Djoksa530i 0 Posted January 8, 2015 Report Share Posted January 8, 2015 Odvezi nekome auto da ga ozraci, meni to ipak lici na vazdusni cep. Link to post Share on other sites
StunterSM 0 Posted January 8, 2015 Report Share Posted January 8, 2015 Pa vazdusni cep i jeste, ali zbog malog hladnjaka koji je ocigledno busan. Nastaje pri hladjenju, uvuce vazduh kroz tu pukotinu.. Sta ti fali, i ja sljakam napolju sada kad moram. Obuci se i resavaj to, ako ti digne temperaturu negde najebao si Link to post Share on other sites
FILIP-M3 0 Posted January 9, 2015 Author Report Share Posted January 9, 2015 Moram da nadjem mali hladnjak prvo pa da rastavljam,kako se krecu cene? I ima li razlike klima i bez klime? Link to post Share on other sites
FILIP-M3 0 Posted January 9, 2015 Author Report Share Posted January 9, 2015 I ima li razlike klima i bez klime? i sta se desava ako crkne taj ventil grejanja pored kutije od osiguraca? Link to post Share on other sites
777.boban 0 Posted January 9, 2015 Report Share Posted January 9, 2015 ima razlike u hladnjacima od godista do godista,od toga ima ili nema klimu..... Kad crkne ventil ili ostane otvoren pa stalno greje ili zatvoren pa ne pusta vodu u kutiju. Link to post Share on other sites
FILIP-M3 0 Posted January 9, 2015 Author Report Share Posted January 9, 2015 pod gasom greje samo,u mestu kao klima :D i ako je nemam Link to post Share on other sites
777.boban 0 Posted January 9, 2015 Report Share Posted January 9, 2015 Brate pocni da radis mani se tastature,mi te krstimo a ti prdis. Link to post Share on other sites
CasperBg82 0 Posted January 9, 2015 Report Share Posted January 9, 2015 Pocni da skidas :) http://www.bimmerforums.com/forum/showthread.php?1328893-*DIY-E34-heater-core-R-amp-R-(IHKA-content) Link to post Share on other sites
vranjin 0 Posted January 9, 2015 Report Share Posted January 9, 2015 Nije to tako strasno kao sto izgleda :) . Cini mi se da nema goreg posla nego menjati taj hladnjak. Link to post Share on other sites
FILIP-M3 0 Posted January 9, 2015 Author Report Share Posted January 9, 2015 Ovih dana skidam mali hladnjak,i javljam sta se desava Link to post Share on other sites
Djoksa530i 0 Posted January 9, 2015 Report Share Posted January 9, 2015 I kod mene i dalje problem, stim sto nigde ne pusta tecnost. Od kad mi je "strucnjak" menjao antifriz nisam imao grejanje, pa smo sutradan muku mucili ga dobijemo grejanje i uspeli, ali pipam ono crevo sa leve strane hladnjaka i hladno je. Grejanje imam, stim sto je na leru slabije, glavni problem je sto je isparivac najvisa tacka...Ne znam sta da mu radim? P.s. Temperatura ne ide preko pola, a ume I da padne za neki mm I tu da se zadrzi. Link to post Share on other sites
StunterSM 0 Posted January 9, 2015 Report Share Posted January 9, 2015 Ozraci ga, al kod majstora, ne strucnjaka :) Link to post Share on other sites
Djoksa530i 0 Posted January 9, 2015 Report Share Posted January 9, 2015 Treba mi preporuka za bg? Link to post Share on other sites
FILIP-M3 0 Posted January 9, 2015 Author Report Share Posted January 9, 2015 ja dok nisam sipao antifriz tj menjao bilo je savrseno sve... od kada sam menjao antifriz,malo cistio hladnjak veliki,menjao creva preventivno zbog starosti pocelo je da zeza ja nikako nemam grejanje u leru ne vozim vise na plin,samo na benzin da li plin i dalje ima ulogu onda zbog ozracivanja posle? Link to post Share on other sites
Djoksa530i 0 Posted January 10, 2015 Report Share Posted January 10, 2015 Ja bih I tebi preporucio da ti neko pismen ozraci to, mozda ti uopste ne uvlaci vazduh ako je pre zamene hladnjaka bilo sve ok. Link to post Share on other sites
777.boban 0 Posted January 10, 2015 Report Share Posted January 10, 2015 Ja bih I tebi preporucio da ti neko pismen ozraci to, mozda ti uopste ne uvlaci vazduh ako je pre zamene hladnjaka bilo sve ok. Ma jok ne uvlaci,ali zato ispusta paru u kabinu.Mozda ima jonizator vazduha. Link to post Share on other sites
FILIP-M3 0 Posted March 15, 2015 Author Report Share Posted March 15, 2015 Tek danas sam uzeo da rastavljam sve da dodjem do malog hladnjaka :) i vec sam se iznervirao, sve zivo sam skinuo ne mogu da skinem zastitu onu plastiku preko hladnjaka sto ima... A kada sam skinuo onu plastiku ili usmerivac gde duva za grejanje iscurelo mi je malo antifriza, tako da je sada 99% do hladnjaka, alii dzaba kada ne mogu da dodjem do njega :( saljem sliku malo kasnije Link to post Share on other sites
FILIP-M3 0 Posted March 15, 2015 Author Report Share Posted March 15, 2015 Link to post Share on other sites
CasperBg82 0 Posted March 15, 2015 Report Share Posted March 15, 2015 jesi video ovu sliku na onom linku? http://www.bimmerforums.com/forum/showthread.php?1328893-*DIY-E34-heater-core-R-amp-R-(IHKA-content) Link to post Share on other sites
FILIP-M3 0 Posted March 15, 2015 Author Report Share Posted March 15, 2015 Jesam 3 puta sam gledao to ali on nigde nema poklopac kao moj, ili ispod ovog mog ima jos jedan kao taj sa slike Link to post Share on other sites
FILIP-M3 0 Posted March 15, 2015 Author Report Share Posted March 15, 2015 ako neko nesto zna neka javlja hitno :D Link to post Share on other sites
StunterSM 0 Posted March 15, 2015 Report Share Posted March 15, 2015 Pa vidi se iz aviona da on nema IHKA jedinicu nego onu obicnu.. Tako da moras da trazis uputstvo, mada ako je obicna cupas celu kutiju grejanja verovatno jer ona kooliko se secam nema 2 mala hladnjaka Link to post Share on other sites
StunterSM 0 Posted March 15, 2015 Report Share Posted March 15, 2015 Preporucio bi ti da potrazis poklopac sa strane, mislim da je to moguce EDIT Originally Posted by Eero H View Post Yes i find, but they all are different. I have 4 seater with rear seat center console. So i cant remove middle center console like in this DIY. Next i have heater control cables, and they are PITA to remove. Also my heater pipes look different. But i try again someday... Its rather easy; 1) remove both back-seats 2) remove the cover over the middle arm rest (eight screws), four on each side 3) remove center glove box (four screws on teh bottom) 4) remove sigaret lighter (rear) 5) you now see two bolts through the opening that hold the rear part of the middle console. Remove these bolts. 6) remove rear part of the center console 7) remove the two bolts through the opening (left and right) 8) remove the screw that connects middle-and front sections (in the center glove compartment). 9) remove the shifter-knob and disconnect its lighting 10) remove the rear plastic nut from the front compartment. 11) the rest is as in teh earlier mentioned DIY 12) you appear to have a IHKR in stead of IHKA; the IHKR does have manual bowden cables that are tricky to disconnect indeed. Link to post Share on other sites
FILIP-M3 0 Posted March 15, 2015 Author Report Share Posted March 15, 2015 Uspeo sam da ga izvadim,sa vozaceve strane sam dosao do njega,vadi se kao fioka ima kao dva mala hladnjaka spojena pa ako neko ima nesto da ponudi moze na pm ili ovde Link to post Share on other sites
FILIP-M3 0 Posted March 15, 2015 Author Report Share Posted March 15, 2015 evo ovakav http://ills.bmwfans.info/cnw.png Link to post Share on other sites
