kalkan 0 Posted December 2, 2011 Author Report Share Posted December 2, 2011 usput, onih drugih bmw-a nema odavno... U međuvremenu sam uzeo i sređijem Opel Rekord '78 coupe, 2.2i, Getrag 5 brzina, koji je isto prošao kroz velike promjene. Sada izgleda ovako... Kao i jednog talijana, Lanciu Thesis 3.0i. Lud auto. Link to post Share on other sites
goxxy 0 Posted December 2, 2011 Report Share Posted December 2, 2011 5+ ;) Link to post Share on other sites
Sutlandjanin 0 Posted December 3, 2011 Report Share Posted December 3, 2011 Svaka cast. :good: :ola: Link to post Share on other sites
Dzoni Paviljoni 0 Posted December 3, 2011 Report Share Posted December 3, 2011 Svaka cast, samo napred! Sto je lepa ona S2-ka u garazi :) Link to post Share on other sites
325ixA 0 Posted December 3, 2011 Report Share Posted December 3, 2011 Senzor temperature usisa. Kako stand-alone ECU "prepoznaje" sve senzore... koji ecu? Link to post Share on other sites
alexxx 0 Posted December 3, 2011 Report Share Posted December 3, 2011 Svaka čast na trudu i radu, za svaku pohvalu.... Link to post Share on other sites
kalkan 0 Posted December 3, 2011 Author Report Share Posted December 3, 2011 Svaka cast, samo napred! Sto je lepa ona S2-ka u garazi :) Nije to S2, osnova je običan Coupe. To je auto za svaki dan, sa planiranih 1000ks. Trenutno je na cca 800, na 2 bara. 2,7 biturbo. Link to post Share on other sites
kalkan 0 Posted December 3, 2011 Author Report Share Posted December 3, 2011 koji ecu? megasquirt 2 Link to post Share on other sites
Dzoni Paviljoni 0 Posted December 3, 2011 Report Share Posted December 3, 2011 Video sam da napred ima S/RS branik pa zato ... Link to post Share on other sites
kalkan 0 Posted December 3, 2011 Author Report Share Posted December 3, 2011 Video sam da napred ima S/RS branik pa zato ... Replika po uzoru na original. Ima razlike zbog puno većeg IC-a. Link to post Share on other sites
325ixA 0 Posted December 3, 2011 Report Share Posted December 3, 2011 megasquirt 2 uzeo si gotov ili u delovima pa sam sklapao i koliko je kostao? ko ce ti mapirati? Link to post Share on other sites
kalkan 0 Posted December 3, 2011 Author Report Share Posted December 3, 2011 uzeo si gotov ili u delovima pa sam sklapao i koliko je kostao? ko ce ti mapirati? kupio sam u kitu, za 6 cilindara + map senzor 4bara. Iz USA, cca 500,00EUR sa dostavom. Imam čovjeka koji će to sastaviti i ispitati na simulatoru, to je nekih 50,00EUR. Slaganje struje i mapiranje će odraditi prijatelj koji se vozi na MS-u godinama, i uvjek na podiju na trkama tako da tu ne očekujem probleme. Naprotiv. Link to post Share on other sites
OGNJEN5 0 Posted December 3, 2011 Report Share Posted December 3, 2011 Evo ja da userem temu.. :) sve, sve, ALI bi bilo lepse da je 6-ici orig.volan i rucica menjaca!! Inace me je opila! B) Link to post Share on other sites
kalkan 0 Posted December 3, 2011 Author Report Share Posted December 3, 2011 u njoj i jeste original ručica mjenjeača i volan, poresvučeni u pravu kožu i prošiveni sa "M" koncem (crveno-plavo). Ono su slike kad sam ga uzeo, a to je bilo davne 2004... :) Link to post Share on other sites
Dejan NS 0 Posted December 3, 2011 Report Share Posted December 3, 2011 Druze iskren da ti budem mislio sam da si omasio boju . Sobzirom da je boja radjena za noviju generaciju vozila mislio sam da nestoji lepo na ovim starijim modelima , pa sam sad pogledao na netu jer se tvoj auto i nevidi bas kako bi trebao da bi se moglo reci dali je ok ili nije . Zajebao sam se debelo jer ako izgleda upola kao ovaj e21 onda je pun pogodak , a njega sam uzeo u obzir jer dosta lici na sesticu . Svaka cast na volji, trudu i svemu ostalom i neka te pravo sluzi kad je napravis. [/ Link to post Share on other sites
kalkan 0 Posted December 4, 2011 Author Report Share Posted December 4, 2011 moj e24 ima puno kromiranih djelova po sebi (branici, lajsne ono stakala, bubrezi, okviri svjetala)kao i planirane polirane felge, tako da sam htio tamnu boju kako bi to bilo u kontrastu. Bila je u igri crna, ali kad sam vidio ovu Sepang brončanu to mi je bilo to. E sad, kako auto još nije završen, a boja u sebi ima puno zlatne perle, niti ja točno ne znam kako će ovo izgledati, dok ga prvi put ne obasja sunce. Znam samo da je boja potpuno drugačija ovisno o svjetlu. Ne vjerujem da mi se neće sviđati, a na kraju krajeva lakiranje je najlakše u ovoj priči. Link to post Share on other sites
AndrejaM5 0 Posted December 4, 2011 Report Share Posted December 4, 2011 Pratim :pilot: Link to post Share on other sites
OGNJEN5 0 Posted December 5, 2011 Report Share Posted December 5, 2011 Too kralju! Jedva cekam da bude opet na putu!! ;) Link to post Share on other sites
kalkan 0 Posted December 10, 2011 Author Report Share Posted December 10, 2011 kako senzor položaja na klapni usisa na mom autu ne zadovoljava, odnosno treba modernija verzija koja radi na principu potenciometra, nabavljen je dio sa e46 modela... isto tako, malo se igram sa dodatnim instrumentima koje mislim staviti umjesto pepeljare. Nabavio sam neki nosač od VW/AUDI modela sa par čukica... vidjet ćemo hoće li biti šta od ovoga. Link to post Share on other sites
kalkan 0 Posted December 10, 2011 Author Report Share Posted December 10, 2011 "špijunske" fotografije iz "powered by Konopek" garaže... Link to post Share on other sites
OGNJEN5 0 Posted December 10, 2011 Report Share Posted December 10, 2011 TURBOOO !!! Da ga sto pre "kresnes" i da ti sto duze traje motor! ;) Link to post Share on other sites
kalkan 0 Posted December 11, 2011 Author Report Share Posted December 11, 2011 saga se nastavlja... ovo meni sada već ulazi u domenu Sci-Fi, i polako mi postaje jasno što je Konopek stvorio. neću više trošiti slova... Na ovim slikama se dosta dobro vidi položaj turbine i ostalih stvari, kako trebaju stajati da se ugrade u e24 bez da se auto igdje buši ili reže. Link to post Share on other sites
Dejan NS 0 Posted December 12, 2011 Report Share Posted December 12, 2011 Meni deluje kao da ces morati voziti bez haube , mnogo mi je nesto visoka ta turbina . Nesumnjam da nije mereno vise puta ali tako deluje . Link to post Share on other sites
kalkan 0 Posted December 13, 2011 Author Report Share Posted December 13, 2011 tako djeluje jer na motoru nema usisa. mjereno je više puta, i isprobavano u praksi. hauba je bila na autu. Link to post Share on other sites
kalkan 0 Posted December 13, 2011 Author Report Share Posted December 13, 2011 upravo naručeno: EGT Thermocouple K type for Exhaust Gas Temp Probe Digital DC Temperature Meter for K Type EGT Probe © dvije stvari mi se sviđaju: -izgled i robusnost (retro) - cjena od 210,00kn :) Operating Temperature -100 – 1250 C Probe Material - Stainless Steel Probe Diameter - 5mm Probe Length (L) - 80mm Probe Length (L1) - 30mm Threads Size - 1/8” NPT Threads Lock - Adjustable Pressure Lock - (Adjustable Length) Cable Length - 2m Cable External Shielding - Stainless Steel Braiding Cable Internal Insulation - Fiberglass Link to post Share on other sites
