ovo ok Link to post Share on other sites
BMW 528iA 0 Posted December 14, 2009 Report Share Posted December 14, 2009 Pa 2.0 sestak u OK stanju pije 12 prosjek, tako da... Na dijagnostiku na test lambdi i MAF-a. Link to post Share on other sites
FloydM3 0 Posted December 14, 2009 Author Report Share Posted December 14, 2009 A koliko ti je prije onda trošio ako ti sada troši 14L? 10l nesme da predje na otvorenom pri brzini od 120km/h.. Link to post Share on other sites
FloydM3 0 Posted December 14, 2009 Author Report Share Posted December 14, 2009 Pa 2.0 sestak u OK stanju pije 12 prosjek, tako da...Na dijagnostiku na test lambdi i MAF-a. Ok hvala Vilsone... Link to post Share on other sites
igorE36 0 Posted December 14, 2009 Report Share Posted December 14, 2009 i meni 2.5 trosi preterano puno benzina, a ne cepam ga kad trosi puno. isao sam na aerodrom pre neki dan, posrko mi je skoro 3 iljade na 200 i nesto kilometara. to je abnormalna potrosnja, jos je i na otvorenom bila voznja. Zar si uopste ocekivao manje? tvoj bivsi 318 a i moj 316 uzmu 10l benzina ako se ne maze,a sad imas 2.5 na automatiku a jos je svez kod tebe pa ga piknes gde stignes,a?priznaj! :) Link to post Share on other sites
BMW-E36 0 Posted December 14, 2009 Report Share Posted December 14, 2009 Meni pije 12 ljeti a 15 zimi 316i al na otvoreno ne moze da predje 7,5l smjesno al realno... Link to post Share on other sites
wWRCw 0 Posted December 15, 2009 Report Share Posted December 15, 2009 citam ovu temu i neverujem oko cega se prepucavate covek lepo pita i trazi pomoc a vi se zajebavate bas ste neozbiljni!!! a ja sam mislio da moj 120d trosi mnogo po gradu sto je 8l! ali kad vidim koliko trose bezinci glava me zaboli!! a neverujem da ni jedan ide boljeod mog! Link to post Share on other sites
FloydM3 0 Posted December 15, 2009 Author Report Share Posted December 15, 2009 citam ovu temu i neverujem oko cega se prepucavate covek lepo pita i trazi pomoc a vi se zajebavate bas ste neozbiljni!!!a ja sam mislio da moj 120d trosi mnogo po gradu sto je 8l! ali kad vidim koliko trose bezinci glava me zaboli!! a neverujem da ni jedan ide boljeod mog! U pravu si , stvarno su neozbiljni neki ljudi ovde, al nebitno navikao sam na to radim sa ljudima stalno ... A sto se tice ovog tvog 120d,upravu si i u vezi toga, jbg samo sto dizel nemoze da ti pruzi ono uzivanje u voznji i taj zvuk kao benzinac, ali zato je stedljiviji... Link to post Share on other sites
StunterSM 0 Posted December 15, 2009 Report Share Posted December 15, 2009 I da ubrzava jednako i fenomenalno al varira na leru izmedju 500- 800o/min ali samo kad je zagrejan... Isti i ja imam problem, srce 17l po gradu, ako ga ne cepam, ako stisnem ode crvena.. Ponekad se i desi to variranje u ler gasu, ali samo ponekad.. Druze ako resis problem javi sta je bilo, ovo mora sto pre da se resi... :) Link to post Share on other sites
